Can I connect a graphics card with 6pin power connector, to a 4pin?
VaynardX
12:35 AM
As the topic implies, can I use a 6-pin graphic card when I only have 4 pins on my motherboard? I want to upgrade to a gtx 550 ti, and my motherboard is Asus P5KPL AM-SE. Can I use this card?
P.S. Sorry, I am still a noob at computers.;3
Windows ultimate 32bit
Windows 7 Professional x64AMD Phenom II X4 9254x1024mb Kingston HyperX DDR2-1066 KHX8500D2/1GAsus GTS 450 OC
Asus V2-M3M8200 Barebones
V2-M3M8200 (basically a M3N78-VM)
Asus GTS 450 OC
Creative Sound Blaster X-Fi Titanium PCIe
Asus 24" LCD VH242H
WDC WD5000AAKS
WDC WD5002ABYS
Seagate ST325062 USB-to-IDE
Fujitsu 160GB Pocket USB HDD
Antec Earthwatts EA-430D
Asus V2-M3M8200
120mm side fan & 80mm front & 92mm rear fan
Dell USB mini Multimedia
Logitech MX518
Comcast Xfinity
Logitech Webcam Pro 9000
Accurian 40-1462 Speakers
little dot MKII Headphone Amp
The GPU doesn't plug into the mobo directly by a 4 pin connection. The GPU gets plugged into a PCI slot on the mobo and then GPU is powered by the PSU. The PSU should have 4 pin and 6 pin power connections. The GPU itself will determine whether it's a 4 pin connection or 6 pin connection and if 1 or more connections are needed. I have an ATI HD 4870 that requires 2, 6 pin connections.
Windows 7 Ultimate 64 bitAMD Phenom II X4 965 Black EditionGSkill 4 X 2 GB PC 8500XFX Radeon HD 6790 D
Custom built
Gigabyte GA-MA790X-DS4
On board RealTek HD
Dual monitors:Samsung SyncMaster S20B300
1600 X 900
Seagate Barracuda 1TB (primary)
Seagate Barracuda 2 X 320 GB
Ultra X4 750 watt fully modular
Thermaltake Overseer RX 1 full tower
Core-Contact 92 mm CPU Cooler
Logitech G510
Razor DeathAdder
50/5 Mbps UL/DL
Optical: Super Muliti DVD burner w/lightscribe, Hauppauge WinTV HVR-1800
Some graphic cards come with a molex to 6 pin adapter and unless you use all your molex connections, you should be able to use the adapter. If you don't have an adapter you can also buy one pretty cheap for like a buck or two. I know this doesn't exactly answer your question but it an alternative solution.
Windows 7 Professional x64i5-2500KDDR3 8GBGTX 570
i5-2500K
ASRock Extreme3 Gen3
DDR3 8GB
GTX 570
Onboard MOBO
Asus
1TB HDD
HX850
Sunbeam Transformer
Systems 1 and 2: Windows 7 Enterprise x64, Wi...System 1: i7 [email protected], System 2: AMD FX-41...System 1: 8GB System 2: 8GBSystem 1: ATI FirePro V4800 System 2: Radeon ...
Dell and Custom
System1: Viewsonic HDMI 24"
10 MBPS
6 pin to 8 pin power connector works but not sure about 4 pin to 6 pin.
Windows 7 Home Premium 64-bit
