Sound Blaster X-Fi Titanium Sound card issue
MrRatigan
2:09 AM
I have put the sound card into my computer and made sure that I've hooked up everything correctly, but I have ran into a problem with it. When I ran the download "Product Identification Module Update" from the Creative website, it's telling me that I don't have the right OS, and tells me to update to Windows 7 or later versions. Well, my problem is that I have Windows 7 Home Premium 64bit, which I know is plenty new, and I don't understand why it's not letting me download the update/driver for the sound card. Please do help if you are able to :cry:
MrRatigan, Welcome to SF. Check to make sure that you have fully updated W7 and then double check and see if the Creative downloads will take then.
Windows 7 Ultimate 64
MSI P67A-GD80 b3
XFX Radeon 7870 2GB DDR5
Sound Blaster Z Series Card
1680 X 1050 p
(1) 1 tb WD Black
(2) 1 tb WD green/sata II
(2) 3 tb Seagate Barracuda
(1) 120 gb OCZ Vertex SS
(1) Drobo 5N w/5 Seagate 3tb
CoolerMaster Storm Styker
Basic 120mbps down
Chrome and IE 10
Netgear Nighthawk router
Asus USB 3 & sata 6 PCIe card
Drobo 5N advanced NAS
I have just checked and there were no updates for it, and I checked to see if I had the latest version of the Service Pack, and I do, which is 1.
I would forget about the product detection download and go straight for the proper drivers for your model sound card.
MSI P67A-GD80 b3
1680 X 1050 p
(1) 1 tb WD Black
Basic 120mbps down
Chrome and IE 10
Agreed. Only install what is needed and you only need that if the drivers tell you they cant find your sound card. Also I highly recommend avoiding the creative driver from windows update. Make sure to hide that if you see it as an update.
windows 8.1 Pro x64intel [email protected]2x8gb ripjaws x @2133asus r9-290@1100/1300
Elsa
windows 8.1 Pro x64
msi mpower max ac
creative sbz
dell u3011
840 evo 250 & 8.5tb
evga supernova p2-1000
corsair air 540
corsair h100
logitech g710+
logitech g502
avg
firefox
Windows 7 Pro X64 SP1Intel Core I7-3930k16 GB Gskill DDR3-2133eVGA GTX680
homegrown
Intel Core I7-3930k
Asus P9X79 Pro
eVGA GTX680
Creative X-Fi Titanium
As PA246Q
1920 X 1200
Corsair Force GT, 120 GB
WDC 1.5TB Caviar Black
PCP&C Silencer 750 Crossfire
Silverstone FT02
Noctua NH-D14
cheap Logitech USB
Microsoft Intellimouse Explorer (old optical) USB
6Mb cable
Pioneer BDR-205
Samsung SH-203B
Monsoon 5.1 speakers
Only downloading just the driver, it gives me this: Setup is unable to detect a supported product on your system. Please ensure that your product is properly installed before running this Setup program.
I have it put in the computer correctly and everything, but I can't figure out why it won't detect it at all
Could the bios need to be set to turn on or see the card in it's PCI slot? Just thinking that it could be a setting in bios turning off something or turning on something?
MSI P67A-GD80 b3
1680 X 1050 p
(1) 1 tb WD Black
Basic 120mbps down
Chrome and IE 10
That is weird. I've always used x-fi cards and never once did I have this issue.
But at this point try uninstalling all creative software installed -if any- and from the device manager right click on the device (should be with a yellow ?) and uninstall it while also checking the box to delete all drivers for it just to be sure.
Shut down the pc and remove it from the system. On reboot enter the bios and make sure on board sound is disabled. Let windows load as usual. Shut down again and insert the x-fi once again, preferably in another pci slot if available. Let windows load again and proceed to installing the drivers in administrator mode. Right click on the creative drivers and select Run as Administrator regardless.
I hope that will do it as I would not know what else to suggest:(
Elsa
windows 8.1 Pro x64
msi mpower max ac
creative sbz
dell u3011
840 evo 250 & 8.5tb
corsair air 540
corsair h100
logitech g710+
logitech g502
avg
firefox
I'm afraid that I did all that and it tells me the same thing as before whenever I try to install it.
What are the chances the sound card could be bad? You may want to call the manufacturer for help or to RMA the card.
MSI P67A-GD80 b3
1680 X 1050 p
(1) 1 tb WD Black
Basic 120mbps down
Chrome and IE 10
That is also so, I never thought about that. Hmm.... I will have to get ahold of the manufacturer whenever I get the opportunity.
Yeah it will have to be during their business hours which is a pain but often I find that's the best call when nothing else I can think of is working. As you know it's really not all that tough. If the device is showing in device manager then it would be settings but when it's not and there's no bios setting to turn on or off then all things point to bad card. Please keep us in the loop so we can learn from this as well!
MSI P67A-GD80 b3
1680 X 1050 p
(1) 1 tb WD Black
Basic 120mbps down
Chrome and IE 10
