Sound Recorder - Open and Use
How to Open and Use Windows 7 Sound Recorder
Sound Recorder lets you record a sound and save it as an audio file on your computer. This will show you how to open and use Sound Recorder in Windows 7.
You can record sound from different audio devices, such as a microphone that's plugged into the sound card or motherboard audio line in jack on your computer. The types of audio input sources you can record from depend on the audio devices you have and the input sources on your sound card or motherboard.
   Warning
To use Sound Recorder, you must have a sound card or motherboard with a audio line in jack and speakers installed on your computer. If you want to record sound, you will also need a microphone or some other audio input device.
Here's How:
1. Open the Start Menu, click on All Programs, Accessories folder, and double click on Sound Recorder. (See screenshot below)
NOTE: The Sound Recorder exe file is located at C:\Windows\system32\SoundRecorder.exe.
A) Go to step 3.
OR
2. Open the Start Menu, and type soundrecorder in the search line and press Enter. (See screenshot below)
3. To Start Recording
A) Click on Start Recording. (See screenshot below)
4. To Stop Recording and Save
A) Click on Stop Recording. (See screenshot below)
B) Navigate to where you want to save this .wma file, type in a name for the file, then click on the Save button. (See screenshot below)
NOTE: In this Save As window you can also specify information for the Contributing artists name, Album title, or Genre by clicking on each one of them and typing the information before clicking on Save.
   Tip
If you decide to continue recording audio instead of saving it to file right now, then click on the Cancel button instead. (See screenshot above)
When ready to continue recording, click on Resume Recording. (See screenshot below)
5. When finished, close Sound Recorder. (See screenshot below step 3A)
Good tutorial
thanks
ASUS
windows 7 ULTIMATE 64 BITS
AMD ATHLON II 620X4 QUAD CORE 2,60 GHZ
ASUS M4A78 PRO
MUSHKIN ESSENTIAL DDR2 8 GB
ATI RADEON HD 4650 1 GB
REALTEK HD
SAMSUNG SYNCMASTER 2032 BW
1680X1050
Seagate Barracuda 7.200 750 GB
SCYTHE KATANA III
LOGITECH G15 GAMMING
LOGITECH G9
20 MB
You're welcome Riojanitoperez. :)
help plx?
when i do this it records sound of my microfone.. but i want it to record the sound i hear (so music, gameplay sound etc)
Help plx?
When i am using the sound recorder in Windows 7 and i dont want to save what i just recorded, is there a way to delete it without saving it and deleting it? When I stop recording it pops up and asks to save but if I hit cancel it goes back and says resume recording. Also can you replay what you just recorded without saving it. It sure seems cumbersom...
Hello Dr.Krptonite, and welcome to Seven Forums.
Sorry, but you will need to save the recording before you will be able to play it back. Luckily the file can just be deleted when done.
Why is volume low?
Hi, I'm using Sound recorder on windows 7 but for some reason when I record, the sound result is low. I'm using a headset microphone and when i set the mic, I spoke as loud as I can and it reached to the top of bar (I also tried normal volume) but when I recorded on sound recorder, I hear the voice very low even on the volume 100. How can I fix this problem? I don't know if it may be my headset's fault seeing I don't know my headset's original product on voice... I hope you can reply to this question fast because I am a very forgetful person and I would probably forget I posted here and I need it fast
Hello TearDroplet, and welcome to Seven Forums.
Double check in Sounds in the Control Panel (Icons view), then look in the Recording tab, double click on your default recording device (Microphone) with the green circle checkmark icon. Next, look in the Levels tab to see if you have an option to increse the DB level or like one below of the microphone to help make it louder.
It helped a little. Thanks for the fast reply. I decided to use a different program in the end but had the same problem XD. Your advice helped better with the new program though
You're welcome TearDroplet. I'm glad to hear that it works better for you with the other program. You might check through all of your separate sound and microphone levels to see if their may be a level setting that may be the culprit somewhere to help it sound better.
vinyl conversion
does the Sound Recorder allow me to transfer vinyl records to my computer? I have a turntable, as well as USB cord.
Hello Goldendusty, and welcome to Seven Forums.
If the turntable has a way of connecting to the audio input of your computer, then you should be able to. You may need to enable What U Hear recording as well though.
Is it possible to use the recorder as a programmed login greeting?
windows 7 64bit
AMD Phenom 9500 quad core
MSI
8 GB
GE Force 9800 GT
SoundBlaster Titanium
2: 250 and 500
NZXT MID TOWER
answer from Creative ref "What U Hear"
With regards to your enquiry, please be informed that Sound Blaster X-Fi XtremeGamer (using PCI slot) and X-Fi Titanium series (using PCI Express slot) sound cards can support what u hear feature on Windows 7. You can refer to the links below for more specifications of the sound cards:
http://us.store.creative.com/Creative-Sound-Blaster-XFi-XtremeGamer-Sound/M/B000J1F1BI.htm
PCI Express Sound Blaster X-Fi Titanium
http://us.store.creative.com/PCI-Express-Sound-Blaster-XFi-Titanium/M/B001E25KDK.htm
PCI Express Sound Blaster X-Fi Titanium Fatal1ty Professional Series
http://us.store.creative.com/PCI-Express-Sound-Blaster-XFi-Titanium/M/B0018EFGTM.htm
X-Fi Titanium Fatal1ty Champion Series
http://us.store.creative.com/PCI-Express-Sound-Blaster-XFi-Titanium/M/B001BDPLJA.htm
Best Regards,
Alvin
Direct Sales
Creative Labs Americas
Built it myself
Windows 7 Home Premium 64 bit
Intel I7 870
giggabyte
8 GB
Sapphire
Creative Sound Blaster Audigy 4
Acer 24"
2 Samsung 500 GB internal
1 Maxtor 750 GB external
650 W PC Power
Thermaltake cooler
Deleted Sound Recorder
Hello, I want to make recordings, but I accidently deleted my sound recorder. What do?
Windows 7 64bit
Hello Beestra, and welcome to Seven Forums.
Here's a copy of SoundRecorder.exe from my system in the ZIP file below that you can use. You would just need to download the ZIP, extract (drag and drop) the EXE file from the ZIP to your desktop, unblock the EXE file, then copy the EXE into your C:\Windows\System32 folder.
Hope this helps, :)
Hi - I am new here and am vision impaired. I'm having trouble finding the "New" thread option. I just wanted to ask how long will the Windows 7 recorder record? Thanks and sorry I have posted this in the wrong area.
windows 7 home
Hello classycat, and welcome to Seven Forums.
Sound Recorder will record until either you hit the stop button, or until you run out of hard drive space.
Hope this helps, :)
