Wireless Connection Problems
Isildrae
5:03 AM
Hey there,
I've recently got a new PC and installed a Wireless card that was previously running on my very old PC with no problems. Ok so my network has other stations (wired and wireless) running perfectly fine, connecting both to the router and the internet. My new machine however can see and connect to the router, but it says that I have no internet access.
The devices on the network that work with no problems are as follows:
PC (7 years old) - Wired Connection - Windows XP
MacBook - Wireless Connection
XBox 360 - Wireless Connection
Now I have tried a Wired connection with my new PC and it works fine, unfortunately this is not practical and I hope to get the wireless working.
Below is the IPConfig from my new PC. It is Windows 7 and has the latest Service Pack. My router also has the latest firmware and the latest drivers are on the Wireless Card. I have also tried rolling back the Drivers, but to no avail. I have tried various combinations of resetting the router, the modem and PC and have reset the network and started a fresh, but still the same problem appears.
Previously in my struggles the problem seemed to be with the Default Gateway (After Diagnosing, the system replies that "The Default Gateway Is Not Available" has now been fixed.)
I am obviously frustrated and have poured over various help sites. I have been able to gain an internet connection, after Diagnosing, the machine seemed to connect fine, for about ten seconds, then it was almost like something had been reset or switched off. To my un-computer literate brain, it seems like the problem most probably lies with some settings on my new PC or a problem with the Wireless Card. The Router and connection work fine with other machines and even the problem machine when it is wired.
In the IPConfig I have included both the Wired and the Wireless connections. The net works on the Wired regardless of whether the Wireless is enabled or not. I figured it may provide some insight as to why the Wired works and the Wireless doesn't.
...here is my system information.
POWER SUPPLY - 500W RECON BRONZE PSU
MOTHERBOARD - P7P55D LE MOTHERBOARD
PROCESSOR - INTEL i5-750 QUAD CORE
CPU COOLER - AKASA X4 CPU COOLER
MEMORY - 4GB DDR3 - 1333Mhz MEMORY
HARD DRIVE - 500GB SATAII
OPTICAL DRIVER - DVD REWRITER
GRAPHICS CARD - XFX RADEON HD 5770 XXX 1GB GDDR5 PCI-E 2.0x16
WINDOWS 7 HP (64 bit)
Many advanced thanks for any help received.
Josh.
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Usewr>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Usewr-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection 2:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek 8185 Extensible 802.11b/g Wireles
s Device
Physical Address. . . . . . . . . : 00-11-3B-0F-84-09
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::5c37:33b7:e49b:797f%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.7.3(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 01 June 2010 21:32:54
Lease Expires . . . . . . . . . . : 02 June 2010 21:32:54
Default Gateway . . . . . . . . . : 192.168.7.1
DHCP Server . . . . . . . . . . . : 192.168.7.1
DHCPv6 IAID . . . . . . . . . . . : 419434811
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-13-8D-9F-CE-48-5B-39-A9-F3-C9
DNS Servers . . . . . . . . . . . : 192.168.7.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 48-5B-39-A9-F3-C9
Link-local IPv6 Address . . . . . : fe80::e024:c7c3:c3f2:809b%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.7.2(Preferred)
Lease Obtained. . . . . . . . . . : 01 June 2010 22:14:09
Lease Expires . . . . . . . . . . : 02 June 2010 22:14:09
DHCPv6 IAID . . . . . . . . . . . : 239622969
Tunnel adapter isatap.{164CC753-2235-4BA5-A5BA-7139A2F58FE1}:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:73ba:2c12:31fb:addc:835d(Pref
erred)
Link-local IPv6 Address . . . . . : fe80::2c12:31fb:addc:835d%12(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Reusable ISATAP Interface {6DAA1030-78CC-4B7C-8C14-9C0306DF187E}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter isatap.{80F910B9-B715-4956-B49E-ED4BEE8F645A}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
ASUS P7P55D LE MOTHERBOARD
XFX Radeon
500GB SATAII
I see from your output that you are connected to your router bothe wired & wireless. Unplug the ethernet cable and report back. :)
ATX Custom Build 2012
Windows 7 Enterprise x64 SP1
Intel Core i3-2100 @ 3.10GHz
Intel DH67CL desktop ATX
10 GB DDR3
Asus EAH5450 series (Radeon)
Samsung SyncMaster 226BW, Samsung Syncmaster P2450H
226BW: 1680 x 1050 & P2450H: 1920 x 1080
Western Digital 320 GB sata (boot), Samsung 640 GB sata, Seagate 2 TB sata (data)
Cooler Master Extreme Power Plus 500W
Thermaltake V3 Black Edition
stock cooling with added intake fan
HP Wireless Elite Keyboard Wireless Keyboard
Microsoft Touch
Comcast Cable business class <=18Mb {averages 12Mb}
Optical drives: LG SuperMulti Blue, HP DVD 1260T
Other: Kensington Bluetooth Receiver
Network: Buffalo Wireless N USB, DLink N router/DLink Ethernet Switch/DLink Xtreme N wireless bridge
Printer: HP Photosmart Plus, HP Officejet Pro 8600 Plus
PCs: HP dv6-3040us (7 x64 SP1), HP DM4-2165dx (7 x64 SP1), HP Pavilion zv6130us (7 x86), Apple Macbook Air (Lion)
I am also experiencing the same problem. I can connect to my wireless network without incident. Windows reports a solid connection consistently. But I get about 5 seconds of proper connection and then it just... stops. This will last for a few minutes and then I'll get another 5 seconds of good connection.
