Quick Launch - Enable or Disable
Page 26 of 39 FirstFirst ... 16242526272836 ... LastLast
  1. Posts : 4
    Windows 7 x86
       #250
    Thanks alot! :)
  2. Posts : 1
    Useful information
    Thanks very much for the Quick Launch how-to. Saved me a lot of time in trying to figure out where that useful feature was hidden.
    Regards,
    Robert Cohn
  3. Posts : 72,164
       #252
    You're most welcome Robert, and welcome to Seven Forums.
  4. Posts : 20
    Win7 Ultimate 32bit
       #253
    I noted that every few days the Quick launch disappears by itself and I have to re-do the steps again ..
    Any one have an idea on this ?!
  5. Posts : 72,164
       #254
    Hello Ahmed,
    Sometimes steps 9 or 10 may help with this. If not, the yellow TIP box at the top of the tutorial should work instead.
  6. Posts : 4
    windows 7 ultimate 64
       #255
    Thank you very much for this tutorial.
    It's a shame that Microsoft didn't set any options to keep some previous default configuration as to add the Quick Lauch set easily(Add least, available from the toobar options).
  7. Posts : 72,164
       #256
    You're most welcome Kayakee, and welcome to Seven Forums. :)
  8. Posts : 1
    Windows 7 Ultimate 64Bit
       #257
    Love that Quick Launch
    Worked like a charm. I didn't like the pins, missed the quick launch. Well done.
  9. Posts : 17,545
    Windows 10 Pro x64 EN-GB
       #258
    I'm sorry to bother you geeks once again with this Quick Launch issue of mine, but I'm desperate to find a fix.
    I've described the issue here earlier, here's a short version once again:
    After a reboot, Quick Launch loses all the shortcut's I've added myself, showing only those shortcuts added by respective installation programs.
    For instance, after a reboot I'll add Snipping Tool to Quick Launch. It stays there as long as I do not reboot. It 'survives' hibernation but not reboot, i.e when I hibernate the computer in the evening and resume it next morning, the Snipping Tool shortcut is still in the Quick Launch, but if I shut down and reboot, it's gone and I have to add it manually once again.
    Any tip really appreciated.
    Kari
  10. Posts : 72,164
       #259
    Hello Kari,
    Have you tried the 2nd part of the TIP box at the top of the tutorial to pin a folder to the taskbar with the Quick Launch shortcuts copied into it instead? Hopefully that workaround will work for you instead.
