Page 21 of 91 FirstFirst ... 11192021222331 ... LastLast
  1. foo
    Win 7 Pro 64-bit
       #200
    Awesome. A few of these came in handy. Had to register & say thanks!
  2. Posts : 72,055
       #201
    You're most welcome Foo, and welcome to Seven Forums. :)
  3. Posts : 1
    Windows 7 Home Premium 32bit
       #202
    Great solutions. Thank you so much....
  4. Posts : 72,055
       #203
    You're most welcome Melon, and welcome to Seven Forums.
  5. Posts : 1
       #204
    Just registered to say thank you so much, Brink; it did work for my ASUS UL20A. All the applications run again now. There is still one problem remained though: the applications' default icons are still missing, with just a blank white folder-shape image shown for every program. Please help with a tip how to restore them.
    Many thanks again.
    Ben
  6. Posts : 72,055
       #205
    You're most welcome Ben, and welcome to Seven Forums.
    What applications have a missing icon (all or certain ones)?
    If all, then you might download and merge the EXE option in this tutorial on the first page. You might also rebuild the icon cache to see if that may help. :)
  7. Posts : 1
    Windows 7 home premium 32 bit
       #206
    how to disable a file extension in windows 7 in default program option
    Thanks a Lot 4 the above post.
    i want u to include .bak file extension.
    whenever i used to open .bak file it open with adobe .
    so how can i remove .bak file in my default setting option.
    Or i use your file association method to resolve my problem????
    Pls Help me in this regard....
  8. Posts : 72,055
       #207
    Hello Lulum, and welcome to Seven Forums.
    I have added bak to the list for you. It will remove all associations for bak to restore it to default after the restart. :)
  9. Posts : 12
    Windows 7 Ultimate x86
       #208
    Thanks a lot Sir Shawn. God bless you. This saved me from reformatting my system after updating windows 7 sp1 bug. :)
    Windows 7 Service pack 1 update bug
  10. Posts : 72,055
       #209
    You're most welcome Debugger. :)
