Solved A problem that is taking me months to find a way to fix....
Yes that's the way the recovery system works
Is it surely guaranteed that there will the an original windows Operating System and not have a blank laptop?? Cuz i cant take a risk on it since we dont have the installation disk of the dell
Windows 7 Home Premium x64I dont know sorry...4GB RAM (3.80 GB Usable) ?Intel HD Graphics Card
Dell Inspiron 15 1564
Generic PnP Monitor
1366x768
Toshiba External HDD (500 GB)
Standard PS/2 Keyboard
Logitech M90
3 MBPS
PC Matic Super Shield
I use my laptop for gaming and more!
Unfortunately there is no guarantee that this will work that I can give you as there is no way to confirm that everything is ok. It' Should work, and the software may give you the option to save your data or even make recovery media but this depends on what was loaded by Dell at the factory
You may try to contact your nearest Dell office and see if they have a set of recovery disks for that model laptop, but even if they do they will be likely to charge for the service, although this is normally just the cost of the disks and postage
    Ryzen 9 5950X, 3.8 - 5.2 MHz
    Asus Prime X570-Pro
    64GB [2 x 32GB] DDR4 3200MHz
    2 x 3840 x 2160 @60Hz
    Workstation Case [Matt Black]
    920 MB Down 50 MB Up
    Also run ...
    Nexus 7 Android tablet x2
    Samsung 10.2" tablet
    Wacom Expresskeys Remote
    Loopdeck+ Graphics Controller
    Shuttle Pro v2 Control
    Dell XPS 17 10750H
    Windows 11 Pro x64 Latest RP
    Intel I7 10750H 5.0GHz
    Dell XPS
    32GB [2x16GB] DDR4 2933 MHz
    nVidia GTX1650Ti 4 GB GDDR6
    Stock [Realtek] 4 Speaker
    3840 x 2400
    Stock - Active Fan Control
    Backlit + Various Logitech
    72 MB Down 18MB Up
    Also run ...
    10.2" tablet
    Sony Z3 Android Smartphone
    Shuttle Pro v2 Control Pad
    10TB NAS
Windows 7 Ultimate x64 SP1AMD Phenom 2 1090T2x8GB Kingston HyperX Fury Black 1600Mhz Unga...MSI GTX 970 Gaming 4G
AMD Phenom 2 1090T
Gigabyte GA-890FXA-UD5
3xAcer GD245HQ
HighPower 1000W
Cooler Master HAF 932
Noctua NH-D14
Logitech G19
Logitech G500
IE 11 - Firefox - Chrome
Seems above board so OK to link, although from reading through some of the chat there I don't think it's something for a regular user yet, (or to be honest ever) ;)
    Asus Prime X570-Pro
    Also run ...
    Dell XPS 17 10750H
    Dell XPS
    3840 x 2400
    72 MB Down 18MB Up
    Also run ...
    10.2" tablet
    10TB NAS
If you have found an option to use recovery settings I would go with that. Factory install means your original copy of windows is on the laptop and will be reinstalled via the recovery process - it will be as it was when the computer was new. Which can be nice - but as Barman said there might be quite a few out of date trial programs and so on that need removing. And you'll need to do all the Windows updates which could take a day or more, but quicker than things have been until now.
It will set up as a new installation, just as if you had installed from a disc, but with manufacture software in addition. Do you have files on there you want to keep? If so it might be an idea to try and recover those before resetting to factory settings.
W7 HP 64 bitCore i3 1st gen8gbNvidia 330M
Sony Vaio VPCCW2S1E
W7 HP 64 bit
Core i3 1st gen
8gb
Nvidia 330M
8 mbps
Updating windows that will take a day will relieve me more of feeling safe from BSODs rather than wasting months to find one right solution out of many fixes out there :D
Also i cannot recover those softwares so i still have them when i reset to factory settings since i cant boot to my desktop and i last booted from my laptop was back December 2015 :(
Generic PnP Monitor
1366x768
Logitech M90
3 MBPS
Thank you guys for helping me!!! Specially to AddRAM hazel123 and Barman58 !!! :)
Now i have my laptop back and its weird looking for now since its in the factory image but i'll edit annd personalize it :P
Generic PnP Monitor
1366x768
Logitech M90
3 MBPS
Yay! I'm glad you found the recovery drive option. If you look in programs (Windows button, control button 'uninstall programs' you will see a list of the pre-installed somewhere. I'm not sure how much 'extra' stuff Dell put on but there are likely to be some 'trial' softwares that will be out of date (and will also pester you to pay for them when they expire). You'll need antivirus on it before you do anything. But if you've already started doing something without antivirus on it, you can restore to factory settings again and start again (you should be able to do it easier next time as there will probably be a Dell recovery program/option in the list of programs).
Anyway you can either activate the trial antivirus that'll be installed and then replace it before the trial runs out. Or you can uninstall the trial antivirus and put your own antivirus on (if you have one) or if you start Windows updates, Windows will automatically down MSE so that will give you antivirus for doing the Windows updates, although I would replace that later with something 'stronger'.
