Page 13 of 43 FirstFirst ... 3111213141523 ... LastLast
  1. Posts : 72,116
       #120
    Bob,
    I was starting to think that was the problem. I'll add an addition to that step for fat32. What is the storage size on the USB drive?
  2. Posts : 14
    Windows 7 ultimate
       #121
    Hi Shawn 8GB
    Regards
    Bob
  3. Posts : 72,116
       #122
    Umm, I'm not sure why it wouldn't let you format it as NTFS, but FAT32 will do just as well.
  4. Posts : 14
    Windows 7 ultimate
       #123
    Hi Shawn everything went ok but it would not install on my Dell Inspiron 545 MT. It recognised it in boot menu as generic usb flash drive and I selected it. Now I'm thinking it is just the flash drive itself.
    Regards
    Bob
  5. Posts : 14
    Windows 7 ultimate
       #124
    New usb flash drive
    Hi Shawn I purchased a new 8GB Corsair Flash Voyager and no problems this time even formatted to NTFS.
    Thanks Shawn
    Bob
  6. Posts : 72,116
       #125
    That's great news Bob. Well, at least you can still use the other one with FAT32 at boot. :)
  7. Posts : 21
    Windows 7/ Windows XP/ Mac OSX Snow leopard
       #126
    This wont work in XP
    Hello mates i tried alot but failed to make pen drive bootable but failed. This is coz diskpart in xp doesnt recognize usb key as disk so no chance in hell thats what you got but still i found a video on the web telling how to create a bootable usb in xp
    VIDEO
  8. Posts : 3
    Win7
       #127
    Bootsage flash drive builder
    While Diskpart doesn't support removable drives under XP, there are applications which simplify this process. I use the freeware app BootSage as it does most of the work for me (and works under XP), but there are other apps which can further customize the flash drive.
  9. Posts : 662
    Windows 7 Home Premium x64, Mac OS X 10.6.2 x64
       #128
    Any way to lock the USB from being written to after doing this? And would this work for the AIO image I made?
  10. Posts : 72,116
       #129
    Hello Michael,
    You would need to have some sort of 3rd party write protection program installed on the USB stick to prevent it from being written to on any computers. Some USB sticks come with this software.
    I'm afraid that I do not know what program is for a AIO image, or if it will work or not.
