Belkin USB Wireless Adapter Problems...
OK. Built-in Windows driver is provided by Marvell Yukon, Belkin USB adapter uses Marvell's chipset. For reasons unknown to me the fact is Belkin's own drivers don't work with 7, you need the driver this image in my earlier post shows.
What build of 7 you have? The right driver is included in all builds since 7100. Did you already try this?
Kari
HP ENVY 17-1150eg
Windows 10 Pro x64 EN-GB
1600*900 (1), 1920*1080 (2&3)
Logitech Performance Mouse MX
50/10 Mbps VDSL
Windows Defender 4.3.9431.0
Maxthon 3.5.2., IE11
7500 i think and i just done what you post said by uninstalling everything disconnecting the USB restarting and connect again, i done that it picked up the device and said "installing driver" then it said driver install unsuccessful and had an red cross next to it.
Is there anyway of getting this driver online i need? so i can transfer it to my computer and install it like that.
HP
AMD Phenom(tm) 8750 Triple-Core Processor 2.40 GHz
4.00 GB
22" Samsung LCD
500GB
1T External
Virgin 20mps
I've tried to google Marvell Drivers, no luck.
I'll check something, back in hour or so.
Kari
HP ENVY 17-1150eg
50/10 Mbps VDSL
When i unplug the adapter i get the normal disconnected sound when i plug it back in i get 3 quick deep beeps and nothing happens....
HP
4.00 GB
22" Samsung LCD
500GB
1T External
Virgin 20mps
The attached zip contains the driver, let's hope it works. Once again, disconnect the USB adapter, uninstall all remains of Belkin in both Device Manager and Control Panel > Programs and Features. Unzip the driver to C:\Windows\system32\Drivers\. Reboot, reconnect the adapter. Come back to tell how it went.
Kari
View attachment MRVW24C.zip
HP ENVY 17-1150eg
50/10 Mbps VDSL
Done what you said, after reboot i reconnected the adapter and it done the connected sound then the 3 quick deep beep sound don't know what that means, and then popped up and said driver unsuccessfully installed.
HP
4.00 GB
22" Samsung LCD
500GB
1T External
Virgin 20mps
Everytime i troubleshoot or plug it in i get those 3 beeps and right after the beeps it says no driver found. It will start to install the driver then the 3 beeps and then it says it can't find a driver.
HP
4.00 GB
22" Samsung LCD
500GB
1T External
Virgin 20mps
OK I have read through the whole of this thread and no where have I seen the model number from the actual device?
Could the OP please confirm the actual model number of the device.
Also due to Belkin manufacturing policy (they use more than one firmware/hardware supplier without changing the model number :mad: ) can you also provide the FCC ID from the unit (This does change on each hardware change)
My Computers
    Ryzen 9 5950X, 3.8 - 5.2 MHz
    Asus Prime X570-Pro
    64GB [2 x 32GB] DDR4 3200MHz
    2 x 3840 x 2160 @60Hz
    Workstation Case [Matt Black]
    920 MB Down 50 MB Up
    Also run ...
    Nexus 7 Android tablet x2
    Samsung 10.2" tablet
    Wacom Expresskeys Remote
    Loopdeck+ Graphics Controller
    Shuttle Pro v2 Control
    Dell XPS 17 10750H
    Windows 11 Pro x64 Latest RP
    Intel I7 10750H 5.0GHz
    Dell XPS
    32GB [2x16GB] DDR4 2933 MHz
    nVidia GTX1650Ti 4 GB GDDR6
    Stock [Realtek] 4 Speaker
    3840 x 2400
    Stock - Active Fan Control
    Backlit + Various Logitech
    72 MB Down 18MB Up
    Also run ...
    10.2" tablet
    Sony Z3 Android Smartphone
    Shuttle Pro v2 Control Pad
    10TB NAS
ok on the back of the device it says:
Device: Belkin High-Speed Mode Wireless G USB Network Adatper
FCC ID: K7SF5D7051
Model no.: F5D7051 P10650-B
HP
4.00 GB
22" Samsung LCD
500GB
1T External
Virgin 20mps
All my searched lead to this page with belkin ...
Belkin : Support : Wireless High Speed Mode USB Adapter : F5D7051
The only drivers I can find are stated for 32 bit Vista here ....
Belkin : Support : F5D7051 Driver
However looking at the actual download file this does include the x64 bit tag
Hopefully this will do the trick
With Belkin products in the past I have found that the download will create a folder on the c: drive in the form of C:\belkin\drivers ....
To install remove the adaptor and any existing drivers (in Device manager and make sure you select the remove files option) ..
