Graphics Card - Overclock
How to Overclock a Graphics Card
   Warning
OVERCLOCKING CAN AND WILL DESTROY YOUR VIDEO CARD IF DONE INCORRECTLY!
Overclocking also voids the warranty on most graphics cards.
Overclocking requires a large time commitment, but can also be done in stages. Make sure you have the time to sit uninterrupted at your computer for around 2 or 3 hours to fully overclock your Card. An addition 2 hours will be needed to finish the final stress tests.
Overclocking (OCing, or OC) is a process by which you increase the clock speed of your GPU and VRAM to increase the performance of your graphics card. This will also heat up the card, and so requires a good cooling system.
If done incorrectly, overclocking WILL DESTROY YOUR CARD! Overclocking also voids the warranty on most graphics cards.
You will need a few programs to overclock. I chose these programs for their ease of use, accuracy, and multiple features. I have also used them to overclock my own cards (a GeForce 9500GT, ATI HD5770, and GeForce 260).
MSI Afterburner:
This is the actual overclocking utility that will let you increase the Voltage, Core/shader/memory clock, and fan speed. It will also show you the temperature of your card in a handy graph.
GPU-Z:
This utility monitors clock speed, temps, and fan speed. I use this as a secondary check on MSI Afterburner.
TechPower-up GPUTool:
This has a similar monitor to GPU-Z, but I used it for stability testing through its Fur Ring feature. It will also allow you to overclock, but I do not like how it works.
FurMark:
This is the ultimate stability and benchmarking test (also my favourite).
Steps:
First thing you need to do is install MSI Afterburner and open it up. Take note of all the default settings, and make sure "Apply settings at Startup" is UNCHECKED. This way if the computer crashes, it will keep your OLD settings (which work).
Secondly, install GPUTool (this is not installed, but you will need to download and install the stability part for some reason) and open it. Run GPU-Z as well.
Third: Make sure all the settings and temperatures are accurate. If one of them shows a radically different setting, take note. (The only one that will be wrong is GPUTools clocks. These will not change, and should not change. Ignore them, and use it only for Stability tests)
Make sure you have adequate cooling, and make sure to know the limits of your card. Do some research and see what other people have overclocked too, what the idle temperature is, the load temperature, and the safe temperature range for your card. You will need to know all this in case you get close to these limits.
When you test for stability, you will need to watch for artifacts (GPUTool will let you know, even if you miss it). Artifacts are small errors in the image, and they look like this:
If you would like, you can run a pre-oc benchmark test to see how you will compare after you have overclocked your card. Open up FurMark, and select your settings. Run the Benchmark test, and write down your result to compare later.
You can also run a stability test first (through GPUTool or Furmark) just for reference.
Now you are ready to start overclocking.
All overclocking will be done through MSI Afterburner and checked with everything else.
Core Clock
We will start with the Core clock (which will stay attached to the shader clock if you have one).
1) Move the clock slider up about 5-10 points. Check MSI Afterburner to make sure it moved (the graph should jump), then check GPU-Z as well. Take note of the temperature, and the fan speed.
2) Check for stability by hitting the test button on GPUTool, and let it run for about 1 minute. Make sure there are nor artifacts, and watch the temperature (on any of the 3 tools).
3) Should the card pass stability and heat, go ahead and turn the clock up again. Then repeat these steps.
4) ARTIFACT!!!!!! Now that you have seen an artifact (this WILL happen), don't panic. This is normal, and it means that your card has reached its limit.
Take note of the core clock, and move it back 10 or 15 points. This is to make sure that you are truly stable. Now, run the stability test. This time you will need to let it run for about 1 HOUR. If you get even 1 artifact, back it off another 5 or 10 points, until there are no errors.
This step is extremely important! Moving it back may reduce your graphics power, but it will keep your card safe. I cannot stress this enough. Move a good 10 -15 points down from where you first got an artifact.
5) Now that you have completed this stability test, take note of the core clock, and temperatures. This is your stable Core overclock.
