Internet Explorer Home Page - Add or Change
    How to Add or Change Home Page in Internet Explorer
    Your home page is displayed when you first start Internet Explorer, or when you click the Home button Internet Explorer Home Page - Add or Change-button-2.jpg in Internet Explorer.
    This will show you how to add or change the home page to be one or more webpages of your choice in Internet Explorer.
    The home page(s) for Internet Explorer are store in these registry locations below.
    (Main Home Page)
    HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main
    Start Page string value (right pane)
    (Secondary Home Pages)
    Secondary Start Pages string value (right pane)
    OPTION ONE
    Home Page(s) for Pinned Sites in IE9 and IE10
    NOTE: This will show you how to have multiple home pages for any pinned site in IE9 and IE10.
    OPTION TWO
    Add or Change Home Page(s) for Internet Explorer Using Internet Options
    1. In Internet Explorer, click on Tools (gear icon or Menu bar) and Internet Options.
    2. Do either step 3, 4, 5, or 6 below for how you would like to add or change your home page(s) in Internet Explorer.
    3. To Use the Webpage(s) in your Currently Opened Tab(s) as Home Page(s)
    NOTE: This will replace your current home page(s) with the webpage address of each tab that you currently have opened in Internet Explorer.
    A) Under Home page in the General tab, and click on the Use current button. (see screenshot below)
    B) Go to step 7.
    4. To Restore and Use the Default Internet Explorer Webpage as the Home Page
    A) Under Home page in the General tab, and click on the Use default button. (see screenshots below)
    B) Go to step 7.
    5. To Use a Blank Page as the Home Page
    A) Under Home page in the General tab, and click on the Use blank or Use new tab (IE10) button. (see screenshots below)
    B) Go to step 7.
    6. To Manually Enter the Webpage(s) as the Home Page(s)
    A) In the white box under Home page in the General tab, type in the URL address of each webpage that you want as your home page(s) one at a time with each address on a separate line by pressing enter after each entered address. (see screenshots below)
    NOTE: Each webpage address must be on it's own separate line.
    B) Continue on to step 7.
    7. If in IE10 or IE11, then in the General tab under Startup, select (dot) Start with home page. (see screenshot below)
    NOTE: In Windows 8 and 8.1, this would be in the desktop version.
    Internet Explorer Home Page - Add or Change-ie_always_open_last_browsing_session-2.jpg
    8. If you added more than one home page and would like to have all of your home pages open when you open Internet Explorer, or when you click the Home button in Internet Explorer, then you will need to be sure to allow it to do so here: How to Open Only the First or All Home Pages when Internet Explorer Starts
    9. Click on OK in Internet Options.
    OPTION THREE
    Add or Change Home Page(s) for IE9, IE10, and IE11 using Home Button
    1. In Internet Explorer, right click on the Home button on command bar, and click on Add or change home page. (see screenshot below)
    NOTE: To make adding your home page(s) easier, open the webpage or webpages in separate tabs before doing step 1. In Windows 8 and 8.1, this would be in the desktop version.
    2. Select (dot) the option you want to use as your home page, and click on Yes. (see screenshot below)
    • Use this webpage as your only home page - This will remove all current home pages, and add the address of the webpage in only the currently opened tab in IE9 as your home page.
    • Add this webpage to your home page tabs - This will add the address of the webpage in only the currently opened tab in IE9 or IE10 to the list as your home page(s).
    • Use the current tab set as your home page - If you have more than on tab open in IE9 or IE10, then this will remove all current home pages, and add the webpage address of each tab that you currently have opened in IE9 or IE10 as your home page(s).
    3. If you select to ahve more than one home page and would like to have all of your home pages open when you open Internet Explorer, or when you click the Home button in Internet Explorer, then you will need to be sure to allow it to do so here: How to Open Only the First or All Home Pages when Internet Explorer Starts
  1. Posts : 10
    Windows 7 Ultimate 32bit
    I am facing this problem any one have idea to change home page in this my home page opions are disabled or how can i enable options of my internet explorer
  2. Posts : 72,058
    Hello Kifayat,
    Using either option in the tutorial below to enable the ability to change IE's home page should fix this for you. If you are joined to a domain, then this will not help you unless the domain administrator changes this setting instead.
    Internet Explorer Home Page - Specify and Prevent Changing
    Hope this helps, :)
  3. Posts : 10
    Bundle of thanks i got resolved my problem
  4. Posts : 72,058
    You're most welcome Kifayat. That's great news. :)
  5. Posts : 10
    It Is Pleasure For Having With You BRINK