Usually any Microsoft Office, antivirus and so on are 'trials' and will keep nagging you to pay for a full version - they can be safely uninstalled via the Control program/uninstall programs.
As for the look, you can change that in 'Appearances' and choose wallpapers or aero or whatever.
I've just reset mine to factory settings recently and there are a lot of Windows updates, so be patient until they are all done. After that it will be safe to use. Don't connect to the internet until antivirus is on and all Windows updates done (if you have already, then say and we can suggest a virus check before going any futher).
I would go to Windows Updates in the program list, open Windows updates and on the left select 'change settings' and opt for the second one 'download updates but let me choose whether to install them'.
Sony Vaio VPCCW2S1E
W7 HP 64 bit
Core i3 1st gen
8gb
Nvidia 330M
8 mbps
What you may wish to do at this point, is check for a Dell folder in the start menu all programs list, which contains an option to create a set of recovery disks, this will take a few minutes and a DVD or two, but could save you in the future if you ever get into problems again.
    Asus Prime X570-Pro
    Also run ...
    Dell XPS 17 10750H
    Dell XPS
    3840 x 2400
    72 MB Down 18MB Up
    Also run ...
    10.2" tablet
    10TB NAS
What im doing at this point is actually updating my windows since 10:30 AM to present 8:30 PM and there are 12 more updates xD so it will be a long updating day :D
Totally,i updated 19 windows updates yet and 12 more to go :)
Generic PnP Monitor
1366x768
Logitech M90
3 MBPS
It's worth it when it's done :-) It probably won't do any harm leaving all the bloatware programs on - if there are any - but if there is Java I would remove it. Control panel - uninstall programs.
When it's all finished you might have the Windows 10 upgrade icon appear. If you don't want it there's a thread on here which shows which updates to remove to get rid of it.
Sony Vaio VPCCW2S1E
W7 HP 64 bit
Core i3 1st gen
8gb
Nvidia 330M
8 mbps
Btw i've been running the laptop for 12 hours now, will it still not overheat or something bad happens? Sorry i just use my laptop from 3-6 hours and its the first time it took this long :)
Generic PnP Monitor
1366x768
Logitech M90
3 MBPS
It should be fine. Some people leave their laptops switched on permanently. They can run a bit warmer when working hard doing a lot of updates, but it if it overheated it would just shut down probably.
Sony Vaio VPCCW2S1E
W7 HP 64 bit
Core i3 1st gen
8gb
Nvidia 330M
8 mbps
The update took 14 hours :D and there are some updates left to do :)
BTW I've found something really odd, i did resetted it to factory settings but its sooo slow that when i move my mouse,it stops responding for 5 minutes then when i click/type something there,it stops responding too long then it will say windows explorer has stopped responding then it takes me almost 45 minutes to boot to my desktop and 1 hour to reboot. It was slower than the old self of that laptop :( Any help???
Generic PnP Monitor
1366x768
Logitech M90
3 MBPS
It takes that long because you were in the middle of updating, after all your updates are done, windows should not take but a minute to reboot.
Skylake Special #666
Intel Core i7 6700K
Asus Sabertooth Z170 Mark 1
EVGA GTX 980 Ti SC x2
Realtek High Definition
AOC G2460PG
Logitech G910 Orion Spectrum
How's it going? Are you up and running now?
Sony Vaio VPCCW2S1E
W7 HP 64 bit
Core i3 1st gen
8gb
Nvidia 330M
8 mbps
Btw i did accidentally factory restored my laptop again and it became successful but when it tried to reboot,the dell logo appeared then next is the windows logo then it will just turn to black forever then will reboot after a long time saying i need to launch startup repair but when i try to go to the recovery options, it just shows the backround and the cursor and not any option for recovery :(
Generic PnP Monitor
1366x768
Logitech M90
3 MBPS
I think you said you had Dell discs with drivers on? There may be a repair option on there. That's a shame when you were nearly updated.
How did you actually lose your Windows install in the first place? Just wondering if there is a hardware issue.
Sony Vaio VPCCW2S1E
W7 HP 64 bit
Core i3 1st gen
8gb
Nvidia 330M
8 mbps
I have my dell drivers and utilities cd which only does is a diagnostics
Btw is there a way i can do a system restore over there? I think that can be the only solution since i made a restore point of the laptop before it happened
Generic PnP Monitor
1366x768
Logitech M90
3 MBPS
I don't understand what you mean there, sorry. You could try the drivers and utilities disc and see if it has a repair option or even a recovery option to reinstall. When you say you made a restore point, I don't think that will help if Windows is not booting and loading - unless you mean you made a system image?
Once Windows was installed you would have had the option to burn a dvd as a repair disc, or make a system image and there might also have been a Dell option to make recovery discs of the Full windows install.
Sony Vaio VPCCW2S1E
W7 HP 64 bit
Core i3 1st gen
8gb
Nvidia 330M
8 mbps