6) Turn your core clock back to defaults in preparation for finding the memory clock.
Memory Clock
These steps will overclock the video card memory (not amount, but speed of it).
Take note of the memory clock, and move it back 10 or 15 points. This is to make sure that you are truly stable. Now, run the stability test. This time you will need to let it run for about 1 HOUR. If you get even 1 artifact, back it off another 5 or 10 points, until there are no errors.
5) Now that you have completed this stability test, take note of the core clock, and temperatures. This is your stable memory overclock.
Overclocking the whole thing:
At this point, you have found your separate overclocks, and it is time to combine them.
1) Move the Core clock and Memory clock up to their respective stable speeds.
2) Check to make sure that they new speeds are set in, and stability test. This time you will want to run it for a minimum of 1 hour, more if you can.
3) This time it is extremely important to keep track of temperatures and artifacts. Take note of when the card starts to level out on temperature. This will be its new full load temperature, and will be much higher than your normal before.
4) Should you encounter an Artifact, move both the Core and Memory clock back 10 points, and test again. If you get even 1 artifact, back it off another 5 or 10 points, until there are no errors.
Now you can run a benchmark test with FurMark again, and compare your score. It should be significantly higher, depending on the card.
When I OCed my 9500, the score was 300 pre-OC, 450 post-OC. Not much of a difference. Newer cards (such as the HD 5770 and GeForce 260) will have a MUCH higher starting score, in the 3000 range, and will be even higher after overclocking.
That is the basics to overclocking your Graphics card.
Neither I (Lorbob75), nor Seven Forums (Windows 7 Forums) take responsibility should your card be damaged or destroyed if you follow this advice. We do not advise overclocking your video card unless you know what you are doing, and are willing to risk your video card.
The following section is not necessary to overclock your card, and is here merely to inform. Feel free to skip the section if you have successfully OCed your card and don't care how it works.
Overclocking Theory and Information:
Basic Overclocking Information:
Overclocking is the practice of changing a computer components clock rate (clock cycles per second) to increase performance of that part. Overclocking will increase the heat generated by the component, and generally reduces the lifespan significantly.
The most common overclocked components are: CPUs, GPUs, RAM, VRAM, and motherboard chipsets.
In order to do this, the CPU multiplier, motherboard Front Side Bus clock rate, and other settings must be changed. Due to subtle variations in electrical and physical characteristics in the components, each and every component overclocks uniquely. No two setups (even exactly similar) will overclock the same.
EDIT: I have yet to finish the theory section. I need some time to research, and finish my other tutorials, as this section is not actually necessary to OCing a card.
Thank you for your patience.
Graphics Card series:
1. How a Graphics Card Works
2. AGP vs PCI
3. How to Install a New GPU
4. How to Overclock Your Card
5. How to Test NVIDIA/AMD Performance with OCCT
I hope this Tutorial helped a whole bunch of you!
Please vote if you liked it.
~Lordbob
Though it's not finished yet, glad to see this one (with the many questions about this subject as of late).
Windows 7 Ultimate x64AMD Phenom II X4 940 Black Edition @ 3.4GHz (...Corsair CM2X4096-8500C5 (4 X 2GB)XFX Radeon HD 5770 / Diamond Radeon HD 5770 C...
Rig 1
AMD Phenom II X4 940 Black Edition @ 3.4GHz (AM2+)
Gigabyte GA-MA790X-UD4P (AM2+)
XFX Radeon HD 5770 / Diamond Radeon HD 5770 CrossFireX
Asus Xonar DS (PCI)
Samsung SyncMaster 932bw+ (3)
4320x900
OCZ Vertex 2 80 GB - Windows 7 System --
WD Caviar Black 1TB - Music, Movies, Vids, Pics --
WD Caviar Black 640GB - User Profiles & Games --
WD My Book 320GB external
Corsair CMPSU-750TX
Cooler Master HAF 932
Corsair Hydro Series H50
Logitech Desktop Wave
Logitech LX8 Laser
20 down / 2 up
LG GGC-H20L Blu-Ray / HDDVD combo --
Hauppauge HVR-1250 --
Silverstone MFP-51 --
Logitech Webcam C600
So far it is looking really good. I have never done any overclocking and I have been able to follow it and understand it so far. Avery good job.
