Recent Programs - Turn On or Off
    How to Turn Recent Programs On or Off in Windows 7
    Recent Programs saves and displays file names, programs, and locations you type in the Run dialog box and a list of your recently opened programs on the left white side of the Start Menu below the Pinned Programs line.
    This tutorial will show you how to turn Recent Programs on or off in Windows 7.
    If you have a progam pinned to the Start Menu, then it will not show up in the recent program area below the pin to area in the Start Menu.
       Warning
    Unchecking the Store and display recently opened programs in the Start menu box in step 3 below will also cause the Run command dialog box to clear and no longer save it's run program history.
    EXAMPLE: Recent Programs in the Start Menu
    OPTION ONE
    To Turn Recent Programs On or Off in Start Menu Properties
    1. Right click on the Start button, and click on Properties.
    2. To Turn Recent Programs On
    A) Check the Store and display recently opened programs in the Start menu box. (See screenshot below step 4)
    B) Go to step 4.
    3. To Turn Recent Programs Off
    A) Uncheck the Store and display recently opened programs in the Start menu box. (See screenshot below step 4)
    NOTE: See warning at top of tutorial.
    4. Click on OK. (See screenshot below)
    OPTION TWO
    To Turn Recent Programs On or Off using a REG File Download
    1. To Turn Recent Programs On
    Turn_On_Recent_Programs_in_Start_Menu.reg
    B) Go to step 3.
    2. To Turn Recent Programs Off
    Turn_Off_Recent_Programs_in_Start_Menu.reg
    3. Save the .reg file to your desktop.
    4. Double click on the downloaded .reg file to merge it.
    5. Click on Run, Yes (UAC), Yes, and OK when prompted.
    6. When done, you can delete the downloaded .reg file if you like.
  1. Posts : 3
    Brink,
    I attempted to use Method Two from within my own Batch script. In my script I use the REG utility to import the registry files above. My goal is to clear the Recent Programs list. So the script imports the Off registry file first then kills and restarts explorer.exe. The script then imports the On registry file. The list never clears. During my debugging of my script I manually ran each import from the command line to make sure import was performed correctly. I found that by opening up the Registry Editor after importing the Off registry file that the list cleared. It's as if the registry was reloaded/refreshed when the editor was launched. Do you know of a way to do this via the REG utility such that I can force a rereading of the registry before turning the Recent Programs feature back on?
    Thanks,
    Paul
  2. Posts : 72,089
    Hello Paul, and welcome to Seven Forums. :)
    You might see if using the "sleep" command to wait a bit or restart explorer command after the off .reg before doing the on .reg may work better. It sounds like it's getting turned off and back on too fast to apply clearing them.
  3. Posts : 3
    Brink,
    Thanks. My script imports the Off .reg, kills explorer, "sleeps" 5 seconds, starts explorer then imports the On .reg. I'll try putting a "sleep" after the restart of explorer but prior to the import of the On .reg.
    Thanks,
    Paul
  4. Posts : 3
    Brink,
    That worked. Thanks for the help!
    Regards,
    Paul
  5. Posts : 72,089
    Great news Paul. I'm glad it could help. :)
