CTRL+ALT+DEL Screen - Add or Remove Change Password
    How to Add or Remove "Change Password" from the CTRL+ALT+DEL Screen
    This will show you how to add or remove the Change a password option in the Windows 7 CTRL+ALT+DELETE screen for specific or all users on the computer.
    EXAMPLE: CTRL+ALT+DEL screen
    NOTE: This is when you press CTRL+ALT+DEL with Change a password added by default (left screenshot below), and removed (right screenshot below).
    CTRL+ALT+DEL Screen - Add or Remove Change Password-change_password_added.jpg
    CTRL+ALT+DEL Screen - Add or Remove Change Password-change_password_removed.jpg
    OPTION ONE
    Using a REG File Download
    1. To Add Change Password to CTRL+ALT+DEL Screen for Only Current User
    Add_Change_Password_CTRL+ALT+DEL.reg
    B) Go to step 3.
    2. To Remove Change Password from CTRL+ALT+DEL Screen for Only Current User
    Remove_Change_Password_CTRL+ALT+DEL.reg
    3. Click on Save, and save the .reg file to the desktop.
    5. Click on Run, Yes, Yes, and OK when prompted.
    6. When done, you can delete the downloaded .reg file on the desktop if you like.
    OPTION TWO
    Through the Local Group Policy Editor
    2. In the left pane, click on to expand User Configuration, Administrative Templates, System, and Ctrl+Alt+Del. (See screenshot below)
    CTRL+ALT+DEL Screen - Add or Remove Change Password-change_password_group_policy.jpg
    3. In the right pane, right click on Remove Change Password and click on Edit. (See screenshot above)
    4. To Add Change Password to CTRL+ALT+DEL Screen
    A) Select (dot) either Not Configured or Disabled. (See screenshot below step 6)
    B) Go to step 6.
    5. To Remove Change Password from CTRL+ALT+DEL Screen
    A) Select (dot) Enabled. (See screenshot below step 6)
    6. Click on OK. (See screenshot below)
    CTRL+ALT+DEL Screen - Add or Remove Change Password-change_password_edit.jpg
  1. Posts : 324
    Windows 7 and MAC
    GOOD... KEEP IT UP
  2. Posts : 84
    vista
    Link is broken
    i give it temporarily until brink fix it;
  3. Posts : 72,052
    Sorry about that. Links fixed. :)
  4. Posts : 2
    Windows 7 Enterprise x64
    Unable to download registry files.
  5. Posts : 72,052
    Hello Greg, and welcome to Seven Forums.
    Here's a copy of them in a ZIP file as promised. Please let me know if you need anything else. :)
    CTRL+ALT+DEL Screen - Add or Remove Change Password Attached Files
  6. Posts : 2
    Excellent! Thanks! :)
  7. Posts : 72,052
    You're most welcome Greg. :)
  8. Posts : 2
    windows 7 pro 64 bit
    My apologies if I should not be replying to this at this point, but I wanted to ask if this should work on 32-bit Windows 7 as well as 64?
  9. Posts : 72,052
    Hello MLR1, and welcome to Seven Forums.
    Yes, it'll work on both 32-bit and 64-bit Windows. Usually the tutorials will specify at the top if it will only work on specific editions or versions instead of all. :)
