Hi everyone, so I just purchased the Creative Sound Blaster X-Fi Titanium Fatal1ty Champion Series Sound Card. I'm having issues with audio(even before I bought the card) and I'm not sure how to fix them. I'll describe the main issues.
Sound Issues:
-Odd popping noise at the beginning and end of audio(usually not noticeable except when in Ventrilo because no other audio is playing.
-Static buzz sound (usually unnoticeable but more amplified in certain applications like the menu of Starcraft 2).
-Tons of feedback through my mic (clicks from my mouse, my own voice is amplified through my headset).
I bought a Sound Card so I could hopefully fix some of the problems (odd popping noise), and just make audio better in general but I must be doing something wrong because it's just gotten worse.
I'm using the Sennheiser PC 350 headset, and an Antec 902 case. I used another headset before I bought the sound card and it did not fix the audio popping issue, but have not tried using it after I got the new sound card.
One thing I noticed is if I unplug the mic the annoying buzzing seems to go away. And the mic feedback(of course). I don't know if this is a common issue that might be related to my case or if there is a way I can fix this through Windows 7 settings or the Creative software. I've tried messing around with the settings but nothing seems to work.
If anyone thinks they can help me out that would be awesome.
These are my system specs, also located in my profile.
System Manufacturer/Model Number N/A
OS Microsoft Windows 7 Home Premium 64-bit
CPU AMD Phenom II X4 955 Black Edition Deneb 3.2GHz
Motherboard GIGABYTE GA-790XTA-UD4
Memory G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 1280)
Graphics Card(s) ASUS 5870
Sound Card Creative Sound Blaster X-Fi Titanium Fatal1ty Champion SerieMonitor(s)
Displays Acer P235Hbmid Black 23" 5ms HDMI Widescreen LCD Monitor
Screen Resolution 1920x1080
Hard Drives SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5"
PSU Antec TruePower New TP-750 Blue 750W
Case Antec Nine Hundred Two
Cooling 4 case fans
Keyboard Razer Arctosa
Mouse Razer Imperator
Internet Speed Cable 10Gbs
Other Info N/A
Sound Issues:
Cooling 4 case fans
Other Info N/A
Microsoft Windows 7 Home Premium 64-bitAMD Phenom II X4 955 Black Edition Deneb 3.2GHzG.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3...ASUS 5870
- Microsoft Windows 7 Home Premium 64-bit
- AMD Phenom II X4 955 Black Edition Deneb 3.2GHz
- Motherboard
- GIGABYTE GA-790XTA-UD4
- G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 1280
- Graphics Card(s)
- ASUS 5870
- Sound Card
- Creative Sound Blaster X-Fi Titanium Fatal1ty Champion Serie
- Monitor(s) Displays
- Acer P235Hbmid Black 23" 5ms HDMI Widescreen LCD Monitor
- Screen Resolution
- 1920x1080
- Hard Drives
- SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5"
- PSU
- Antec TruePower New TP-750 Blue 750W
- Case
- Antec Nine Hundred Two
- Cooling
- 4 case fans
- Keyboard
- Razer Arctosa
- Mouse
- Razer Imperator
- Internet Speed
- Cable 10Gbs
