Drive Letters - Show Before or After Name in Computer
Page 1 of 4 123 ... LastLast
    How to Show Drive Letters Before or After Drive Name in Vista, Windows 7, and Windows 8
    This will show you how to have drive letters in the Computer or This PC show before or after the drive name in Vista, Windows 7, and Windows 8.
    EXAMPLE: Drive Letters Before and After Drive Name in Computer
    OPTION ONE
    Using a REG File Download
    1. To Show all Drive Letters After the Drive Name for All Users
    NOTE: This is the default setting. This will override steps 2 and 3.
    Show_Drive_Letters_After_All_Users.reg
    B) Go to step 4.
    2. To Show all Drive Letters Before the Drive Name for All Users
    NOTE: This will override steps 1 and 3.
    Show_Drive_Letters_Before_All_Users.reg
    B) Go to step 4.
    3. Show all Drive Letters Before Drive Name for Only Current User (you)
    NOTE: This step will be overridden by step 1 or 2 above.
    Show_Drive_Letters_Before_Current_User.reg
    4. Click on Save, and save the .reg file to the desktop.
    5. Right click on the downloaded .reg file and click on Merge.
    6. Click on Run, Yes, Yes, and OK when prompted.
    7. Log off and log on, or restart the computer to apply.
    8. When done, you can delete the downloaded .reg file if you like.
    OPTION TWO
    Manually in Registry Editor
    1. Press the Windows + R keys to open the Run dialog, type regedit, and press Enter.
    2. If prompted by UAC, click on Yes in the UAC prompt.
    3. For Only Current User (you)
    A) In regedit, navigate to the locations below.
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer
    B) Do either step 5 or 6 for what you wanted to do.
    4. For All Users on the Computer
    A) In regedit, navigate to the locations below. (see screenshot below)
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer
    5. To Show the Drive Letters Before the Drive Name
    A) In the right pane, right click on a empty area and click on New and DWORD (32-bit) Value. (see screenshot above)
    B) Type ShowDriveLettersFirst and press Enter. (see screenshot below)
    C) Right click on the ShowDriveLettersFirst and click on Modify. (see Screenshot above)
    D) Type the number below for what you want, and click on OK. (see screenshot below)
    • 1 = Drive letters displayed first for remote drives only.
    • 4 = Drive letters displayed first for all drives.
    E) The registry will now look like this. (see screenshot below)
    F) This step depends on if you did step 3 or step 4 above.
    • If you did step 3, then be sure to also do step 6 at the step 4 location.
    • If you did step 4, then be sure to also do step 6 at the step 3 location.
    G) Go to step 7.
    6. To Show all Drive Letters After the Drive Name
    A) Right click on the ShowDriveLettersFirst (if available) and click on Delete. (see screenshot above)
    B) Click on Yes to confirm deletion. (see screenshot below)
    C) This step depends on if you did step 3 or step 4 above.
    • If you did step 3, then be sure to also do this at the step 4 location.
    7. Close Regedit.
    8. Log off and log on, or restart the computer to apply.
  1. bmb
  2. Posts : 3,141
    Thanks Shawn and Ushatl.
  3. Posts : 72,062
    You're welcome guys. :)
  4. Posts : 87
    Windows 7 Pro 64-bit
    Very cool thanks
    How do you guys figure these registry tweaks out?
  5. Posts : 72,062
    You're welcome Green.
    I just do a lot of digging around in the registry and in Windows 7, then I just get lucky sometimes.
  6. Posts : 3,612
    well written brink its cool to have the drive letter first in my opinion :)
  7. Posts : 72,062
    Thank you Brian. :)
  8. Posts : 6,285
    Windows 10 Pro X64
    The manual steps are missing this part:
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer]
    "ShowDriveLettersFirst"=-
    When I tried the manual steps it didn't work, the .reg did. Difference is the above missing from the manual steps.
    I like it though, thanks for another great tip Shawn.
  9. Posts : 6,618
    I did the manual method and it worked perfectly for Windows Explorer, but I wish it did the same in Disk Management and the file manager that I prefer to use, they are the same as before.
