takuro1103
- Local time
- 7:30 AM
- Messages
- 44
big problem of all of new adding USB device!! the story is : just before i was trying to plug my MP3 player to uploading song, but the system inform that it is new USB device and need to install driver, i just let it automaticaly install its driver, but system cannot find any driver for my MP3 player, i have try to remove the device from device manager, and scan it again, it show off a yellow exclamation mark next to my USB device (which is my player), then i clicked on update driver software by right it and select auto search driver, and it still cannot find driver, i have try to put on some other USB device, my toshiba 4gb flash drive, USB hub (1 to 4), and even my logitech wireless Keyboard, they all cannot find its driver! can anyone tell my what is going on? i have search for this problem and found that lots of people have this problem but there is no answer for it! but, some usb device such as my mouse, other USB flash is work, those are the USB device that i start using it after clean install. below is my PC config, and i hope that somebody can help my with it.
CPU : AMD Phenom II 945
MB : MP-AKGX Extreme (Chipset 790X)
RAM : 2 x 2GB DDR2 1066
Display Card : ATI HD2600PRO
BIOs USB all enable, nothing special.
please advice what i can do, beside, those USB device do not have specify driver, e.g. MP3 player Creative Zen x-fi, USB Hub etc...they should look for it driver from windows itself, and, they all work fine as i have try to put it on my laptop...
thanks!!
thanks!!
- windows 7
