ALT+TAB - Use Classic Icons or Default Thumbnails
    How to Use Classic Icons or Thumbnail Previews with ALT+TAB Keyboard Shortcut
    Normally, you could press and hold right Alt key, press left Alt+Tab keys, tap Tab key to select a window, and release right Alt key to switch to the window in Classic Windows Switcher.
    This will show you how to ether have classic icons or the default thumbnails previews of opened windows and programs always displayed when you use the ALT+TAB keyboard shortcut in Windows 7 or Vista.
    When your press ALT+TAB, press the TAB key to cycle through the open windows and programs. The selected item (icon or thumbail preview) is what will be displayed on the desktop when you release the keys.
    EXAMPLE: ALT+TAB with Classic Icons or Thumbnail Previews
    ALT+TAB - Use Classic Icons or Default Thumbnails-alt-tab_icons.jpg ALT+TAB - Use Classic Icons or Default Thumbnails-alt-tab-thumbnail_previews.jpg
    Option One
    Using a REG File Download
    1. To Have ALT+TAB with Classic Icons
    Alt+Tab_Classic_Icon.reg
    Download
    B) Go to step 3.
    2. To Have ALT+TAB with Thumbnail Previews
    Alt+Tab_Thumbnail_Previews.reg
    3. Click on Save, and save the .reg file to the desktop.
    4. Right click the downloaded .reg file and click on Merge.
    5. Click on Run, Yes, Yes, and OK when prompted.
    6. Log off and log on, or restart the computer to apply the changes.
    7.When done, you can delete the downloaded .reg files on the desktop if you like.
    Option Two
    Manually in Registry Editor
    1. Open the Start Menu, then type regedit in the search boxand press Enter.
    2. If prompted by UAC, click on Yes.
    3. In regedit, go to the location below. (see screenshot below)
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer
    4. To Have ALT+TAB with Classic Icons
    A) In the right pane of Explorer, right click on a empty space and click on New and DWORD (32-bit) Value. (see screenshot below)
    B) Type in AltTabSettings and press enter. Right click on AltTabSettings and click on Modify. (see screenshot below)
    C) Type in 1 and click on OK. (see screenshot below)
    D) Go to step 6.
    5. To Have ALT+TAB with Thumbnail Previews
    A) In the right pane of Explorer, right click on AltTabSettings and click on Delete. (see screenshot below)
    B) Click on Yes to confirm deletion. (see screenshot below)
    6. Close regedit.
    7. Log off and log on, or restart the computer to apply the changes.
  1. Posts : 112
    Windows® 7 Home Premium SP1 [x64]
    Gar, good post. :)
  2. Posts : 72,052
    Thank you.
  3. Posts : 1,027
    Windows 7 Ultimate x64/ Windows Vista Ultimate x64
    Nice tutorial Shawn keep them coming. :)
