Memory Diagnostics Tool - Read Event Viewer Log
    How to Read Event Viewer Log for Windows Memory Diagnostics Tool
    This will show you how to read the Event Viewer log to see the results of the Windows Memory Diagnostics Tool in Vista, Windows 7, and Windows 8.
    If you just ran the Windows Memory Diagnostics Tool, then it may take a bit before it actual shows up in the Event Viewer.
       Warning
    You will need to be logged in as administrator to be able to open Event Viewer.
    Here's How:
    1. If you have not already, you will need to have ran the Memory Diagnostics Tool prior before it will be in the Event Viewer System log.
    2. Open the Start Menu, and type eventvwr.msc in the search box and press enter.
    3. If prompted by UAC, then click on Yes (Windows 7) or Continue (Vista).
    4. In the left pane of Event Viewer, double click on Windows Logs to expand it, then right click on System and click on Find. (see screenshot below)
    5. Copy and paste MemoryDiagnostics-Results into the line, and click on Find Next. (see screenshot below)
    NOTE: You can continue to click on Find Next to search for other older system logs (if available) for the Windows Memory Diagnostics Tool to see them as well.
    6. You will now see the system log for the results of the Windows Memory Diagnostics Tool. (see screenshot below)
    7. When finished searching for Windows Memory Diagnostics Tool system logs, you can close the Find window. (see screenshot below step 5)
    8. When finished, you can close Event Viewer.
  1. Posts : 32
    Win 7 Ultimate x64 bit SP1
    I can't seem to find an event log of the memory diagnostics tool in event viewer...
  2. Posts : 72,059
    Hello bangdosa, and welcome to Seven Forums.
    Was the Memory Diagnostics Tool able to completely finish running before checking the log?
  3. Posts : 32
    I believe it did. I know it got to around 80%ish before I looked away. Next thing I saw was windows starting. should I try it again and see if it does finish? when it finishes should it automatically restart or results show?
  4. Posts : 72,059
    It'll automatically restart when ran.
    It may take a bit before it actual shows up in Event Viewer since you just ran it.
    Did you run the tool from within Windows? (not in Safe Mode)
  5. Posts : 32
    Yes I told the memory diagnostic to run in windows so it restarted and did it before restarting windows
  6. Posts : 72,059
    If you can't get any results, then you might give a Memtest86+ a try instead.
    RAM - Test with Memtest86+
  7. Posts : 32
    ok will do. Thank you
  8. Posts : 72,059
    You're welcome. :)
  9. Posts : 7
    So, does this means I have 2 bad memory?
    Attached Thumbnails Attached Thumbnails Memory Diagnostics Tool - Read Event Viewer Log-memorydiagnostics-results.jpg