Windows 7 Ultimate 32 bitIntel(R) Pentium(R) 4 CPU 3.00GHz2.50 GB RAMNVIDIA GeForce 7600 GS
Home built
ASUS P4P800-VM Motherboard Chipset: Intel 865G + ICH5
2.50 GB RAM
SoundMax Integrated Digital Audio (Chip)
ViewSonic VX 1962 wm
1680 X 1050
Seagate Barracuda 7200.10 80 GB
ST380215A ATA Device 18.6 GB
Western Digital "My Book" external hard drive 750 GB
Fan based
Microsoft Comfort Curve Keyboard 2000 v10 USB
Logitec optic USB
3.01 Mb/s download 0.64 Mb/s upload
Thanks for the input guys, it is good to know that it is easy to follow and makes sense. I will finish it now, and get it cleaned up.
If you would like, I can research a bit and add a "theory" section (if you will) about how overclocking actually works, and how to optimize it, etc.
~Lordbob
Windows 7 Ultimate x64, Mint 9Intel i5-2500k2x 4Gb Corsair VENGEANCE DDR3-1600NVidia GeForce N260GTX Twin Frozr
Hera
Intel i5-2500k
ASUS P8P67 Pro
Realtek HD OnBoard Audio
ASUS 24" Monitor
Cooler Master Haf 932
Fans
Razer Tarantula
Razer Lachesis
not fast enough
~Lordbob
Thatt would help a novice like me! :D
Home built
2.50 GB RAM
1680 X 1050
Fan based
Logitec optic USB
~Lordbob
I will have to take some time to research some of it, my own knowledge is a little lacking (so far, not so much after college :D).
~Lordbob
Hera
Intel i5-2500k
ASUS P8P67 Pro
ASUS 24" Monitor
Fans
Razer Tarantula
Razer Lachesis
not fast enough
There is certainly no hurry on my part. I would not attempt to mess with my old card. Now when I build my new box...
Home built
2.50 GB RAM
1680 X 1050
Fan based
Logitec optic USB
Looks good :)
Will re-read when your finished ;)
Easy to follow, well done, so far....
Windows 7 Ult x64 - SP1/ Windows 8 Pro x64Intel Core i5-3570K 4.6GHz8GB (2X4GB) DDR3 1600 Corsair Vengeance CL8 1.5vSapphire HD 7770 Vapor-X OC 1GB DDR5
76~2.0
Gigabyte GA-Z77X UD3H, f18
Onboard VIA VT2021
22" LCD Dell
Samsung 840Pro 128GB SSD,
Corsair HX650W
Cooler Master Storm Scout
Logitech Wave
CM Sentinel
Dismal
Opera Next
Desktop: eSATA ports,
External WD USB 500GB
Alright, all done for now.
I will work on the theory section later, need to finish homework.
~Lordbob
Hera
Intel i5-2500k
ASUS P8P67 Pro
ASUS 24" Monitor
Fans
Razer Tarantula
Razer Lachesis
not fast enough
Very well done. Great job!
Home built
2.50 GB RAM
1680 X 1050
Fan based
Logitec optic USB
I see I also have a shiny new graphic, thanks to Shawn.
Looks good.
~Lordbob
Hera
Intel i5-2500k
ASUS P8P67 Pro
ASUS 24" Monitor
Fans
Razer Tarantula
Razer Lachesis
not fast enough
I noticed that. It looks good.
Home built
2.50 GB RAM
1680 X 1050
Fan based
Logitec optic USB
I tried overclocking my video card, and my fps for all the testing is below 5fps, i tried lowering the clock numbers and raising them, with it still a very low fps, can anybody help me?
