Speccy - Advanced System Information Tool
Page 2 of 2 FirstFirst 12
  1. Posts : 5,915
    Windows 10 Pro X64
    Nice tutorial andrew. I would add a tip for users to set it to C when using for specs to receive advice.
  2. Posts : 4,566
    Windows 10 Pro
    It actually does do this automatically. C is the default. I set it to f as I prefer F but I have started using c and changed it to c recently.
  3. Posts : 4,566
    Windows 10 Pro
       #12
    Speccy has updated:
    • v1.24.632 (14 Nov 2013) - Added USB storage device detection.
      - Improved CPU and motherboard temperature reading accuracy.
      - Added option to skip User Account Control warning.
      - Added ability to refresh Speccy data.
      - Added option to start Speccy with Windows for temp monitoring.
      - Enhanced hard drive information to include sector and track data.
      - Added scriptable parameters for XML and TXT data export (professional edition only).
      - Improved network adaptor detection.
      - Improved debug mode notification.
      - Minor bug fixes and GUI improvements.
  4. Posts : 9,600
    Win 7 Ultimate 64 bit
    andrew129260 said:
    Speccy has updated:
    One caution about using Speccy for temperature monitoring: it may not play well with some programs. I know for a fact it will not play well with Macrium Reflect (and I had the BSODs to prove it). Speccy is an excellent program that I use frequently and I strongly recommend it but a bit of caution must be used when running it.
  5. Posts : 4,566
    Windows 10 Pro
       #14
    I suppose its possible, I personally never had a problem with it, and I have over 200 different programs installed.
    Granted I dont use all of them at once, haha. But I have never had a bsod running many programs with speccy turned on and in the tray.
    Who knows, maybe with this update things might work for you.
    Why use Macrium Reflect anyway? I don't understand whats so bad about windows 7 built in imaging. To each his own I guess. I heard whs say there is major issues with it, bit I never experienced any.
    Am I just lucky with everything? Idk...
    I guess in the end its just all opinions honestly.
  6. Posts : 9,600
       #15
    Reflect is easier to use, more versatile, and more reliable than Win 7's backup utility.
  7. Posts : 6,458
       #16
    Below the line is my Speccy "post template".
    A warning is insufficient regarding keys presented in screen shots or text reports.
    PUBLISH a snapshot automatically removes sensitive information and hosts the output on a Piriform server.
    The member only has to copy the link returned and post it on their thread.
    I recommend that you change Step 4
    Click "File-save as text file"
    to
    Click "Publish Snapshot..."
    Feel free to use anything below, if that helps.
    Please post the following system information: Speccy snapshot
    How to publish a Speccy snapshot:
    Click on the Speccy file menu and select Publish Snapshot. This method removes sensitive information and provides you with a link to the report.
    Copy the link returned from Publish Snapshot and paste it in a post on this thread so members have more information to better assist you.
    Published Speccy report of my machine: http://speccy.piriform.com/results/CHlegp43qppad1Ua8dOLDAj
  8. Posts : 19,383
       #17
  9. Posts : 6,458
       #18
    Thanks Reverend,
    Can that be added to Related links on this tutorial?
  10. Posts : 72,078
       #19
    Done. :)
