How to Use System Restore to Change your User Account Password
InformationThis will show you how to use System Restore to reset the passwords of users to what they were for the date of the restore point in Windows 7.
This is helpful for the following reasons:
- You set a new password for the Administrator account and no longer remember it.
- You enter the correct password but because of system corruption it is not accepted.
- You delete a protected Administrator account and are no longer able to log on to another account.
- You change a protected Administrator account to a standard user account and are unable to log on to another Administrator account.
For more information, see: Microsoft Help and Support: KB940765
- For this to work there must already be a valid restore point created to use from the last successful log on.
- If you don't have a proper Windows installation disk, then you can create a System Repair Disk that can be used to reset your user account password in Windows 7.
WarningA System Restore will affect all users on the computer, and also uninstall programs and drivers that were installed after the date of the selected restore point.
Let's get Started!
1) The Boot Priority in the BIOS needs to be set to boot first from the optical drive, insert your Windows disk and re-start the PC, when you see "Press any key to boot from CD or DVD" press the space bar.
2) After the initial "Windows is loading files" select your language, time and keyboard preferences and click next, then select "Repair your computer", then it'll do some searching then choose "Syetem Restore".
3) Remember you must select the restore point before you started experiencing the issues; once you have selected the correct restore point you'll be presented with one last chance before the restore begins, when you are sure everything is correct click next then finish. 4) When the System Restore "checkup" completes you'll get a "Confirm your Restore Point" window, click finish then yes to the next wimdow, then you will need to restart the machine to complete the process. 5) When the PC restarts remember you MUST use the password that was active for the Restore Point that you went back to. After Windows restarts you'll get a "System Restore Completed Successfully" window, just click close. 6) You may need to add back any programs and/or any Windows Updates that may have been removed during the restore process, you may also need to reset any personal settings that may have been changed but none of your personal documents or files will have been removed.
Enjoy :)
Related Tutorials
- How to Reset a Windows Password in Regedit at Boot
- System Restore Point : Create at System Startup
- How to Create a Password for a Windows 7 User Account
- CTRL+ALT+DEL Screen - Add or Remove Change Password
- How to Create a Windows 7 Password Reset Disk
- How to Change the User Account Password if Unable to Login to Windows
- How to Change the Password for Your or Another User Account in Windows 7
- How to Reset the Password of a User Account in Windows 7
- How to Enable or Disable Password must meet Complexity Requirements
- How to Enable or Disable Password Expiration for a User in Windows 7
- How to Change the Maximum and Minimum Password Age in Windows 7
- How to Enable or Disable Windows 7 Password History Enforcement
- How to Change the Time to Warn a User to Change Password Before Expiration
- How to Prevent or Allow a User to Change their Password in Vista and Windows 7
- How to Remove the Password for Your or Another User Account in Windows 7