Windows 7 Professional3gbsNvidia e-Geforce 7300 gs
Intel Pentium D Core 2 Duo
3gbs
Sound blaster Audigy 2
Dell 1703fp
1280x1024
Maxtor 250gbs
Basic Dell SFF PSU
Small Form Factor (SFF)
Basic Intel CPU Fan, nothing else. :(
Basic Dell keyboard.
Basic Dell Mouse
around 20kb\s at daytime, and 125kb\s at night. Long story.
I wish that i could get a better pc, so i can pwn people :D
With your graphics card, that is the best you are going to get.
If you want better FPS, you will need a better card...
~Lordbob
Hera
Intel i5-2500k
ASUS P8P67 Pro
ASUS 24" Monitor
Fans
Razer Tarantula
Razer Lachesis
not fast enough
Thanks, my card is 2 years old xD
3gbs
Dell 1703fp
1280x1024
Maxtor 250gbs
Basic Dell SFF PSU
Basic Dell Mouse
I think it's worth adding that with GTX400 cards, you overclock the GPU by increasing the shader core now, such as if you open EVGA Precision, the GPU core speed is blacked out. The shader speed is more or less double the GPU speed, so overclocking is quite simple still.
Windows 8.1 Pro x64Intel Core i7 4790k8GB Corsair Dominator 1600MHzMSI TwinFrozr GeForce GTX770
Windows 8.1 Pro x64
Intel Core i7 4790k
MSI Z97S Krait Edition
ASUS Xonar DX/XD 7.1
1920x1080 + 1680x1050
Corsair HX850 modular
Fractal Design Define R4
Logitech G510S Keyboard
Logitech G500S Laser Mouse
40Mbps
LG Blu-Ray player
Interesting tidbit. Any clue why it is that they did this?
~Lordbob
Hera
Intel i5-2500k
ASUS P8P67 Pro
ASUS 24" Monitor
Fans
Razer Tarantula
Razer Lachesis
not fast enough
If I were to overclock my card would it make a big difference in its performance. What about overcloaking any of my components? Will any of them make my computer better? When I say better. I mean I will notice a good increase in performance.
Windows 7 Ultimate x64AMD Athlon(tm) II X4 630DDR3 2048 MB's/ PC3-10600 (1,333 MHz) (2 Cards)ATI Radeon HD 4200
HP Pavilion p6000 series/Model p6654y
Socket AM3 (938)
ATI Radeon HD 4200
Realtek High definition Audio
PnP-Monitor (Standard) (I am using my Emerson TV)
1024 x 768 pixels at 75 Hz in true colors (32-bit)
750.05 Gigabytes Usable Hard Drive Capacity
692.61 Gigabytes Hard Drive Free Space
hp DVD-RAM GH60L SATA CdRom Device [Optical drive]
YMAX magicJack USB Device [Optical drive]
Generic- Compact Flash USB Device [Hard drive] -- drive 2
Generic
250 Watts
HP
Fan
Logitech wireless wave combo MK550 (Came with mouse)
Logitech wireless wave combo MK550 (Came with keyboard)
DSL Download speed 15.06-mb/s Upload .49-mb/s ping 45ms
HP Wireless 802.11 b/g/n PCIe Card
Not a huge different with those components. You might get a few FPS increase.
~Lordbob
Hera
Intel i5-2500k
ASUS P8P67 Pro
ASUS 24" Monitor
Fans
Razer Tarantula
Razer Lachesis
not fast enough
how high did you get your 5770?
Windows 7 Ultimate x64Intel Core 2 Duo E8400Mushkin DDR2 4096MB (2048MBx2) 800Mhz CL 5-5-...Club3D ATI Radeon HD4850 512MB PCIe
GIGABYTE GA-EX38-DS4
Mushkin DDR2 4096MB (2048MBx2) 800Mhz CL 5-5-5-18 SP
Asus 22" VK222U 2ms LCD
Seagate ST3500320AS 500GB SATA2 32MB
Enermax Pro82+ 525W
NZXT Trinity
Arctic Cooling Case Fan AF12025 120mm
Logitech Media Keyboard
Logitech RX700 Cordless
