Window 7 home premium 64bit, nid help T_T
lester123
3:00 AM
Is Windows 7 . . .
- x86 (32-bit) or x64 ? x64
- the original installed OS on the system? window 7 home premium
- an OEM or full retail version? OEM
- OEM = came pre-installed on system
- Full Retail = you purchased it from retailer
- What is the age of system (hardware)? NOt more than 2 month
- What is the age of OS installation (have you re-installed the OS?) no
Sorry, this does not related to sudden attack..I try google my problem , but cant seem to find a solution , wonder if any tech guy here could help me. thx..
The problem is, everytime after i start up my notebook , i cant press anything on the desktop , example the taskbar the start button , but! i can double click on folders on my desktop..but not the icon...then if i CTRL+Del+alt, everything return to normal..i tried doing clean boot but it does not fix my problem
Tis is different problem
Another one is, i can drag my icon in desktop, but i cant drop it, example i try to put my icon to other place, it juz wont go ther, it stay the same location , i does not make auto grid, and when i tried to move my thing into 1 folder, i juz cant drop it into the folder, i juz only cn copy and paste..
AND, i also have blue screen once in awhile, so i did everything u all told me to.. if i miss out, pls guide me.thxx!!
sorry for my poor english , pls help ! T_T
Microsoft Windows 7 Home Premium 64-bit 7601 ...Intel(R) Core(TM) i7-2630QM CPU @ 2.00GHz8.00 GB(1) Intel(R) HD Graphics Family (2) Radeon (T...
Hewlett-Packard 1657
8.00 GB
(1) Intel(R) HD Graphics Family (2) Radeon (TM) HD 6770M
(1) IDT High Definition Audio CODEC (2) Intel(R) Display A
TOSHIBA MK6461GSYN
Razer Lycosa Mirror
Cyborg R.A.T 7
Is Windows 7 . . .
These two were Related to Lycosa.sys Tarantula Keyboard Driver from Razer USA Ltd. I would re-install the newest version
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\K\Desktop\Windows_NT6_BSOD_jcgriff2\060411-17877-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*C:\Symbols*http://msdl.microsoft.com/download/symbols;srv*e:\symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 7601.17592.amd64fre.win7sp1_gdr.110408-1631
Machine Name:
Kernel base = 0xfffff800`02e63000 PsLoadedModuleList = 0xfffff800`030a8650
Debug session time: Fri Jun  3 22:37:35.040 2011 (GMT-4)
System Uptime: 0 days 0:02:38.946
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 1E, {0, 0, 0, 0}
Unable to load image \SystemRoot\system32\drivers\Lycosa.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for Lycosa.sys
*** ERROR: Module load completed but symbols could not be loaded for Lycosa.sys
Probably caused by : Lycosa.sys ( Lycosa+1051 )
Followup: MachineOwner
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
so thats the fix for bsod? how about the drag n drop , and the start up problems==!
anyway thanks alot!!
8.00 GB
TOSHIBA MK6461GSYN
Razer Lycosa Mirror
Cyborg R.A.T 7
Window 7 home premium 64bit~help T_T
Whenever i start up my notebook (HP) , i cant click on anything , i cn open folders but cant close them , any icon on my taskbar is unclickable.. but i solved it with ctrl+del+Alt... but tis is annoying, how do i fix it?
and 1 more, i seem to unable to drag n drop file, example i wan to arrange icons in my desktop , i cant seem to move it, its not auto align , and when i wan to copy files into folder, normally i juz drag n drop, but it wont drop... still i can juz copy and paste, but tis is annoying! pls help !!
8.00 GB
TOSHIBA MK6461GSYN
Razer Lycosa Mirror
Cyborg R.A.T 7
Are you using a wireless mouse?
Have you tried logging into a different account and seeing if the problem exists?
Windows 7 Home Premium 64bitIntel Core i5-2500 @ 3.8GHzG.SKILL Ripjaws Series 8GB (2 x 4GB) DDR3 1600NVIDIA GTX 550Ti
MSI P67A-GD65
NVIDIA GTX 550Ti
On Board
ASUS 23"
OCZ Vertex 3 VTX3-25SAT3-60G
Wireless
Wireless
I use a usb connected mouse. the mouse is gaming mouse called cyborg rat 7
no it does not fix the problem...however after i cr8 a new profile n switch on to it.above problem is fix. after i restart , everything return to normal wher i couldnt drag n drop etc..
8.00 GB
TOSHIBA MK6461GSYN
Razer Lycosa Mirror
Cyborg R.A.T 7
So the problem is fixed in your original profile? Or just the new one?
MSI P67A-GD65
NVIDIA GTX 550Ti
On Board
ASUS 23"
Wireless
Wireless
its like this, i cr8 a new profile, and i switch to the new profile, yes i can drag n drop , then i back to my old profile, it can drag n drop , but then i restart and go to my new profile, i cannot drag n drop anymore and at startup the taskbar freeze thus i nid to alt+ctrl+del to fix it jus like the old profile..
8.00 GB
TOSHIBA MK6461GSYN
Razer Lycosa Mirror
Cyborg R.A.T 7
Have you ran any virus scans?
MSI P67A-GD65
NVIDIA GTX 550Ti
On Board
ASUS 23"
Wireless
Wireless
i think this have somthing to do with my mouse middle button ..
8.00 GB
TOSHIBA MK6461GSYN
Razer Lycosa Mirror
Cyborg R.A.T 7
Try getting just a standard USB mouse and see if the problem continues.
MSI P67A-GD65
NVIDIA GTX 550Ti
On Board
ASUS 23"
Wireless
Wireless
