Start Menu Auto Arrange by Name - Enable or Disable
    How to Enable or Disable Start Menu Auto Arrange by Name in Vista and Windows 7
    This will show you how to enable or disable auto arrange to sort all programs menu by name or sort listed programs and program folder menus how you like in the Pin to and All Programs areas of the Start Menu for your user account in Vista and Windows 7.
    EXAMPLE: Auto Arrange Disabled in Start Menu "Pin to" and "All Programs"
    NOTE: Notice in the screenshots with Auto Arrange disabled, the listed programs and program folders can be dragged to be sorted how you like without having to be in alphabetical order.
    Start Menu Auto Arrange by Name - Enable or Disable-pin-.jpgStart Menu Auto Arrange by Name - Enable or Disable-all_programs.jpg
    OPTION ONE
    Enable or Disable Start Menu Auto Arrange in "Customize Start Menu" Properties
    1. Open the Customize Start Menu properties window, then do step 2 or 3 below for what you would like to do. (see screenshot below)
    2. To Enable Auto Arrange by Name in Start Menu
    A) Check the Sort All Programs menu by name box, and click on OK. (see screenshot below step 1)
    3. To Disable Auto Arrange by Name in Start Menu
    A) Uncheck the Sort All Programs menu by name box, and click on OK. (see screenshot below step 1)
    OPTION TWO
    Enable or Disable Start Menu Auto Arrange using a REG File Download
    1. To Enable Auto Arrange by Name in Start Menu
    Enable_Start_Menu_Auto_Arrange_by_Name.reg
    B) Go to step 3.
    2. To Disable Auto Arrange by Name in Start Menu
    Disable_Start_Menu_Auto_Arrange_by_Name.reg
    B) Go to step 3.
    5. If prompted, click on Run, Yes (UAC-Windows 7) or Continue (UAC-Vista), Yes, and OK.
    6. When done, you can delete the downloaded .reg file if you like.
  1. Posts : 178
    Windows 7 Home Premium Service Pack 1 32-bit Build 7601
    Great tutorial. Thank you.
