Location - Change Computer Default Location
    How to Change the Default Location of your Windows 7 Computer
    This will show you how to set a default location to provide programs information about your computer's geographic location to use when a location sensor, such as a GPS receiver, is unavailable or not installed. When you set a default location, it applies to all users.
    To help you know which programs are accessing your default location, Windows temporarily displays the Location and Other Sensors icon in the notification area the first time a program accesses your computer's location.
    OPTION ONE
    Set Default GeoID Location Using "Region and Language" Settings
    1. Open the Control Panel (icons view), and click on the Region and Language icon.
    2. Click on the Location tab. (see screenshots below)
    Location - Change Computer Default Location-location-1.jpgLocation - Change Computer Default Location-location-1b.jpg
    3. To Only Set "Current Location"
    A) Under Current location, select your current location from the drop down box and click on OK. (see screenshots above)
    B) Go to step 5.
    4. To Set "Default Location"
    A) Click on the Default location link at the bottom. (see screenshots above)
    B) Go to step 3 or 4 in OPTION TWO below.
    5. Close the Control Panel window.
    OPTION TWO
    Set Default Location Using "Location and Other Sensors" Settings
    1. Open the Control Panel.
    2. Type location in the Control Panel's search box (top right corner), then click on the Enter a default location link. (see screenshot below)
    3. To Enter and Apply Default Location Information
    A) Enter your default location information that you wish to fill out, then click on Apply when finished. (see screenshot below)
    B) Go to step 5.
    4. To Delete Default Location Information
    NOTE: This will delete all default location information that you entered and applied in step 3 above back to being blank, and restores the default County/Region location back to what it is set as in step 2 of OPTION ONE above.
    A) Click on the Delete information button. (see screenshot below)
    5. If prompted by UAC, click on Yes (if administrator) or type in the adminstrator's password (if standard user).
    6. When finished, you can close the Default Location window. (see screenshot below step 3A or 4A)
  1. Posts : 5
    Windows 7 Home Premium 64 bit
    The title is a bit misleading: this just allows you to set the current location (i.e. country), not the geographic location (longitude + latitude) Windows should get from a GPS. Is there a way to set the geographic location manually?
  2. Posts : 72,058
    Hello Steven, and welcome to Seven Forums.
    Yeah I agree, but that's the description Microsoft gives it.
    To get GPS type geographic location (longitude + latitude) cordinates, you would need to have an actual GPS sensor device compatible with Windows 7 connected or built-in to the computer. However, you would unlikely be able to change the cordinates.
  3. Posts : 5
    Thanks Brink. So, no location in the registry which I could patch? (My PC is not really the traveling type )
    (Also, thanks for the gazillion tutorial posts.)
  4. Posts : 72,058
    You're most welcome. I'm afraid that I don't know where the registry entries are for these settings though.
