Control Panel - Change Default Icon
Page 1 of 3 123 LastLast
    How to Change the Default Control Panel Icon in Windows 7
    This will show you how to change the default Control Panel icon in the Windows 7 Start Menu, Desktop icon, and navigation pane to be a icon of your choice.
    You should use a 256x256 pixel .ico (icon) file to have the best support for all icon view sizes.
    EXAMPLE: Default and Changed Control Panel Icon
    Control Panel - Change Default Icon-start_menu_example_default.jpgControl Panel - Change Default Icon-start_menu_example_changed.jpg
    OPTION ONE
    To Change Control Panel Icon for Current User Only
    NOTE: This option will only change the default icon for the user account that you are currently logged in, and will override the icon from OPTION TWO below for only this user account. This option will not change the icon for all users like OPTION TWO below, but only for the current user.
    1. To Change the Control Panel Icon for Current User
    Add_Default_Control_Panel_Icon_Entries.reg
    B) Save the .reg file to the desktop.
    C) Right click the downloaded .reg file on the Desktop and click on Merge.
    D) Click on Run, Yes (UAC), Yes, and OK when prompted.
    E) Open the Start Menu, then type regedit in the search box and press Enter.
    F) If prompted by UAC, then click on Yes (administrator) or enter administrator's password (standard user).
    G) In regedit, navigate to the location below. (see screenshot below)
    NOTE: This will be the registry locations added from steps A to D.
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CLSID\{26EE0668-A00A-44D7-9371-BEB064C98683}\DefaultIcon
    H) In the right pane of DefaultIcon, right click on (Default) and click on Modify. (see screenshot above)
    I) Do either step J or K below.
    J) To Use another Windows 7 Icon
    J1) Download and install the free program IconViewer to add the Icons tab in the screenshot below step J2.
    NOTE: Be sure to download the correct 32-bit or 64-bit version for your Windows 7.
    J2) In Windows Explorer navigate to the .exe (ex: for program icons) or .dll (ex: Windows 7 icons) file that contains the icon that you want to use, right click on the file, click on Properties, and the Icons tab. (see screenshot below)
    NOTE: The most common Windows 7 icons come from the C:\Windows\System32\imageres.dll file.
    J3) Make note of the icon number for the icon that you want to use instead. (see screenshot above)
    NOTE: For example, the default Control Panel icon number is 27.
    J4) In the Modify window from regedit, type in the full path of the .exe or .dll file followed by ,-icon# (full path,-####) and click on OK. (see screenshot below)
    NOTE: For example, if I wanted to use the path (step J2) and the 27 icon (step J3), I would type:
    %SystemRoot%\system32\imageres.dll,-27
    OR
    C:\Windows\System32\imageres.dll,-27
    J5) Go to step L below.
    K) To Use a Custom Icon of Your Own
    K1) In the Modify window from regedit, type in the full path of where the custom icon (.ico) file is saved at with the file extension in quotes, then click on OK. (see screenshot below)
    WARNING: You will need to use a 256x256 pixel icon that was made for Windows 7 and Vista for them to display properly at all of the available icon view sizes in Windows 7. You will also need to leave the icon (.ico file) saved at the exact location you typed below for it to continue to work. If you delete or move this icon, then it will no longer be displayed.
    L) In regedit, navigate to the location below.
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CLSID\{5399E694-6CE5-4D6C-8FCE-1D8870FDCBA0}\DefaultIcon
    M) In the right pane of DefaultIcon, right click on (Default) and click on Modify. (see screenshot above)
    N) Do either step J or K above, and use the same icon you used at step G above. When finished, go to step 3.
    2. To Restore the Default Control Panel Icon for Current User Only
    NOTE: This will undo the changes made to the icon in OPTION ONE for only the current user, and restore the icon back to what the icon is set as in OPTION TWO below.
    Restore_Default_Current_User_Control_Panel_Icon.reg
    3. Log off and log on, or restart the computer to apply.
    4. When done, you can delete the downloaded .reg file if you like.
    OPTION TWO
    To Change Control Panel Icon for All Users
    NOTE: This option will change the default icon for all users on the computer. You will need to be logged in as an administrator to be able to do this option. OPTION ONE above will override this option's changed icon only in the user account that OPTION ONE was applied in.
    1. To Change the Control Panel Icon for All Users
    A) Open the Start Menu, then type regedit in the search box and press Enter.
    B) If prompted by UAC, then click on Yes.
