Partition or Volume - Create New
Page 18 of 48 FirstFirst ... 8161718192028 ... LastLast
  1. whs
       #170
    1. It might be safe to delete this partition since it would be anyhow far too small for a data partition.
    2. That SYSTEM partition you better leave alone. It may contain the master boot record.
    3. I have made a 12 minute video how to deal with creating and deleting partitions - have a look.
  2. Posts : 72,116
       #171
    yurhi said:
    thanks guys...
    But the problem is that I just got last sunday the laptop, i havent done anything to it yet and it is a HP as you can see in the first picture. a windows explore screen shows that I have 3 primaries partitions:
    1-local disk
    2-recovery
    3-hp-tools
    and the second screen shows that I have 4 primaries partitions
    1-local disk
    2-hp-tools
    3-recovery
    4-SYSTEM
    all those 4 partitions already came in the laptop, cause the windows 7 was already installed.
    my questions are:
    1- Can I just CUT what is inside of the Hp-tools partition and COPY to the Recovery partition and then use this partition for all my files and rename the partition later on ?
    2- What the heck is the SYSTEM partition, can I just delete that ?
    3-Please, can you give me step by step tutorial to help me be able to create more partitions ?
    Thank you very much !
    Yurhi,
    You can create yourself a set of HP Windows 7 recovery disks to use to restore your computer back to a factory installation of Windows 7 instead of using the partitions. One disc will be a "Windows 7 Recovery Disc" and the other a "Applications and Drivers Disc". The link below from HP will show you how to using the HP Recovery Manager.
    Using HP Backup and Recovery Manager in Vista - HP Customer Care (United States - English)
    Afterwards you can delete the Recovery D: and HP_Tools E: partitions. Afterwards, you should be able to create a new partition with the unallocated space left.
       Warning
    Be sure to create a set of Windows 7 Recovery discs before you delete these partitions. If you do not, you will have no way of reinstalling Windows 7 again.
  3. Posts : 2
    Win 7
       #172
    shrink volume limit unavailable
    The shrink volume limit is not avaialble in my system. Also mine is a 220 GB hard Disk out of which my data is 40GB. But the free space avbl is only 120 gb.
    How do i partition my drive?
    How do i get that extra space?
  4. Posts : 72,116
       #173
    Hello itsmesir, and welcome to Seven Forums.
    Could you post a screenshot of your Disk Management showing your drive layout? This will help us determine what may be happening.
  5. Posts : 2
    Win 7
       #174
    disk management screen shots
    Have attacehd the disk management screen shots. I am allowed to shrink only 203mb of the total.
    Attached Thumbnails Attached Thumbnails Partition or Volume - Create New-dm-ss1.jpg   Partition or Volume - Create New-dm-ss2.jpg   Partition or Volume - Create New-dm-ss3.jpg
  6. Posts : 72,116
       #175
    Itsmesir,
    Since the C: drive will have allocated space for items like the page file, restore points, etc..., this will limit the amount of free space available on that partition.
    Disk Management is limited to what it can do, so you might try the free Partition Wizard Home Edition to see if it may allow you to shrink the C: drive more for you.
  7. whs
       #176
    This is a little unusual because it normally lets you shrink about half of the space (mainly because of the MFT sitting in the middle of the partition). But in your case, there may be a problem (as Brink says) with the shadowstorage (restore points). That cannot be seen from the Disk Management shots. I suggest you go into elevated Command Prompt and run the vssadmin list shadowstorage command. Look for the number associated with allocated - if that is excessive (e.g. more than 10 to 15% of the partition space), you may want to reduce the shadowstorage size. After reduction (which would delete all your current restore points), you can try your luck again with Disk Management.
    System Protection - Change Disk Space Usage
  8. Posts : 101
    w7
       #177
    Reason MS places the MFT where it does????
    After reading through this informative thread about the cycle of steps needed to reduce the C partition I was wondering-
    what is the reason Microsoft puts the Master File Table (MFT) where it does on the C partition???
    If there is a good reason, is there any possible risk to moving it through successive shrinking required to get the C Partition down to a smaller size??
    Thanks for your help!!
  9. Posts : 3
    WINDOW 7 HOME PREMIUM
       #178
    Hi everyone, I am new here.
    I use this "Quick Reply" as I can't find where should I post my problem.
    I bought a brand new Acer Aspire 5740G with Window 7 Home premium installed.I want to have dual boot feature with Linux distro Mandriva 2010.
    Thus , I want to use existing "Disk Management" to shrink my C drive to create an extra primary partition(G drive: Data & Linux) of 200GB . And then I will further shrink this G drive to create a 20GB unallocated partition for later Linux OS Mandriva installation, to achieve dual boot feature.
    My issue is I can't get a primary partition G drive after shrinking C drive. It gives me logical drive in G drive which I worry not suitable for later Linux OS installation. Is this statement of Linux OS must use contagious primary partition, true?
    Attached pls find the original disk situation(before shrinking),
    after shrinking
    and after formatted screenshots.
    Appreciate any help or advice , all are welcome.
    Thank You.
    Best rgds.
  10. whs
       #179
    An NT based OS would work on a logical drive because the BCD ( boot configuration data ) would be written into the root of your boot drive. I think the same is true for the Grub - but I am not 100% sure.
