Recycle Bin Icon - Allow or Prevent to Display
    How to Allow or Prevent the Windows 7 Recycle Bin Icon to Display
    The Recycle Bin provides a safety net when deleting files or folders. When you delete any of these items from your hard disk, Windows places it in the Recycle Bin and the Recycle Bin icon changes from empty to full.
    This will show you how to allow or prevent the Windows 7 Recycle Bin icon to display from the desktop, Windows Explorer, programs that use Windows Explorer, and the File - Open menu bar window for all users on the computer. By default, the Recycle Bin icon is allowed to be displayed in all user accounts.
    Removable drives do not use or have a Recycyle Bin. Files deleted from removable drives are permanently deleted instead.
       Warning
    If set to prevent, then this will only remove the Recycle Bin icon and not prevent a user from using other methods to gain access to the contents of the hidden protected operating system C:\$Recycle.Bin folder though.
    EXAMPLE: Desktop Icon Settings window
    NOTE: When set to prevent, the Recycle Bin option will be grayed out.
    EXAMPLE: Recycle Bin icon Allowed and Prevented in Windows Explorer
    OPTION ONE
    Using a REG File Download
    1. To Allow Recyle Bin Icon to Display
    Allow_Display_Recycle_Bin_Icon.zip
    B) Go to step 3.
    2. To Prevent Recyle Bin Icon to Display
    3. Click on Save, and save the .zip file to the desktop.
    4. Open the .zip file and extract the .reg file to the desktop.
    5. Right click the .reg file (On Desktop) and click on Merge.
    6. Click on Run, Yes, Yes, and OK when prompted.
    7. Log off and log on, or restart the computer to completely apply.
    8. When done, you can delete the downloaded .reg and .zip files on the desktop if you like.
    OPTION TWO
    Through the Local Group Policy Editor
    2. In the left pane, click on to expand User Configuration, Administrative Templates, and Desktop. (See screenshot below)
    3. In the right pane, right click on Remove Recycle Bin icon from desktop and click on Edit. (See screenshot above)
    4. To Allow Recyle Bin Icon to Display
    A) Select (dot) either Not Configured or Disabled. (See screenshot below step 6)
    B) Go to step 6.
    5. To Prevent Recyle Bin Icon to Display
    A) Select (dot) Enabled. (See screenshot below step 6)
    6. Click on OK. (See screenshot below)
    8. Log off and log on, or restart the computer to completely apply.
  1. Posts : 419
    Windows 7 Ultimate SP1 64- bit
    Can't seem to find that setting.
    is it hidden?
    Attached Thumbnails Attached Thumbnails Recycle Bin Icon - Allow or Prevent to Display-local.jpg
  2. Posts : 72,133
    Hello Seven,
    You just need to have the main Desktop folder above Active Directory that one highlighted instead.
  3. Posts : 419
    No, it's not there either!
    I removed it by right clicking on the desktop and unchecked 'Show desktop items' d
  4. Posts : 72,133
    Go up one more folder. It's the Desktop folder above Active Desktop.
    With Show desktop items unchecked, it will hide all of them instead.
  5. Posts : 419
    I removed it!
  6. Posts : 72,133
    Ok mate. I'm glad that you got it sorted. :)
  7. Posts : 75
    Windows 7 Ultimate edition x64
    this way too
    To remove recycle bin icon from desktop Right click on your desktop/personalize/change desktop icons/un-check recycle bin
    Desktop Icons - Add or Remove
  8. Posts : 72,133
    Hello Adam,
    That would be fine if you just wanted to turn off the Recycle Bin, but this tutorial will allow you to prevent all users from being able to turn on or display the Recycle Bin at all instead. This way they will not be able to access it.
    Thank you though. :)
  9. Posts : 75
    oops
    oh ok Brink you're right!My bad!
    great tut though
    thanks
