Make bootable iso from student d/l
Page 16 of 69 FirstFirst ... 6141516171826 ... LastLast
  1. Posts : 7
    Windows 7 Pro 64 bit
       #150
    gregnied said:
    kk, I keep doing post 1 exactly how it say and I still get an error when attempting to make the ISO.
    first this is what is being entered
    Oscdimg.exe –u2 –bC:\Users\Greg\Desktop\expandedSetup\boot\etfsboot.com –h C:\Users\Greg\Desktop\expandedSetup C:\7.iso
    these are the errors it gives me
    ERROR: Could not delete existing file "ûbC:\Users\Greg\Desktop\expandedSetup\boot\etfsboot.com"
    Error 123: The filename, directory name, or volume label syntax is incorrect.
    any help would be greatly appreciated.
    EDIT: if it matters I am using XP Pro 32 bit
    Try this:
    oscdimg.exe –u2 –b"C:\Users\Greg\Desktop\expandedSetup\boot\etfsboot.com" –h C:\Users\Greg\Desktop\expandedSetup C:\7.iso
    Added quotation marks.
  2. Posts : 12
    windows 7
       #151
    So has anyone actually upgraded from Windows 7 RC 32bit to Windows 7 Home Preimum? If so, how?
    This is the error I get:
    Windows Setup
    This installation disc isn’t compatible with your version of Windows. To upgrade, you need the correct installation disc. For more information, check your computer’s system information. To install a new copy of Windows, restart (boot) your computer using the installation disc, and then select Custom (advanced).
    OK
    I feel like I am in a catch 22. I can't upgrade off my Windows 7, and if I boot installation then I would my product key input wouldn't work. So I have to re-install Vista and then upgrade windows 7.
  3. Posts : 8
    Vista
       #152
    Windows 7 Student Edition
    Im sure the forumn has been littered with these today but I didnt see any helpful ones. I use Vista 32 I bought the W7 64. Digitalriver is the online company I purchased the product from they claimed you would be able to do a clean install loosing all previous information, which Im fine with. However they sent only an exe which a 32 bit system cannot open with out a disk. To make matters worse they did not include an ISO so you could burn it to a Disk. Any solutions as to making an ISO?
  4. Posts : 1
    Windows XP
       #153
    I've gotten everything to work and burned the .iso to a dvd. When i boot from the dvd it goes into the Starting Windows thing and loads and all, but when I get to the part with the blue and green background (where you can see your mouse for the first time) nothing ever loads. I can move my mouse around so I know my computer isn't freezing, but no menus or anythign come up.
    Does anyone know have any idea what is causing this problem?
  5. Posts : 20
    Windows
       #154
    ghettobanjo said:
    ok so has anyone been successful burning the ISO, formatting and then installing?? From what I have read, if you format first, then the product key will not work
    This is false. I successfully burned the image, wiped the harddrive, and installed.
  6. Posts : 12
    windows 7
       #155
    Hold on, I don't think that statement is false. Did you boot from disc when the computer started or did you boot in windows?
  7. Posts : 7,878
    How big was this EXE file, what was the name?
  8. Posts : 8
    Vista
       #157
    ANy one able to tell me how to first establish the ISO???
  9. Posts : 12
    windows 7
       #158
    Read the first post?
  10. Posts : 8
    Vista
       #159
    Yeah but it just save in the folder or what I followed the first post and it uploaded but I couldnt find it any where?????