Re insert the adaptor and choose to manually install the drivers - point the selection box to the C:\belkin folder and let the install complete
It is normally best to then restart the pc
Hopefully this will also work in your case :D
My Computers
    Asus Prime X570-Pro
    Also run ...
    Dell XPS 17 10750H
    Dell XPS
    3840 x 2400
    72 MB Down 18MB Up
    Also run ...
    10.2" tablet
    10TB NAS
Ok i installed the driver, and then plugged it in, and it started picking up some wireless networks but at very low signal and i couldn't connect to any of them. So like you said i restarted the computer and when i logged back in its not working and isn't picking anything up. I go to the network and sharing setting and the adapter says "disabled" and i try enable it and it doesn't do anything.
Edit i restarted it again and i can now again pick up some wireless signals and i am connected to my main one. I was on internet for like 1-2 mins and it has disconnected again and now i can't get back on it, i ran a Wdinows Network Diagnostics and i got that 3 quick deep beeps again and it says network adapter is expericing some problems. and it tells me to plug a Ethernet cable in which defeats the object. Now the connections totally lost and i can't pick anything up and everythings disabled and disconnected.
Also the device is still flashing but not picking anything up.
HP
4.00 GB
22" Samsung LCD
500GB
1T External
Virgin 20mps
More annoyed now after i gave up as nothing seems to be working i was going to downgrade to vista, yet i can't as it says not device driver found so i can't install vista either, now my computer is pretty much usless atm.
HP
4.00 GB
22" Samsung LCD
500GB
1T External
Virgin 20mps
Yes this is annoying - have you contacted Belkin support directly on this matter? - I have dealt with them on issues previously and always found them extremely helpful - they offer a lifetime warranty on all their devices so it is in their interest to ensure that support is up to the mark.
back to the original issue though ..
when installing the last time did you remove the old files as I suggested? this is normally an essential with network driver install.
One other thing that may or may not help is the actual port that the device is plugged into - Not all USB ports are created equal and a change of port can occasionally make all the difference. I did not suggest this earlier as I am assuming that you are using the same port that worked previously with vista
My Computers
    Asus Prime X570-Pro
    Also run ...
    Dell XPS 17 10750H
    Dell XPS
    3840 x 2400
    72 MB Down 18MB Up
    Also run ...
    10.2" tablet
    10TB NAS
i thought i got it working then, i was using it for like 45 mins and again it disconnected and now i can't pick anything up :( i am getting so annoyed, and even more annoyed that i can't downgrade to vista.
Edit:
I switched the usbs around i had my iphone plugged in aswell and its now connected to the internet again, but i can't hope it will stay like that for long...
HP
4.00 GB
22" Samsung LCD
500GB
1T External
Virgin 20mps
USB adapter disconnects after computer standby
cant seem to find my same problem occuring in the forum....
new computer, windows 7.
installed (online) Belkin driver (most recent I guess) and its working great, but.....
after I come back to computer and "wake it up" out of sleep, the Belkin shows no connectivity. Not really a problem but theres isnt a fast/easy way to get it reconnected other than "troublshoot" which will go through checks and then 'reset' the adapter and al is fixed. With XP i just right clicked and re-connected or refreshed or something that was quick and painless.
Any settings adjustment anywhere to keep USB adapter connected all the time?
Dell inspiron
windows 7
Hate to tell you this but I have 3 of the belkin usb adapters gathering dust because I can not get them working properly. Some folks have, depending upon the chipset that belkin used. Some have ESL, Ralink, etc.
I just loaded up a linksys usb adapter and haven't had any problems.
:cry:
custom build
WinXP / Win 7 / Win 8.1 64bit Dual Boot
i7-4770K
Asus Z87-A
16 gb G.Skill Ripjaws
on board 4600
On Board Soundmax HD
Dell 19" Flat Panel
1280x1024
Samsung 840 Pro 512gb SSD
WD1001 Caviar Win 7 Boot
WD500 Caviar Win XP Boot
2xWD500 Caviar (Raid 0)
WD750 Caviar (Backup)
Aerocool StrikeX 800w x2
Aerocool Strike X
Air
Microsoft Wireless
Microsoft Wireless
Cable
Asus 12x Blu-ray writer
Hi
I found a resolution for myself somewhere on different site
Basically I've uninstalled the anti virus protection, and restarted computer, installed the USB wireless Adapter and Installed the Anti virus and all works perfect.
Hope this helps you and good luck
Windows 7 64bit
Quad Core
Asus
8GB
Nvidia
