Select Items with Check Boxes
    How to Select Items with Check Boxes in Windows 7
    This will show you how to add a check box to Windows Explorer to help make selecting multiple files, folders, or drives at once easier in Windows 7.
    When check boxes is used, you can now just hover the mouse pointer over each item and check the check box to select the item.
    By default, you could select multiple files and folders using keyboard shortcuts.
    To select random multiple files or folders:
    Press and hold the Ctrl key while clicking on a file or folder to select them, then release the Ctrl key when finished.
    To Select everything inbetween two selected files or folders including the selected files and folders:
    Select a file or folder, press and hold the Shift key, click on another file or folder to select them and everything inbetween them, then release the Shift key.
    EXAMPLE: Selecting Items with a Check Box
    OPTION ONE
    Using Folder Options
    1. Open Folder Options, and click on the View tab. (see screenshot below)
    2. To Use Check Boxes to Select Items
    A) Check the Use check boxes to select items box, then click on OK. (see screenshot above)
    3. To Not Use Check Boxes to Select Items
    A) Uncheck the Use check boxes to select items box, then click on OK. (see screenshot below step 1)
    OPTION TWO
    Using a REG File Download
    1. To Use Check Boxes to Select Items
    Turn_On_Check_Boxes_to_Select_Items.reg
    B) Go to step 3.
    2. To Not Use Check Boxes to Select Items
    Turn_Off_Check_Boxes_to_Select_Items.reg
    3. Click on Save, and save the .reg file to the desktop.
    5. Click on Run, Yes, Yes, and OK when prompted.
    6. Log off and log on, or restart the computer to apply.
  1. Posts : 1,158
    Win7 HP (x64)/Win7 Ultimate (x64)
    Thanks for this Shawn.:)
    I figure I have about another 300 years to learn.
    Regards
  2. Posts : 72,052
    You're most welcome Lomai. None of us know everything, and are always learning. :)
