System Image - Extract Files Using Disk Management
How to Extract Windows 7 System Image Files Using Disk Management
When you create a system image, Windows 7 creates a Virtual Hard Disk VHD file that contains all of your files. This will show you how to attach (mount) this VHD file using Disk Management to manually extract and restore specific files of your choice from the system image instead of doing the default full system image recovery.
System images are saved in this format:
(selected backup location's drive letter)\WindowsImageBackup\(your computer name)\Backup (year-month-day) (time-hhmmss)
For example, if your computer name is Windows7-PC, your backup image location is on hard disk or partition (network or local) D: , and you backed up on September 14th 2008 at 4:39:45 AM (it uses 24 hour time), then that system image VHD file will be located in the D:\WindowsImageBackup\Windows7-PC\Backup 2009-09-14 043945 folder.
OPTION ONE
To Attach the VHD to Extract Files from System Image
1. Open the Control Panel (icons View).
A) Click on the Administrative Tools icon, and click on Computer Management.
B) Go to step 3.
OR
2. Open the Start Menu.
A) In the Search box, type compmgmt.msc and press Enter.
3. If prompted by UAC, then click on Yes.
4. In the left pane, right click on Disk Management, and click on Attach VHD. (See screenshot below)
NOTE: You can also click on Disk Management, Action on the menu bar, and Attach VHD.
5. Click on the Browse button. (See screenshot below)
6. Navigate to the drive or partition that you selected to save the created system image to, then select a listed VHD file for the disk that you want to extract files from. (See screenshot below)
NOTE: See the NOTE box at the top of the tutorial to see where to find your system image VHD file at.
There will be a VHD file for each hard disk that was included in the system image backup when it was created.
You will not be able to open the VHD for the 100 MB System Reserved partition if you had one created during the installation of your Windows 7.
7. Click on OK. (See screenshot below)
NOTE: Be sure to leave the Read only box unchecked if you wish to have more than read-only access.
8. You will now notice that the VHD file has been attached (mounted) as a separate virtual disk with it's own drive letter (ex: F: ) in Disk Management. Close Disk Management.(See screenshot below)
9. You may also get a AutoPlay pop-up window. Double click on the Open folder to view files option. (See screenshot below)
NOTE: If you did not get a AutoPlay pop-up, then you can open the new attached VHD virtual disk (ex: F) from the Computer window like any other hard drive or partition.
10. You can now copy any files that you want from the attached system image VHD disk (ex: F: ) to restore back to your Windows 7 C: drive. (See screenshot below)
OPTION TWO
To Detach the VHD in Disk Management
NOTE: This will show you to detach the VHD file in Disk Management from OPTION ONE above without affecting the system image.
B) Go to step 3.
OR
4. In the middle pane, right click on the Disk # of the attached VHD (ex: F: ), and click on Detach VHD. (See screenshot below)
5. Click on OK. (See sreenshot below)
WARNING: DO NOT CHECK the Delete the virtual hard disk file after removing the disk box. If you do, you will destroy the created system image. Leaving this box unchecked will leave your created system image intact an unharmed so you can still be able to use it to do a full system image recovery.
6. You will now notice that the VHD (ex: F: ) has been detached in Disk Management. (See screenshot below)
7. Close Disk Management.
Did you manage to pick up any Vista backup images in the same way?
It should work with those too.
Nice tut as always.
    7 X64i5 84002x8gb 3200mhz
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    pure power 11 400w cm
    Coolermaster
    cryorig m9i
    7x64g54008gb ddr4 2400
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
Well, while Vista does not have the option to attach a VHD file like this, you should be able to do this from within Windows 7 to extract files from a Vista system image though.
Another fine tutorial Thank you.
Vista Ult64, Win7600Intel Core 2 Quad Q6600 @ 2400 MHz 64bit OS4096 MB DDR3-SDRAMATI Radeon HD 3870 Series x2 Crossfired
Self Build 64bit
4096 MB DDR3-SDRAM
Realtek on board
My Book 1 TB external..
Cooler Master 1000w
Cooler Master Cosmos 1000.
Fans and fresh air,
Wireless
Wireless
Never fast enough
I use a Magnum.
Thanks Shawn , yes that's what I meant. May be useful for those who have both installed.
You have always been able to do it in Vista ( not natively - you need to use Virtual PC ).
That's why I figured you could easily pick up 7 backup images (and probably Vista ) using 7 create vhd function.
Is there a tut on VF about doing that with VPC ?
As if you aren't busy enough already, LOL.
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
Very nice, but....
I notice it doesn't work too well (at all) if you select read only.
windows 7 64bit
windows 7 64bit
Hello Jdop, and welcome to Seven Forums.
