Problem in CPU Usage in window 7 and other motherboard problem!
  1. Posts : 1
    Window 7 Ultimate x86
    Hello Guys.
    How are you all? I hope you are fine and enjoying a good health. Well, I'm having some problems with CPU Usage. Whenever, I open firefox or others programs, It start up to 100% and that's the reason of me of lagging. Even, I have problem with svchost.exe. It gets like 50-70 % CPU usage.
    I'm having 2 windows installed on this computer, one is Window XP SP3 and Window 7 Ultimate x86 (32 bits of course). Windows XP SP3 is installed on C and 7 on Disk D..
    When I had installed windows 7, I had no Aeros or transparencies. I roamed on many websites to have a aero on, but unfortunately, after spending time I didn't got it at all. then, finally after a hard working, I got the driver for NVIDIA Geforce fx 5200. (256 MB) ( I know this isn't good). But as I read in some forums, that this card, doesn't enable the Windows 7 transparency. But, I think I'm the one who did it! If anyone wants the driver, I would be glad to give him.
    So the problem is up at all.
    The 2nd problem is, when I start my computer then it appears like 'System date is not setup' and ' System battery is low'. I don't know how to fix it, since I do something with my computer like putting the ram out and then in, then out then in. like 10-12 times. Because, I was checking rams.
    The third problem is that.
    While using computer, even Windows XP3 the computer totally get stopped and were unable to do anything except restarting computer.
    I would be glad if someone helps me out! thanks!
    Here are my PC requirements!
    System Information
    Time of this report: 1/1/2002, 07:53:41
    Machine name: AHMEDSAEED-PC
    Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
    Language: English (Regional Setting: English)
    System Manufacturer: System manufacturer
    System Model: System Product Name
    BIOS: JOOYON BIOS Date: 07/29/05 08:28:51 Ver: 08.00.09
    Processor: Intel(R) Pentium(R) 4 CPU 3.00GHz (2 CPUs), ~3.0GHz
    Memory: 1022MB RAM
    Available OS Memory: 1022MB RAM
    Page File: 645MB used, 1401MB available
    Windows Dir: D:\Windows
    DirectX Version: DirectX 11
    DX Setup Parameters: Not found
    User DPI Setting: Using System DPI
    System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
    DxDiag Version: 6.01.7600.16385 32bit Unicode
    Display Devices
    Card name: NVIDIA GeForce FX 5200
    Manufacturer: NVIDIA
    Chip type: GeForce FX 5200
    DAC type: Integrated RAMDAC
    Device Key: Enum\PCI\VEN_10DE&DEV_0322&SUBSYS_00000000&REV_A1
    Display Memory: 509 MB
    Dedicated Memory: 254 MB
    Shared Memory: 255 MB
    Current Mode: 1024 x 768 (32 bit) (85Hz)
    Monitor Name: HP D8901 HP 71 17-inch Monitor
    Monitor Model: HP D8901
    Monitor Id: HWP22C5
    Native Mode: unknown
    Output Type: HD15
    Driver Name: nvd3dum.dll
    Driver File Version: 7.15.0010.9685 (English)
    Driver Version: 9.6.8.5
    DDI Version: 9Ex
    Driver Model: WDDM 1.0
    Driver Attributes: Final Retail
    Driver Date/Size: 10/9/2006 21:55:00, 3022848 bytes
    WHQL Logo'd: Yes
    WHQL Date Stamp:
    Device Identifier: {D7B71E3E-4062-11CF-6546-0A2001C2CA35}
    Vendor ID: 0x10DE
    Device ID: 0x0322
    SubSys ID: 0x00000000
    Revision ID: 0x00A1
    Driver Strong Name: oem1.inf:NVIDIA.Mfg.NTx86.6.0:nv_NV3x:9.6.8.5:pci\ven_10de&dev_0322
    Rank Of Driver: 00F60003
    Video Accel: ModeMPEG2_A ModeMPEG2_C
    Deinterlace Caps: {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    D3D9 Overlay: Not Supported
    DXVA-HD: Not Supported
    DDraw Status: Enabled
    D3D Status: Enabled
    AGP Status: Enabled
  2. Posts : 20
    windows 7 professional x64 SP1
    Problem 1: you have 1 gig of ram - Aero won't work.
    Problem 2: Battery is dying, you need to replace it - its the little silver circular part on your motherboard and has nothing to do with your ram.
    Problem 3: Even XP needs 2g ram minimally to even function, Win 7 needs 4g+ to work at all (properly)
    Problem 4: Your hardware specs are below average for your new Operating systems, consider upgrading to 4g+ of ram 1333mhz or more, P67 or Z68 Mobo w/ Core I3 CPU, a GTS standard video card with 1g of DDR5 memory, 550w power supply and then Win7 / XP will talk to you again.
    Good Luck!
