Opening Audacity changes volume/balance of Sound Blaster X-Fi 5.1 card
Jarvismcjiggles
9:43 PM
Occasionally (but not every time) when I open Audacity it will lower or mute my overall soundcard volume & other times it will automatically adjust the balance of my left/right speaker settings.
I've tried multiple versions of Audacity (older & recent) as well as two different drivers for my soundcard (the most recent one + one from 2016).
Is there any setting in audacity or my soundcard that could be triggering this? Why is it so random?
Any help is appreciated.
Microsoft Windows 7 Ultimate 64-bit 7601 Mult...Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz16.00 GBNVIDIA GeForce GTX 1050 Ti 4GB
HP
Hewlett-Packard 1497
16.00 GB
ASUS XONAR U5
2560 x 1440 x 32 bits @ 75 Hz
(1) Samsung SSD 850 EVO 500GB ATA Device
(2) Seagate 4TB Expansion USB Device
Yes, I've had issues with my Audacity before. It is most likely a driver conflict or just how you have some of the sound settings that overlap/overlay what software plays sound where.
I'm hitting the hay for the evening and I have a full morning. Iko22 or maybe Paul Black may be of help.
Win 10 x64, Linux Lite, Win 7 x64, BlackArch,...
HP Desktop & Compaq Laptop
Samsung 850 Pro 256Gb,
Hitachi HDD 1Tb,
Crucial MX SSD 250Gb
150Mbps dn, 20Mbps up
Firefox, Chrome, Opera, & VPN
Windows 7 x64, Vista x64, 8.1 smartphoneIntel E8400 65W 64-bitDDR2 2 x 2GB, 1GB x 2XFX Radeon HD5750
Gigabyte EP45-UD3LR
XFX Radeon HD5750
AMD High Definition Audio; Realtek High Definition Audio
iiyama prolite X2377HDS
500GB 7200 rpm Seagate ST3500413AS 16MB, 500GB 5400 rpm Toshiba MQ02ABF050H 32MB, 200GB 7200 rpm Seagate ST3200820AS 8MB, 2TB 7200 rpm Western Digital WD20EZRX 64MB
Enermax Liberty Modular
Antec P193 Midi Tower
Mionix ZIBAL 60
Razer USB 2.0 Diamondback Mouse or Huion Graphics Tablet
Internet Explorer, Lunascape, Firefox, Opera, Avast Safezone
Hi Jarvismcjiggles,
I have not used Audacity myself but you could perform the following to rule out driver issues.
To find out if all your hardware device drivers are working correctly you can check for any yellow triangles in the Device Manager [Start => Control Panel => Device Manager => Expand ALL nodes].
If there are any yellow triangles you can view the Device Status [it will give you the Error message / Error code] of the problem by right-clicking the item with the Error => Properties => General tab.
You can also check for any problems by clicking Start => Run => in the search box type msinfo32 => Enter => Components. If there are any problem drivers they will be shown on the right-hand side of the Components screen. When it is blank, you are good to go.
Another option is => Find and Identify Unknown Devices through Device Manager.
I hope this helps!
Win 7 HP SP1 64-bit Vista HB SP2 32-bit Linux...Intel(R) Pentium(R) CPU P6200 @ 2.13GHz4.00 GBIntel(R) Graphics Media Accelerator HD
Fujitsu LIFEBOOK
Win 7 HP SP1 64-bit Vista HB SP2 32-bit Linux Mint 18.3
FUJITSU FJNBB06
4.00 GB
[1] Realtek High Definition Audio [2] Intel(R) Display Audio
TOSHIBA MK5076GSX
AVG FREE
I've noticed that if I move the playback volume slider in Audacity, the computer's global output volume slider is also changed, and vice versa. It's a HP laptop with whatever default sound board and drivers they provided. The only way I know to decouple them is to choose Communications Headphones in the Playback Device box - then presumably Audacity's playback volume instead gets coupled to the headphones, which I guess is my USB wireless headphones volume. It doesn't seem possible to get Audacity to keep its playback volume to itself.
It's a long shot but maybe your problem is related to that.
Win 7 Pro 32-bit
HP Probook
Win 7 Pro 32-bit
