Windows 7 Forums Search
Windows 7 - Power Options Shortcut - Create
How to Create a "Power Options" Shortcut in Windows 7
Published by Brink
02-27-2010
Default Power Options Shortcut - Create
information   Information
This will show you how to create or download a Power Options shortcut to select a power plan in Windows 7.
You can also Pin to Taskbar or Pin to Start Menu this shortcut, or move where you like in Windows 7 for easy use.
EXAMPLE: Power Options
OPTION ONE
To Download the "Power Options" Shortcut
1. Click on the download button below to download the file below
Power_Options.zip
download
2. Click on Save, and save the .zip file to the desktop.
3. Open the downloaded .zip file and extract the Power Options shortcut to the desktop.
4. Right click on the Power Options shortcut, and click on Properties, General tab, and on the Unblock button. (See screenshot below)
5. Move the shortcut to where you like for easy use.
6. When done, you can delete the downloaded .zip file on the desktop if you like, or save it to use again.
OPTION TWO
To Manually Create the "Power Options" Shortcut
1. Right click on a empty area on desktop, and click on New and Shortcut.
2. Copy and paste either location below into the location area, and click on the Next button. (See screenshot below)
C:\Windows\explorer.exe shell:::{025A5937-A6BE-4686-A844-36FE4BEC8B6D}
OR
C:\Windows\System32\control.exe powercfg.cpl
OR
C:\Windows\System32\rundll32.exe shell32.dll,Control_RunDLL powercfg.cpl
3. Type Power Options for the name, and click on the Finish button. (See screenshot below)
4. Right click on the new Power Options shortcut on the Desktop and click on Properties.
5. Click on the Shortcut tab, then click on the Change Icon button. (See screenshot below)
6. In the line under "Look for icons in this file", copy and paste the location below and press Enter. (See screenshot below)
%SystemRoot%\System32\powercpl.dll
7. Select the icon highlighted in blue above and click on OK. (See screenshot above)
NOTE: You can use any icon that you would like instead though.
8. Click on OK. (See screenshot below)
9. Move the shortcut to where you like for easy use.
Administrator
Brink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond repute
Brink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond reputeBrink has a reputation beyond repute
Tutorial Tools
Comment
Power Options Shortcut - Create problems?
Tutorial Tools
Similar Threads for: Power Options Shortcut - Create
Windows 7 Tutorial Category
Internet Options Shortcut - Create Tutorials
Advanced Power Options Shortcut - Create Tutorials
Power options - is there a keyboard shortcut ? Customization
Indexing Options Shortcut - Create Tutorials
Folder Options Shortcut - Create Tutorials
