WIFI won`t work , but ethernet cable does.
Sobolanu
9:38 PM
My wifi connection won't work, and every time I try to troubleshoot it, it says "Plug an ethernet cable into this cumputer". I have never connected my laptop to an Ethernet cable, so I'm wondering if I had deleted something (I usually delete things I don't really need). All of the devices in my house are able to connect the wifi just fine, but for some reason my laptop won't. (I cant really get a ethernet cable because i usually move my laptop so i cant move the ethernet cable) My wifi switch isnt working.
Thanks.
HP
ESET
Google
Does the network properties show you have a wireless adapter and is it also in device manager. If you open a cmd prompt and type ipconfig /all and post results that will tell us
win 8 32 bit
Here`s the screenshot with cmd : Click
Here`s another thing : Click
HP
ESET
Google
    Ryzen 9 5950X, 3.8 - 5.2 MHz
    Asus Prime X570-Pro
    64GB [2 x 32GB] DDR4 3200MHz
    2 x 3840 x 2160 @60Hz
    Workstation Case [Matt Black]
    920 MB Down 50 MB Up
    Also run ...
    Nexus 7 Android tablet x2
    Samsung 10.2" tablet
    Wacom Expresskeys Remote
    Loopdeck+ Graphics Controller
    Shuttle Pro v2 Control
    Dell XPS 17 10750H
    Windows 11 Pro x64 Latest RP
    Intel I7 10750H 5.0GHz
    Dell XPS
    32GB [2x16GB] DDR4 2933 MHz
    nVidia GTX1650Ti 4 GB GDDR6
    Stock [Realtek] 4 Speaker
    3840 x 2400
    Stock - Active Fan Control
    Backlit + Various Logitech
    72 MB Down 18MB Up
    Also run ...
    10.2" tablet
    Sony Z3 Android Smartphone
    Shuttle Pro v2 Control Pad
    10TB NAS
CPU : Pentium(R) Dual-Core CPU T4500 @ 2.30GHz
Motherboard : Hewlett-Packard 1526
BIOS : Default System BIOS
Total memory : 8,00 GB
Usable : 7,90 GB
HDD : (1) WDC WD3200BEKT-08PVMT1 ATA Device (2) Kingmax USB2.0 FlashDisk USB Device
Sound Card : (1) High Definition Audio Device (2) High Definition Audio Device
Graphics Card : Microsoft Windows 7 Ultimate 64-bit 7601 Multiprocessor Free Service Pack 1
NETWORK
Manufacturer : Realtek
Name : Realtek PCIe FE Family Controller
Adapter Type : Ethernet 802.3
MAC Address : 1C:C1:DE:A1:DD:34
Connection Name : Local Area Connection
Connection status : Media disconnected
Enabled : False
I hope this is enough.
HP
ESET
Google
The immediate thing that shows there is that there is no wireless network adaptor listed
NETWORK
MAC Address : 1C:C1E:A1D:34
Enabled : False
All this relates to a disabled ethernet adaptor
You need to check the system documentation, discover the details of the wireless network, obtain the drivers (from the HP site), and install them
Try here ... HP Pavilion dv4-1526la Entertainment Notebook PC Software and Drivers | HP® Customer Support ...
and Here [url="http://h10032.www1.hp.com/ctg/Manual/c01487709"]http://h10032.www1.hp.com/ctg/Manual/c01487709
[/url]
The alternative is to purchase a USB stick wireless adaptor which comes with Windows 7 drivers or has them available (not as easy as it used to be as most on sale are now set-up for Windows 10)
    Asus Prime X570-Pro
    Also run ...
    Dell XPS 17 10750H
    Dell XPS
    3840 x 2400
    72 MB Down 18MB Up
    Also run ...
    10.2" tablet
    10TB NAS
