Wired/Wireless Internet Connection Only WORKS In Safe Mode (help)
kkeo7
6:05 PM
Pretty much my internet connection only(barely) works in safe mode but even then I'd have to disconnect and reconnect it to run for a minute or so. In regular startup the connection goes straight to limited/or disconnected. All of my other devices/computers connected to the router works. I've tried everything from flushing my dns to downloading malware removers but I'm still not having any luck. Help? :cool:
1. Is this a wired or wireless connection issue?
Both
2. Who is your Internet Service Provider (ISP)?
Cogeco
3. What type of Broadband connection are you using?
Cable/Wireless Card
4. What is the exact Make and Model of your Modem, Router or Modem/Router Combo -
Linksys Technicolor DPC3848VM DOCSIS 3.0 Gateway
5. What is the Name of the Anti-Virus, Security or Firewall Software
I did have McCafe, but I just recently uninstalled it but no luck still. I've tried disabling and re-enabling my firewall as well but no success.
Windows IP Configuration
Host Name . . . . . . . . . . . . : pheap-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : cgocable.net
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : cgocable.net
Description . . . . . . . . . . . : Realtek PCIe GBE Family C
Physical Address. . . . . . . . . : F8-0F-41-31-55-A1
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::d16c:ca17:7681:4a84
IPv4 Address. . . . . . . . . . . : 192.168.0.203(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Wednesday, March 01, 2017
Lease Expires . . . . . . . . . . : Wednesday, March 08, 2017
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 217583425
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1D-F3-4E-9A-7
DNS Servers . . . . . . . . . . . : 24.226.10.193
24.226.10.194
24.226.1.94
24.226.1.93
NetBIOS over Tcpip. . . . . . . . : Enabled
Wireless LAN adapter Wireless Network Connection:
Description . . . . . . . . . . . : 802.11n Wireless LAN Card
Physical Address. . . . . . . . . : 74-DE-2B-42-B8-BF
IPv6 Address. . . . . . . . . . . : 2001:1970:5068:dd00:76de:
referred)
IPv6 Address. . . . . . . . . . . : 2001:1970:5068:dd00:81bd:
referred)
Temporary IPv6 Address. . . . . . : 2001:1970:5068:dd00:8819:
referred)
Link-local IPv6 Address . . . . . : fe80::81bd:878c:8632:5c32
IPv4 Address. . . . . . . . . . . : 192.168.0.169(Preferred)
DHCPv6 IAID . . . . . . . . . . . : 192208427
DNS Servers . . . . . . . . . . . : 2001:1970:c06e:c0::94
2001:1970:c06e:c0::93
2001:1970:c0c0:6ec0::194
2001:1970:c0c0:6ec0::193
24.226.10.193
24.226.10.194
24.226.1.94
24.226.1.93
Connection-specific DNS Suffix Search List :
cgocable.net
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-I
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter isatap.cgocable.net:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Hello and welcome kkeo7 mate please follow this first before we can get anywhere
Now before we can help we do need to know what is in your machine so please do this System Info - See Your System Specs
or either enter the specs of your system in your forum profile the specs will appear when we click on that little box bottom left of the post screen it is for me the preferable option as it is easy. As you may appreciate it is very hard when you don’t know what one is working with for example a diesel or petrol engine.
*(pretyped to save time)
Now please post using black text as it is quite hard to see what the lime green text is saying.
However I have to ask did you uninstall MuckAfee using the dedicated uninstall tool? If not then I think it might be an idea to run it now because if you did it manually there may still be traces of it left in the registry.
https://service.mcafee.com/webcente...&showHeader=false&_adf.ctrl-state=vs6rdwm7o_4 < you need to go to the download link in this page.
Lastly if you can get into safe mode please run these
Disk Check < if necessary include the /f switch and if this does not make any improvement then just run this switch instead /r in the command line as per Option2
Run these in safe mode and the sfc often best run for two to three runs – you can leave out the /r switch in ckdsk if you feel it not necessary
But we need the system specs!
1920x1080 D1 & D2 & Laptop 1
Desk1 Samsung 120GB 830 SSD
Asus ROG 256GB 850 Pro SSD
Desk2 Samsung 840 256 SSD
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
System restoring it fixed the problem. Thanks for the assistance either way. :D
Hmm probably some update or add on stuff that came with a program/software you installed.
If you want to stop that happening again if indeed that is what it was then just install this I use it on all my machines.
Unchecky - Keeps your checkboxes clear
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
