Control Panel - Add or Remove "Services"
    How to Add or Remove "Services" from Control Panel in Windows
    This will show you how to add Services to the Control Panel for all users in Vista, Windows 7, and Windows 8.
    EXAMPLE: "Services" added to Control Panel
    NOTE: This is the Control Panel icons and category view.
    EXAMPLE: Services
    Here's How:
    1. To Remove "Services" from Control Panel
    A) Click/tap on the Download button below to download the file below.
    Remove_Services_from_Control Panel.reg
    Download
    B) Go to step 3.
    2. To Add "Services" to Control Panel
    Add_Services_to_Control Panel.reg
    3. Save the .reg file to the Desktop.
    4. Double click/tap on the downloaded .reg file to Merge it.
    5. Click/tap on Run, Yes, Yes (UAC-Windowws 7/8) or Continue (UAC-Vista), and OK when prompted.
    6. When finished, you can delete the .reg file if you like.
  1. Arc
    Nice tutorial Shawn Now access to services will be comparatively easier
  2. Posts : 72,052
    Thank you Archie. :)
  3. Posts : 5,956
    Win 7 Pro x64, Win 10 Pro x64, Linux Light x86
    That is very useful, thank you Shawn
  4. Posts : 72,052
    You're welcome Stephanie. Glad it could help. :)