Swapping in another wireless card did not help. So it goes back to the store today and the original card is back in its slot. Problem has persisted throughout that process.
It's not just the internet. Connecting to the web-based router configuration screen is also affected. As is connecting to any shared network resources. When your router's web page times out, you know you have problems.
I do not experience this problem with other internet appliances in the house. The Unix laptop, the WinXP laptop and the various smartphones do not exhibit any connection problems. The wired Win7 machine works fine. It's only the Win7 64bit desktop that has the problem.
Homebrew
Win7 Pro 64bit
Intel i7-960
Gigabyte GA-P55A-UD3
4GB OCZ Obsidian DDR3-1600
Sapphire Radeon HD 5870
2 x 17" LG
1920x1280 (x2)
1 TG Western Digitial Caviar Blue 7200rpm
250GB Seagate 7200rpm
Antec 500W
Antec Sonata III
CoolerMaster Hyper 212
Ideazon Mercenary USB gaming keyboard
Logitech Wireless
Cable Modem
D-Link Wireless N Network Card
Rosewill Internal card reader
Welcome to the forum, Darkmage. What anti-virus and firewall are you running?
Home built
Windows 7 Ultimate 32 bit
Intel(R) Pentium(R) 4 CPU 3.00GHz
ASUS P4P800-VM Motherboard Chipset: Intel 865G + ICH5
2.50 GB RAM
NVIDIA GeForce 7600 GS
SoundMax Integrated Digital Audio (Chip)
ViewSonic VX 1962 wm
1680 X 1050
Seagate Barracuda 7200.10 80 GB
ST380215A ATA Device 18.6 GB
Western Digital "My Book" external hard drive 750 GB
Fan based
Microsoft Comfort Curve Keyboard 2000 v10 USB
Logitec optic USB
3.01 Mb/s download 0.64 Mb/s upload
I'm not familior with that particular default gateway. Are you using another type of third party firewall? You didn't mention which brand make and model of router you are using? You may need to disable DHCP on some other device in order to pick up the correct default gateway.
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
GSkill Phoenix Pro 120GB SSD
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
I mentioned somewhere in my giant first post that I only did ipconfig with both connections on, because it may give some insight into the connections working. There is no noticable difference when both connections are running compared to when one is.
Short answer: Tried it. No luck :-(
XFX Radeon
500GB SATAII
I'm not currently using a 3rd party Anti-Virus or firewall. I wanted to get the net working without before going through no doubt more problems. The default gateway was changed to 192.168.7.1 (from 192.168.1.1) due to a suggestion someone on anoher forum made. It seemed to have no effect however.
I shall hunt out the make and model of my router when I get back from work.
XFX Radeon
500GB SATAII
Router is: Netgear WGR614v6
let me know if you need anything else.
XFX Radeon
500GB SATAII
How come your router is outputting the dns address? I think that's your problem.