What do you mean and are referring to? :confused:
Fantastic tut, Brink. I've read lots of your tutorials on the Vista side and now the Windows 7 side and have learned a lot from them.
Sorry I haven't posted on the worthiness of them before now. Just one of my many failings. :-)
Thanks again.
Windows 10 HomeIntel Core i5 3550Corsair Vengeance DDR3 16GBNvidia GEForce GTX 970 SSC
Self build
Windows 10 Home
Intel Core i5 3550
ASUS P8Z77-V LX (LGA1155)
Hanns-G 23.6", Acer 17"
1920x1080, 1440x900
Sandisk SSD 256 GB
WD500GB
WD640GB
Seagage Ultra + 1TB ext.
BWD 800GB
WD 1TB ext
Antec 650w
Cooler Master Centurion 534
COOLER MASTER GeminII S524, 3 120 mm case fans.
Logitech MK300
Logitech MK300
Cable
MSSE, Malwarebytes
IE 10, Chrome
You're most welcome Cato, and welcome to Seven Forums. :)
Very cool Brink!
I soon will try it ;-)
Thanks!
zx81
Windows 7 Home Premium x64Intel 1720 Core 2 Duo 2.00GHz,800,2M4GB 667MHz DDR2 SDRAM (2x2048)NVIDIA Geforce Go 8600M GT 256MB DDR2
Dell Inpspiron 1720
SigmaTel
17.0" Widescreen WXGA+ (1440x900) TFT with TrueLife
2x160GB 5400RPM Serial ATA
What he meant was what I just tried :)
When I attached the VHD, (see attachment), there is a Read Only option (I circled it in red). I wanted to be sure that I could still use the system image as a system image if I ever had to restore my system. But when I do, it mounts as an unformatted drive. I had to unmount it, make sure Read Only was not checked, then it simply worked.
Do you (or anyone) know/tested that a system image does infact work after mounting it as a VHD? (Not making any changes to it, of course.) Because I think I remember, while doing some research on Win 7 before I got it, that if you messed with the windows system restore image file, it could never again be used as a system restore...
Windows 7 x64 UltimateCore I712 GBGTX 275
Core I7
12 GB
GTX 275
Hello Sabre,
I have not tested it, but as long as changes were not made to the VHD, it should still be able to be used to restore the image with.
even though the fix described above didn't work for me, it pointed me in the right direction until I found a solution for why my Win7 repair function couldn't find any image files. Here's what didn't work after my SSD boot disk failed and I re-installed Win7-64 bits, giving it the same computer name that I had originally chosen (win7-64):
* Opening the image files and copying them to C:\ - many open files prevented copying, as noted by someone in the thread
* booting up to WinXP and copying the files; some still wouldn't copy - with error message of "access not permitted" or some such.
* booting up in Linux (Ubuntu 9.04) and copying the files. All files copied to my Win7 boot partition, but still, after booting, my Win7-64 wouldn't open any of the dozens of programs that I had installed during the 4 months since I started using it. Hundreds of hours of my time down the drain? No . . .
After copying the files to C:\, I found that the repair function of the Win7 installation disk suddenly was able to see my images. I chose the latest and, after waiting for it to copy 91,000+ files, I'm now using that OS to write this. Joy!
I still have no idea why it couldn't see those image files previously. No matter - now I'm going to test the free BartPE image creation/recovery program that I've used with such success for several years with WinXP; I presume it will be more reliable than this questionable M$ backup system.
win7-64bitq66008gbasus nVidia 9600GSO
my own assembly
win7-64bit
q6600
asus p5b
8gb
asus nVidia 9600GSO
24" Dell 2305
Corsair
Arctic cooling
Thanks for these instructions
This is great. Exactly the information I needed in clear and very understandable steps. Thank you. This saved my evening.
Window 7 x64
Window 7 x64
You're most welcome Vavrajj, and welcome to Seven Forums. :)
Thanks Brink. A wonderful tut that worked great and made the family happy with a lot of recovered music and photos. Thanks again. :geek:
Flysjet
Windows 7 64Intel Quad4 Gig DDR2Two Sapphre HD2600 XT Crossfire configeration
Home built
Windows 7 64
Intel Quad
Gigabyte X38-DQ6
4 Gig DDR2
Samsung
2 WD Caviar Blue in a Raid 0
LIAN LI
Four case fans, one power supply fan, one CPU fan
MS Natural Egronomic 4000
Logitech Laser USB
You're most welcome Flysjet. I'm happy to hear that you were able to recover your music and photos. :)
This is a very good tutorial. I just saw it for the first time. Thanks Brink. But it is really unfortunate that MS makes us jump thru all those hoops to look at our data. I now know why I will stick with Macrium.
