How to Create a "RemoteApp and Desktop Connections" Shortcut in Windows 7 and Windows 8
RemoteApp and Desktop Connections (Workspaces Center) is a feature that you can use to access programs and desktops (remote computers and virtual computers) made available to you by your workplace's network administrator. When you're at home, you can access all the programs and computers that you would normally need to be at work to use. With a connection, all of these resources are located in one easy-to-access folder on your computer. Using these resources is almost the same as if they were on your local network or on your computer.
This tutorial will show you how to create or download a
RemoteApp and Desktop Connections shortcut that you can use or pin where you like in
Windows 7 and
Windows 8.
EXAMPLE: RemoteApp and Desktop Connections
OPTION ONE
To Download "RemoteApp and Desktop Connections" Shortcut
1. Click/tap on the download button below to download the file below.
RemoteApp_and_Desktop_Connections.zip
2. Save the .zip file to the desktop.
3. Open the downloaded .zip file and extract (drag and drop) the RemoteApp and Desktop Connections shortcut to the desktop
4. Right click or press and hold on the
RemoteApp and Desktop Connections shortcut, and click/tap on
Properties,
General tab, and on the
Unblock button. (See screenshot below)
5. In
Windows 7, you can now
Pin to Taskbar or
Pin to Start Menu, add to
Quick Launch,
assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
6. In
Windows 8, you can
Pin to Taskbar on desktop,
Pin to Start screen, add to
Quick Launch,
7. When done, you can delete the downloaded .zip file on the desktop if you like, or save it to use again.
OPTION TWO
To Manually Create "RemoteApp and Desktop Connections" Shortcut
1. Right click or press and hold on a empty area on desktop, and click/tap on
New and
Shortcut.
2. Copy and paste the location below into the location area, and click/tap on the
Next button. (See screenshot below)
%windir%\explorer.exe shell:::{241D7C96-F8BF-4F85-B01F-E2B043341A4B}
3. Type
RemoteApp and Desktop Connections for the name, and click/tap on the
Finish button. (See screenshot below)
4. Right click or press and hold on the new
RemoteApp and Desktop Connections shortcut on the Desktop, and click/tap on
Properties.
5. Click/tap on the
Shortcut tab, then click/tap on the
Change Icon button. (See screenshot below)
6. In the line under "Look for icons in this file", copy and paste in the location below and press
Enter. (See screenshot below)
%SystemRoot%\System32\tsworkspace.dll
7. Select the icon highlighted in blue above, and click/tap on
OK. (See screenshot above)
NOTE: You can use any icon that you would like instead though.
8. Click/tap on
OK. (See screenshot below)
9. In
Pin to Taskbar or
Quick Launch,
10. In
Windows 8, you can
Quick Launch,
