boot problems!please need help!
Okay, we need to get the boot issue resolved before we can move on. Try unplugging your hard drive and booting from a CD/DVD you know works.
Windows 7 Professional x64
Intel i7 2600K OC'd @ 4620 MHz
Asus P8Z68-V Pro
16GB GSkill Sniper 2133 Mhz (4x4GB)
EVGA GeForce GTX 480 SuperClocked+
2x Acer S273HLbmii 27"
2 x 1920x1080
64GB Crucial M4 SSD
Storage: Hitachi 1TB 5400RPM, Samsung 1.5TB 5400RPM
Corsair HW Series 750w (modular)
Cooler Master HAF 932 Advanced Blue Edition
CM Hyper 212+ CPU cooler, 3x 230mm + 1x 140mm case fans
Logitech MK320 (wireless)
30 Mb/s : 2 Mb/s
how to i unplugg hard drive on my laptop...i know but its under licence....:)
the only solution is to find the windows 7 dvd and do a repair?but i dont have windows 7 dvd.:D
Windows 7,Ubuntu,Fedora,Windows XP
i know about wubi...but wubi has two options...to boot up ubuntu and i cant do that and to install ubuntu inside the windows os...i dont want that.
If you are using Windows 7 now, use the link above to create a repair disk. Instead of unplugging your HD, try going into the BIOS and disabling all boot devices except optical drive.
Asus P8Z68-V Pro
2 x 1920x1080
64GB Crucial M4 SSD
30 Mb/s : 2 Mb/s
Don't we need to mark the 2 partitions as active (D & F)?
HP Touchsmart IQ771.uk
AMD Turion(tm) 64 X2 Mobile Technology TL-56
ASUS Pheonix
3GB Nanya PC2-6400 DDR2-SDRAM SO-DIM (400MHz)
NVIDIA GeForce Go 7600 256MB GDDR3 SDRAM
High Definition Intergrated NVIDIA MCP51
46" Sony Bravia HDTV
1600x1200
1.5TB Samsug
320GB Seagate ST3320820AS - SATA 3Gb/s 8MB
500GB Maxtor Basics STM305003EHD301-RK
↓6.32 Mb/s ↑0.35 Mb/s ↔26ms
BIOS - American Megatrends Inc. 5.07
Ethernet Port - NVIDIA nForce 10/100/1000 Mbps
DVD Drive - TSSTcorp DVDR/RW TS-T632L
how do you mean rsvr85 ?
jonathan_king i tryed that already...still the same problem...
i thing when we make rescue cd in windows 7 system save the setting and configuration...and then if you have some problems it restore the previous good setting right?
so if i make rescue cd now it will restore this problem?
Not quite:
This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your Windows installation disc, or can't access the recovery options provided by your computer manufacturer.
Asus P8Z68-V Pro
2 x 1920x1080
64GB Crucial M4 SSD
30 Mb/s : 2 Mb/s
ok...sorry...my mistake...:D
Ignore the active comment ;)
ASUS Pheonix
1600x1200
1.5TB Samsug
Can you access your boot popup menu? It may be disabled in your BIOS, but it is usually the F11 or F12 key during the POST. Can you manually boot from your optical drive?
Asus P8Z68-V Pro
2 x 1920x1080
64GB Crucial M4 SSD
30 Mb/s : 2 Mb/s
ok then...no bootmgr file...:sarc:
i have to get windows 7 cd then...but thank you all guys.
i can access popup menu...and guess what...BOOTMGR is missing...please press ctrl+alt+delete to restart.
Do you have a camcorder to record your PC booting into Windows then booting off a dvd and getting bootmgr is missing???
I just cannot get my head around it, maybe i've been staring at my monitor too long! :)
ASUS Pheonix
1600x1200
1.5TB Samsug
ahahahaaaaaahahahaa
Yes, second that. The only think of other that user error is a bad optical drive. Or maybe a bad BIOS.
Asus P8Z68-V Pro
2 x 1920x1080
64GB Crucial M4 SSD
30 Mb/s : 2 Mb/s
come on...its not i think its bad windows 7 installation.i find on internet bootmgr file but for windows vista....:sarc:
haha...damn...no windows 7...its look like i need to repair installation with windows 7 cd.
please DO NOT install integral parts of the OS from the internet.
please create a repair cd as per Johnathans posts ;)
ASUS Pheonix
1600x1200
1.5TB Samsug
That would be best. You have have one of two possible problems:
1) the computer is not booting from the right drive
2) the boot manager is missing, in which case a Startup Repair should fix it.
Asus P8Z68-V Pro
2 x 1920x1080
64GB Crucial M4 SSD
30 Mb/s : 2 Mb/s
ok then thank you guys and i will try that.bye
