Page 33 of 43 FirstFirst ... 233132333435 ... LastLast
  1. Posts : 72,164
       #320
    pwashington said:
    My hard drive is gone. I bought a new one, but now I need a copy of windows 7. I have the Key code on the bottom of my laptop. Does any one know were I can get a copy of windows 7 from the Internet. This was the orginial OS on the laptop and plus I have the code and someone said that I can download it and create a ISO DVD.
    Hello Patrick,
    You can download a Windows 7 ISO file at link in the yellow tip box under OPTION ONE. :)
  2. Dom
    Windows Seven Ultimate
       #321
    If anyone would be so kind as to confirm whether a formatted external HD would work too? I am aware installation will be slower but it would be useful
  3. Posts : 18,415
    windows 7 home 64bit
       #322
    Hi Dom .... I found it to be unreliable works on some systems ..
  4. Dom
       #323
    I'll give it a go anyway
  5. Posts : 18,415
       #324
    Sure it worked for me on this Laptop i am using ... So could well work for you :)
  6. Posts : 21,004
       #325
    As Max said it can be done mate but make sure you really check it thoroughly afterwards as the partitions do get a bit muddled.
    If it were me I would be doing a clean all on the drive beforehand as they have their own software crap on a lot of them. Still that is just me being pedantic and maybe a bit OCD LOL!! but at least you will have blank drive to start with after formatting it of course:)
  7. Dom
       #326
    I've went ahead and done it, all seems well! Booted into Windows. Now all I need to do is connect to the internet and download some drivers.
  8. Posts : 18,415
       #327
    Great news well done Dom
  9. Posts : 5
    windows 7 home premium 32bit
       #328
    After typing diskpart into cmd prompt, it does not allow me to type anything else. What could be the issue?
  10. Posts : 21,004
       #329
    Hello and welcome Zaka mate try these
    https://www.sevenforums.com/tutorials/1538-sfc-scannow-command-system-file-checker.html
    https://www.sevenforums.com/tutorials/433-disk-check.html