    C) In regedit, navigate to the location below. (see screenshot below)
    HKEY_CLASSES_ROOT\CLSID\{26EE0668-A00A-44D7-9371-BEB064C98683}\DefaultIcon
    D) In the left pane, right click on DefaultIcon, click on Permissions. (see screenshot above)
    E) Select your Administrators account, check the Allow box for Full Control, then click on OK. (see screenshot below)
    F) In the right pane of DefaultIcon, right click on (Default) and click on Modify. (see screenshot below step 1C)
    G) Do either step H or I below.
    H) To Use another Windows 7 Icon
    H1) Download and install the free program IconViewer to add the Icons tab in the screenshot below step H2.
    H2) In Windows Explorer navigate to the .exe (ex: for program icons) or .dll (ex: Windows 7 icons) file that contains the icon that you want to use, then right click on the file, click on Properties, and the Icons tab. (see screenshot below)
    H3) Make note of the icon number for the icon that you want to use instead. (see screenshot above)
    H4) In the Modify window from regedit, type in the full path of the .exe or .dll file followed by ,-icon# (full path,-####) and click on OK. (see screenshot below)
    NOTE: For example, if I wanted to use the path (step H2) and the 27 icon (step H3), I would type:
    OR
    H5) Go to step J below.
    I) To Use a Custom Icon of Your Own
    I1) In the Modify window from regedit, type in the full path of where the custom icon (.ico) file is saved at with the file extension in quotes, then click on OK. (see screenshot below)
    WARNING: You will need to use a 256x256 pixel icon that was made for Windows 7 and Vista for them to display properly at all of the available icon view sizes in Windows 7. The icon will need to be saved in a location that all users have access to. For example, in a C:\Users\Public folder. You will also need to leave the icon (.ico file) saved at the exact location you typed below for it to continue to work. If you delete or move this icon, then it will no longer be displayed.
    J) In regedit, navigate to the location below.
    HKEY_CLASSES_ROOT\CLSID\{5399E694-6CE5-4D6C-8FCE-1D8870FDCBA0}\DefaultIcon
    K) In the right pane of DefaultIcon, right click on (Default) and click on Modify.
    L) Do either step H or I above, and use the same icon you used at step C above. When finished, go to step 3.
    2. To Restore the Default Control Panel Icon for All Users
    NOTE: This will restore the default icon for your user account and all users except the user accounts that had applied OPTION ONE above.
    Restore_All_Users_Default_Control_Panel_Icon.reg
  1. xTL
    Thank you Shawn :) had a little problem at first, but dubble checked and tripple checked ur guide :)
    Works a 100% :)
  2. Posts : 72,052
    You're most welcome xTL. Thank you for posting back with your results. :)
  3. xTL
    so far every singel tutorial here has worked for me :) really happy
  4. Posts : 3
    windows 7 home premium
    Hi there...
    the tutorial is great, but for some reason, the only icon that doesnt change is the icon in the start menu...
    following the steps in the tutorial, the icon changed in every location apart from the start menu one.
    Please see attached images.
    Image 1 - this shows the icon still at its original state
    Image 2 - this shows the icon in its changed state
    Image 3 - this shows the regedit key entered
    Please advise!!
    thanks!
  5. Posts : 72,052
    Hello Kevin,
    Have you already restarted the computer afterwards to see if that may have been the issue?
    If you did, then also do OPTION ONE to see if it will change afterwards.
  6. Posts : 1
    Windows 7 Professional 32 bit
    kevinkeady said:
    Hi there...
    Please advise!!
    thanks!
    Kevin,
    After following Brink's advice to restart the computer, this problem was resolved on my system. Should work for all other users too.
    Another thing I have discovered is that when accessing the control panel in the 'Large Icons' or 'Small icons' view modes, the taskbar icon remains unchanged along with the small icon to the immediate left of the URL bar. Viewing in 'Category' mode resolves this issue.
    [hint] Perhaps further tweaking can resolve this minor problem! [\hint]
    A well written tutorial nonetheless. Back to further customising my Windows 7.
  7. Posts : 4
    Control Panel Icon Changing
    My Control panel Icon does not change.
    I went through all the steps and restarted my computer often.
    /image
    This is how my computer currently looks.
    I went back and tried both methods.
    I even went to the different registry files and changed them both.
    I used the registry merge app as well.
    In Summary, it seems like my computer feels like she is married to the wrong person. Am I begin strong armed here or what?
  8. Posts : 72,052
    Hello Carl, and welcome to Seven Forums.
    If you would, please ZIP your icon and upload it here. I'll be happy to test it on my system to see what the issue may be.
    In addition, could you also post screenshots of your registry for the locations in OPTION ONE to see what they look like. :)
  9. Posts : 4
    Okay, so I went through step one again and took a screenshot of that location and the new path I made to the new Icon.
    Also, I double checked the icon in gimp, it was 256x256 and I uploaded it here in a zip.TronControl.zip