Windows 7 Pro 64bit build 7601 SP1
Intel Core I5 3570K 3.4Ghz w/ Zalman CNPS9900NT RT
MSI Z77A-G45 Gaming
G.Skill F3-12800CL9D-8GbXL ; 4Gx2
EVGA Geforce GTX 770 Superclocked
Creative Sound Blaster Z
Dual ViewSonic VX2770Smh-LED Black 27"IPS-Panel
Kingston Hyper X 240GB SSD Win8 Pro 64bit 6GB/s Sata III
Intel 335 Series SSD 240GB Win8 Storage 6GB/s Sata III
Intel 320 Series SSD 600GB Storage 3GB/s Sata II
Western Digital Scorpio Black 1TB - Docked via Esata
Coolermaster GX 750W
Corsair Vengence C70
Coolermaster 120mm and Enermax 140mm
Corsair Vengence K70
Logitech G500
22mbps+
Firefox, Chrome, IE
Swan M50W 2.1 speakers
APC UPS
Thermaltake BlacX HDD Dock
Samsung BD Optical Drive
Netgear WNDR4500
I believe that using an incorrect default gateway is the source of your problems. It's obvious that he had you set it up manually which should not be needed. The type of router will determine the correct default gateway you should be using.
For netgear you should be using 192.168.1.1 as the default gateway. I would make sure that DHCP is enabled in your routers control panel and also your network connection properties and perform a reset procedure on your router and see if that changes anything.
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
Just a quick bump as I finished typing.
If my problem is that my router is putting out the DNS address, how could I fix that? Set it to get automatically?
Strange as every other device in my house works fine.
XFX Radeon
500GB SATAII
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
I will try switching back to 192.168.1.1 tonight, but it has also already been tried. I've performed several router reboots over the last couple of days and nothing seems to change. I'm starting to think it may well be an inherent comparability issue with the Wireless card. Is that possible or common?
XFX Radeon
500GB SATAII
Yeah, chev65 laid it. As to how your other computers are getting through I don't know. The router should be set to the default gateway and dhcp. Your computers should be set to automatically obtain an IP address. The DNS server should be coming from your ISP and your computer should also be detecting that automatically.
MSI Z77A-G45 Gaming
Logitech G500
22mbps+
Firefox, Chrome, IE
APC UPS
Netgear WNDR4500
XFX Radeon
500GB SATAII
If this problem is only with one Windows 7 machine then yes it's possible the driver isn't working correctly, although the default gateway was not correct for a netgear router so this could be a router firmware problem.
You can also try to manually enter the correct default gateway 192.168.1.1 into the connection properties window of the problem machine as in the picture below but this step should not be needed.
If this problem is only occuring with a single Windows 7 machine then you might try updating the firmware for your Netgear router because you shouldn't need to enter the default gateway manually using DHCP unless your router isn't working correctly with Windows 7.
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
Well, the good news is that I solved my particular problem. It turned out to be wireless network interference, of all things. Interestingly, it is between my wireless network card and my wireless XBox-like controller for the PC. The wireless dongle thingy makes my connection unbearable.
When I unplug the dongle, all is right with the world. Updating the drivers on the dongle didn't help, so I'll just have to unplug it when I'm doing anything online.
Oh, and thanks for the warm welcome!
Homebrew
Win7 Pro 64bit
Intel i7-960
2 x 17" LG
1920x1280 (x2)
Antec 500W
Antec Sonata III
Logitech Wireless
Cable Modem
Looking at Isrildae's OP... I don't think having the default gateway at any other address than 192.168.1.1 is the problem. One of my older Linksys routers defaulted to 192.168.123.254 out of the box and I never had an issue with it.
If she's connecting with DHCP enabled, I think the best thing to do is just let the router assign the gateway. That way it will give him/her a centralized place to change it.
My first suggestion would be to try and learn from my issue and look for wireless interference problems. Try changing the channel of your wireless network at the router and see if there is a change in behavior.
My 2nd suggestion is to double-check the DNS servers that your router is picking up from your ISP. My ISP's DNS servers are awful and crash occasionally. A quick Google search on "open dns servers" will lead you a list of more reliable & faster DNS servers to improve lookup times. You can assign you router to use those DNS servers instead of the ones your ISP provides. It might help.
If that doesn't cut it, you may wish to try turning of the IPv6 capability on your network connection. (look at chev65's far-left image for where you can disable this for that connection). That might help, but it's a long shot.
Homebrew
Win7 Pro 64bit
Intel i7-960
2 x 17" LG
1920x1280 (x2)
Antec 500W
Antec Sonata III
Logitech Wireless
Cable Modem
I am glad you got your problem solved. Interesting solution. :D
Home built
2.50 GB RAM
1680 X 1050
Fan based
Logitec optic USB
If everything did not work to resolve the issue. A simple system restore to a later date before the problem on the driver occur, can solve the problem.
Acer
Windows 7 home premium
Intel pentium
P6200
2gb
Nvidia
Avg
Google chrome
