CPU Fan Question and/or problem
dbtmellis
4:34 PM
I worked on my friends computer yesterday. His CPU fan has being doing what I would describe as "pulsing". It speeds up in short bursts for about 2 seconds at a time, about every 2-3 minutes or so.
I opened up the case, cleaned out the fan blades, and oiled the fan bearing (with clipper oil). It is still doing the same thing.
I don't know what his system specs are, other that its an eMachines, with an AMD Processor.
Dell Insprion 530s
Windows 7 Home Premuim 64 Bit
Intel Core 2 Duo E4600 @ 2.4Ghz
Foxconn
Crucial 4GB
ATI Raedon 5450 1GB
Dell 19 inch
1TB Western Digital
Bestec 250w
GE
Microsoft Security Essentinals
Internet Explorer 11
The thermal paste could also stand to be removed and reapplied or better yet if you can get access to the back plate on the mobo and or remove the mobo (big job) you could look at a higher quality cpu cooler or even a 120mm sealed water cooler?
Windows 7 Ultimate 64
MSI P67A-GD80 b3
XFX Radeon 7870 2GB DDR5
Sound Blaster Z Series Card
1680 X 1050 p
(1) 1 tb WD Black
(2) 1 tb WD green/sata II
(2) 3 tb Seagate Barracuda
(1) 120 gb OCZ Vertex SS
(1) Drobo 5N w/5 Seagate 3tb
CoolerMaster Storm Styker
Basic 120mbps down
Chrome and IE 10
Netgear Nighthawk router
Asus USB 3 & sata 6 PCIe card
Drobo 5N advanced NAS
I don't think it would be cost effective to put a water cooled set up on a low end budget systems.
When was the last time anyone ever turned an eMachines system into a Gaming or CAD Rig?
Dell Insprion 530s
Foxconn
Crucial 4GB
ATI Raedon 5450 1GB
Dell 19 inch
1TB Western Digital
Bestec 250w
GE
I am going to re apply a fresh coat of CPU themal paste. I am out right now, I just ordered a new tube on newegg.com
Dell Insprion 530s
Foxconn
Crucial 4GB
ATI Raedon 5450 1GB
Dell 19 inch
1TB Western Digital
Bestec 250w
GE
Also look to the PSU and make sure you blast it clean with air, make and remake all the connections to the mobo and other powered components....never hurts. If it still happens then could be pointing to the PSU or mobo.
MSI P67A-GD80 b3
1680 X 1050 p
(1) 1 tb WD Black
Basic 120mbps down
Chrome and IE 10
