Sound Shortcuts - Create
    How to Create Sound Shortcuts in Windows 7 and Windows 8
    This tutorial will show you how to create or download shortcuts that open directly to the Playback, Recording, Sounds, and Communications tabs in the Sound control panel in Windows 7 and Windows 8.
    EXAMPLE: Sound
    NOTE: Opened to the Playback, Recording, Sounds, and Communications tabs in Folder Options.
    Sound Shortcuts - Create-sounds.jpgSound Shortcuts - Create-communications.jpg
    OPTION ONE
    To Download a "Sound" Shortcut
    1. Sound Shortcut that Opens to the Playback Tab
    A) Click/tap on the download button below to download the file below.
    Sound_Playback.zip
    2. Sound Shortcut that Opens to the Recording Tab
    Sound_Recording.zip
    3. Sound Shortcut that Opens to the Sounds Tab
    Sounds.zip
    4. Sound Shortcut that Opens to the Communications Tab
    Sound_Communications.zip
    Download
    5. Save the .zip file to your desktop.
    6. Open the downloaded .zip file and extract the Sound shortcut to the desktop.
    7. Unblock the Sound shortcut. (See screenshot below)
    8. In Windows 7, you can now Pin to Taskbar or Pin to Start Menu, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
    9. In Windows 8 and 8.1, you can Pin to Taskbar on desktop, Pin to Start screen, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
    10. When done, you can delete the downloaded .zip file if you like.
    OPTION TWO
    To Manually Create a "Sound" Shortcut
    1. Right click or press and hold on an empty area on your desktop, and click/tap on New and Shortcut.
    2. Type the location below into the location area for what tab you want the Sound shortcut to open to, and click/tap on the Next button. (See screenshot below)
    • Playback Tab
      • %windir%\System32\rundll32.exe shell32.dll,Control_RunDLL mmsys.cpl,,0
    • Recording Tab
      • %windir%\System32\rundll32.exe shell32.dll,Control_RunDLL mmsys.cpl,,1
    • Sounds Tab
      • %windir%\System32\rundll32.exe shell32.dll,Control_RunDLL mmsys.cpl,,2
    • Communications Tab
      • %windir%\System32\rundll32.exe shell32.dll,Control_RunDLL mmsys.cpl,,3
    3. Type the name of the Sound tab for the name, and click/tap on the Finish button. (See screenshot below)
    NOTE: You can name this shortcut anything you would like though.
    4. Right click or press and hold on the new Sound shortcut, and click/tap on Properties.
    5. Click/tap on the Shortcut tab, then click/tap on the Change Icon button. (See screenshot below)
    6. In the line under "Look for icons in this file", type in the location below, and press Enter. (See screenshot below)
    %windir%\System32\mmsys.cpl
    7. Select the icon highlighted in blue above, and click/tap on OK. (See screenshot above)
    NOTE: You can use any icon that you would like for this shortcut instead though.
    8. Click/tap on OK. (See screenshot below)
    9. In Windows 7, you can now Pin to Taskbar or Pin to Start Menu, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
    10. In Windows 8 and 8.1, you can Pin to Taskbar on desktop, Pin to Start screen, add to Quick Launch, assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
  1. Posts : 15
    Awesome! Can you take it a step further to Enhancements in Speakers' Properties?
  2. Posts : 8
    Windows 7 Home Premium
    Is there a way to make a script or shortcut that will open sound like this, then make a choice of the playback devices?
  3. Posts : 72,052
    Sorry, but not that I know of, or if it's possible.
    You might create a new thread to see what suggestions you may get on it. :)
  4. Posts : 1
    64
    Thanks so much!
    Thank you so much. Please allow me to condense the information a bit:
    Use rundll to display the sound settings dialog. The last argument specifies the tab to open.
    Example: Playback Tab (0)
    Example: Recording Tab (1)
    For those wondering why i care:
    I'm using SoundWire to connect my Headphones to the PC, so i don't need to crawl under the desk to plug them in. But turning off the loudspeakers is at least 10 klicks in Windows 7.
    I cooked up a AutoIt script to do it for me, but I could not figure out how to open this Dialog without using the mouse. Thanks you for providing these shortcuts.
  5. Posts : 72,052
    You're most welcome Mike. I'm glad that it could help. :)
  6. Posts : 1
    I dont know if this was covered before with Nirsoft as there were many search results for it however I could not find one for this use.
    You can use nircmd from Nirsoft to create desktop shortcuts.
    Right click, New, Shortcut.
    Use this line as the target for your shortcut.
    C:\Windows\nircmd.exe setdefaultsounddevice "Exact device name goes here"
    The device name can be found in the playback tab of your Sound under control panel or from right clicking the speaker icon in the system tray.
    Then name your shortcut whatever you want.
    If you dont want nircmd.exe in your windows folder, specify the alternate location where you saved it instead of the default windows folder directory.
    Also, this is not a program that runs in the background. It just executes.
    There are also other programs which allow for a hotkey you can choose from your keyboard, but the ones I have seen either work only for xp, require it in the system tray (which you can still hide) and/or add another background process.
    But I like nircmd the best.
  7. Posts : 4
    Microsoft Windows Vista Home Premium
    I know that this is a little late but Thank You!
    I was looking for something like this and just to let you know .. these shortcuts work very well on my windows 10 pc!
  8. Posts : 72,052
    I'm glad that they could help mrclose. :)
  9. Posts : 1
    Windows 10 64bit
    going some steps further...
    you are able to jump even more close to your properties, by adding the right registry key.
    For Windows 10 I figured out this shortcut:
    *....mmsys.cpl,,{0.0.0.00000000}.{9bc40abd-b525-453e-a9b0-f73d491bdf42},3
    Windows 8.1:
    *....mmsys.cpl,,{0.0.0.00000000}.{120CED89-3BF4-4173-A132-3CB406CF3231},3
    Look for some key in the registry similar to what I added as screenshots. It has to be something like:
    SWD\MMDEVAPI\{0.0.0.00000000}.{9bc40abd-b525-453e-a9b0-f73d491bdf42}
    Best way to search is to insert the bold part into the search window.
    Cheers!
    Attached Thumbnails Attached Thumbnails Sound Shortcuts - Create-sound-properties.png   Sound Shortcuts - Create-registry2.png   Sound Shortcuts - Create-registry.png
