Credential Manager Shortcut - Create
    How to Create a "Credential Manager" Shortcut in Vista, Windows 7, and Windows 8
    Credential Manager allows you to store credentials, such as user names and passwords that you use to log on to websites or other computers on a network. By storing your credentials, Windows can automatically log you on to websites or other computers. Credentials are saved in special folders on your computer called vaults. Windows and programs (such as web browsers) can securely give the credentials in the vaults to other computers and websites.
    This tutorial will show you how to download or create a Credential Manager shortcut that you can pin and use where you like in Vista, Windows 7, and Windows 8.
    EXAMPLE: Credential Manager
    OPTION ONE
    To Download the "Credential Manager" Shortcut
    1. Click/tap on the download button below to download the file below
    Credential_Manager.zip
    2. Save the .zip file to your desktop.
    3. Open the .zip file, and extract (drag and drop) the Credential Manager shortcut to your desktop.
    4. Unblock the Credential Manager shortcut.
    5. In Vista and Windows 7, you can now Pin to Taskbar (Windows 7 only) or Pin to Start Menu, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
    6. In Windows 8, you can Pin to Taskbar on desktop, Pin to Start screen, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
    7. When finished, you can delete the downloaded .zip file if you like.
    OPTION TWO
    To Manually Create the "Credential Manager" Shortcut
    1. Right click or press and hold on an empty area on your desktop, and click/tap on New and Shortcut.
    2. Copy and paste the location below into the location area, and click/tap on the Next button. (see screenshot below)
    %windir%\explorer.exe shell:::{1206F5F1-0569-412C-8FEC-3204630DFB70}
    3. Type Credential Manager for the name, and click/tap on the Finish button. (see screenshot below)
    4. Right click or swipe down on the new Credential Manager shortcut, and click/tap on Properties.
    5. Click/tap on the Shortcut tab, and click/tap on the Change Icon button. (see screenshot below)
    6. In the line under "Look for icons in this file", copy and paste the location below, and press Enter. (see screenshot below)
    %SystemRoot%\system32\Vault.dll
    7. Select the icon highlighted in blue above, and click/tap on OK. (see screenshot above)
    NOTE: You can use any icon that you would like instead though.
    8. Click/tap on OK. (see screenshot below)
    9. In Vista and Windows 7, you can now Pin to Taskbar (Windows 7 only) or Pin to Start Menu, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
    10. In Windows 8, you can Pin to Taskbar on desktop, Pin to Start screen, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
  1. Posts : 2
    A much easier way to create a shortcut to Credential Manager...
    Navigate to Control Panel and select view by: Category within the Control Panel.
    From here select > User Accounts and Family Safety
    Right-Click on Credential Manager Icon and select 'Create shortcut'...Done.
  2. Posts : 72,062
    Hello Duramba, and welcome to Seven Forums.
    Creating that shortcut using that method would be fine, but it doesn't give you the option to Pin to Taskbar and Pin to Start Menu in the shortcut's context menu as the options to create the shortcut in the tutorial do.
    It just depends on what one wants, and I just went with the one that gives the most choices. That's all. :)
  3. Posts : 2
    Great point! I forgot about the "pinning" can of worms. =)
  4. Posts : 72,062
    LOL, and a wiggly can of worms it is. :)
