System Info - See Your System Specs
How to See Your System Specs with "System Info"
System Info is free Seven Forums program that CyberZeus has kindly made for us. It let's you easily see all of your system information, and has an option to make filling out your system specs here at Seven Forums easier to do.
Here's How:
1. Click on either Download button below to download and save the SystemInfo.exe file to your desktop.
(EXE file)
Download
(ZIP file)
Download
2. Run the SystemInfo.exe file.
NOTE: This is a standalone .exe file that only runs and does not install anything on your computer. If you would like to stop getting the Run prompt, then unblocking the SystemInfo.exe file will stop it.
3. After System Info loads, you will see a summary of your system's information.
NOTE: There's a Edit System Specs link at the bottom right that will take you to your system specs here at Seven Forums.
4. Do either step 5 or 6 below for how you would like to fill out your system specs at Seven Forums.
5. To Automatically Fill Out your System Specs at Seven Forums
NOTE: This step can only be done using Internet Explorer.
A) In System Info, click on Options (menu bar), Settings, select (dot) Automatic Mode, and click on OK. (see screenshots below)
B) Click on the Edit System Spec link at the bottom right corner of System Info. (see left screenshot above)
C) If you are not already, log in to Seven Forums in the new IE Seven Forums' Site window that just opened. (see screenshot below)
D) Click on the Set info button at the top left corner to automatically enter the information from System Info into your system specs at Seven Forums, then click on the Save Changes button at the bottom to save them. (see screenshot below)
6. To Manually Fill Out your System Specs at Seven Forums
A) Clicking on each device icon will give you a pop-up with more detailed information about that device.
B) In System Info, click on Options (menu bar), Settings, select (dot) Manual Mode, and click on OK. (see screenshots below)
C) Click on the Edit System Spec link at the bottom right corner of System Info. (see left screenshot above)
D) You can now use the information in System Info to fill out your system specs at Seven Forums by clicking on the Copy_to_Clipboard.jpg button to the right of a system spec in System Info to copy it to the clipboard, then right click in a system specs field at Seven Forums like below and click on Paste. When finished filling out your system specs, be sure to click on the Save Changes button at the bottom to save them.
Sorry for the long delay.
No - I did not use step 5...I dont use Explorer but Firefox (just DL's FF 31).
Thx
Windows 7 Ultimate Service Pack 1Intel Core i5 2500K @ 3.30GHz Sandy Bridge 32nm8.00GB Dual-Channel DDR3 @ 668MHz (9-9-9-24)1023MB NVIDIA GeForce GTX 550 Ti
custom build
ASUSTeK P8Z68-V LX (LGA1155)
AOC 2416 (1920x1200 pixels); Dell E193FP (1280x1024 pixels)
1920x1200
Boot - ST3200822AS ATA Device
Seagate Barracuda 2 terra SATA II
WD 1 Terra SATA II
WD 640Mb SATA II
550 watt output
Ms
Dell (old)
slow
Comodo Internet Securitry 2013
Firefox 22 (Eng)
That would be why then. Step 5 can only be used in Internet Explorer. Otherwise you'll need to manually copy and paste them. :(
not working, it shows error.
Windows 7 Ultimate x32
it says standalone installer, so will it require internet to install?
It will require the Internet to download.
Exporting
Are the any exporting option with this?
Microsoft Windows 7 Home Premium 64-bit 7601 ...Intel(R) Core(TM) i3-N3054.00 GBStandard VGA Graphics Adapter
LENOVO IdeaPad Slim 3 15IAN8
Oracle Corporation VirtualBox
4.00 GB
High Definition Audio Device
VBOX HARDDISK ATA Device
Hello Wyatt, :-)
If you're using this for the site, you could copy and paste to help make it easier.
Hello Wyatt, :-)
ok. thank you so much. you are truly a big help as well as a lot of others. thx a bunch
4.00 GB
SysSpecsOK-But will they auto-appear in my posts?
Thanks for lucid explication of how to get all specs together - did that.
Now I want to post - are they going to automatically appear in my post(s),
or do I have to do something to make that happen?
Guess I'm about to find out, huh...:o AbbyBoo
Windows 7 Ultimate x64Intel(R) Core(TM)2 Duo CPU T5800 @ 2.00GHz L2...2.00 GBMobile Intel(R) 4 Series Express Chipset Family
Toshiba Satellite A300 64 bit
Intel(R) Core(TM)2 Duo CPU T5800 @ 2.00GHz L2 Cache 2048 KB
Intel
2.00 GB
Microsoft High Definition Audio Device
Generic
1280 x 800
SAMSUNG HN-M500MBB ATA Device
Built in
Synaptics Touchpad v.7.0
104 Mbps
Kaspersky Free; Microsoft Firewall
Firefox 66.0.2 32 bit and no other
Hard disc 114 GB free of 202 GB total; 830 Total available graphics memory. Additional protection:NoScript; HTTPS Everywhere; CCleaner free & Spybot Free v. 2.65.7.0 after every browsing session; Zemana Antimalware.
Sys Specs as instructed WORKS
Thank you! Non-problem solved.:D
Intel
2.00 GB
Generic
1280 x 800
Built in
104 Mbps
