Screen Saver Password Protection -Enable or Disable
    How to Enable or Disable Screen Saver Password Protection in Windows 7 and Windows 8
    This tutorial will show you how to enable or disable password protection to display the logon screen on resuming from the screen saver in Windows 7 and Windows 8.
    OPTION ONE
    Through Screen Saver Settings for "Current User" Only
    NOTE: This option will only affect the user that you are currently logged in as.
    1. Do step 2 or 3 below depending on what edition of Windows 7 or Windows 8 you have.
    2. For Windows 7 Starter or Windows 7 Home Basic editions
    A) Open the Control Panel (icons view), click on the Display icon, click on the Change screen saver link in the left blue pane, and go to step 4 below. (see screenshot below)
    3. For Windows 7 Home Premium, Professional, Ultimate, Enterprise, and All Windows 8 editions
    A) Right click or press and hold on a empty space on the desktop, click/tap on Personalize, and go to step 4 below.
    NOTE: The Windows 7 Starter and Home Basic editions do not have Personalize included in them.
    4. Click on the Screen Saver link at the bottom right of the Personalization window. (see screenshot below)
    5. To Turn On Screen Saver Password Protection
    A) Check the On resume, display logon screen box.
    B) If You Selected a Screen Saver
    • Select how many idle minutes to Wait before the selected screen saver displays.
    • Go to step 5D.
    C) If You Selected (None) for No Screen Saver
    • Select how many idle minutes to Wait before going straight to the log on screen (Windows 7) or lock screen (Windows 8) without a screen saver displaying first.
    • Continue on to step 5D.
    D) Click/tap on OK. (see screenshot below)
    6. To Turn Off Screen Saver Password Protection
    A) Uncheck the On resume, display logon screen box, then click/tap on OK. (see screenshot above)
    OPTION TWO
    Using a REG File Download for "All Users"
    NOTE: You must be logged in as an administrator to be able to do this option.
    1. For Default Screen Saver Password Protection
    NOTE: If you set it to not configured, then all users on the computer will be able to choose whether or not to set password protection for screen savers in their own user user account.
    A) Click/tap on the Download button below to download the file below.
    Default_Screen_Saver_Password_Protection.reg
    B) Go to step 4.
    2. To Enable Screen Saver Password Protection for All Users
    NOTE: If you enable this setting, all screen savers are password protected for all users on the computer and cannot be changed.
    Enable_Screen_Saver_Password_Protection.reg
    B) Go to step 4.
    3. To Disable Screen Saver Password Protection for All Users
    NOTE: If you disable this setting, then password protection cannot be set on any screen saver for all users on the computer.
    Disable_Screen_Saver_Password_Protection.reg
    4. Save the .reg file to your desktop.
    5. Right click on the downloaded .reg file and click on Merge.
    6. Click on Run, Yes (UAC), Yes, and OK when prompted.
    7. Restart the computer to apply.
    8. When done, you can delete the downloaded .reg file if you like.
    OPTION THREE
    Through Local Group Policy Editor
    2. Browse to User Configuration, Administrative Templates, Control Panel, Personalization, and double click on Password Protect the Screen Saver.
    3. For Default Screen Saver Password Protection
    A) Select (dot) Not Configured, and click/tap on OK. (See screenshot below)
    4. To Enable Screen Saver Password Protection for all Users
    A) Select (dot) Enabled,and click/tap on OK. (See screenshot below step 3)
    5. To Disable Screen Saver Password Protection for All Users
    A) Select (dot) Disabled, and click/tap on OK. (See screenshot below step 3)
    6. Close the Local group Policy Editor, and restart your computer.
    Dinesh.
    Thanks to Shawn for creating the bb codes list. :)
  1. Posts : 72,055
    Updated to include REG file downloads. :)
  2. Posts : 8,476
    Windows® 8 Pro (64-bit)
    Thanks Shawn. :)
  3. Posts : 72,055
    You're welcome Dinesh. :)
  4. Posts : 69
    Windows 7 RC ,Windows Vista Ultimate ,Windows XP SP3,Ubuntu 8.01
    hey thx 4 the info share...
  5. Posts : 8,476
    You are welcome Vasu.
  6. Posts : 6,305
    Nice tutorial man
  7. Posts : 2,651
    W7 RTM Ultimate x64
    Great tut dinesh, very helpful :)
  8. Posts : 8,476
    Thank you Orbital Shark and Uber Philf. I m glad that you guys liked it. :)
  9. Posts : 72,055
    Update:
    Added option one. :)
