Creative audigy 4 crackling recorded sound HELP :((
listmajer
12:55 AM
I have problem with my creative audigy4 sound card,
i use FL studio 9 and pianissimo piano software, or any other it does not mether,
and midi evolution keyboard, and when i try to record my self, playing live, with microphone on and these plugins, the recorded sound is cracling, like interaptable, im using sony soundforge10 for live recordings.
this worked on xp, now i use win7 64bit ultimate,
intel core2quad q9550, 4gb ddr3 ram on 1600ghz,.....i think its not an comp. issue.
Did anyone had the same or similar problem????
Windows 7 Ultimate 64-bit
First thing, do you have the Win 7 drivers for this old SB sound card? If you only have Windows installed drivers, go to the Creative site and download the actual Creative drivers HERE
After you get the Creative drivers (if you don't have them), try recording the mic to the Windows sound recorder and see if you get the crackling there. If not, that would say the sound card is OK and the problem is probably in the setup for FL Studio. I use Sonar X1 so I can't say what FL studio actually needs.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
I have problem with my creative audigy4 sound card...the recorded sound is crackling,
Something easy to test...
Open the START menu and in the SEARCH FILES AND PROGRAMS box type "appearance" (no quotes). <enter>
UNcheck the "enable desktop composition" box and click on OK. Then try your programs. If no change, no harm...
You can revert to the default by clicking the "let Windows decide" button - same configuration page - or simply check the box that you UNchecked and click on OK.
Yes, UNchecking the box disables some fancy graphics, but the system will work just fine without them.
W7x64 Pro, SuSe 12.1/** W7 x64 Pro, XP MCEPhenom II 1090T w/Noctua NH-D14 /**4400+ X2 w...2 x 2GB Patriot PGS34g1600LLKA/**4x1GB Corsai...EVGA GTX460 SC/**EVGA 8800GTS
DIY
Asus Xonar D2X/**Xonar D1
HAF922/**Antec 1040IIB
3.3Mbps
(** = 2nd rig)
fireberd: Seems like there is a new driver, im downloading it right now, and see what will result be :)))
that doesnt help I will try this alternative solution, from daniel_k
i havent got problem with sound when im playing it and using mic, it sounds ok, normal, but when i play it back, its like i describe it abowe, i dont get it. Recorded song is wrong.
And one question for fireberd:
Can I use sonar x1 for live recording, will it record my midi input, playing and voice at same time????
Or do I have to record it separetly, like first piano, then voice...or can it do together?
Thenks :)
and meybe I sould explain my self, at the first place, to you that you know what is my goal, I would like to use my midi keyboard, play it(using VSTi plugin or stand alone) and sing and record that....simple :))))
I have done it with XP.
Maybe I'm misunderstanding, but it sounds as though the problem only appears when you are recording. If that is true, I would tend to suspect either the mike that you are using, or a bad connection on it.
DIY
3.3Mbps
(** = 2nd rig)
The problem appears when i playing recorded, the recorded sound is the issue. Everithing sounds great when im recording, but when im finished, and play what i recorded.....there is a problem, recording is bad.
I understand, but you mentioned that it happened when recording with a mike...what if you are just recording midi alone, does it still sound bad? In either case, it still sounds like the issue is with input, rather than the sound card or driver. Does it also sound bad if you play an audio that you did not record yourself?
DIY
3.3Mbps
(** = 2nd rig)
my audigy 4 also makes crappling noise like "i am robot" but this issue exist since 7 appeared. under xp my audigy 4 was perfect. after changing to 64 bit win 7 everithing went wrong. I mean on the input side cuz the output is crystal clear still on 16bit 24bit it doesnt matter. I tried danielk's driver but nothing changed.
anyway go to creative forums and have a look what creative says about this. at the end you will sell your card just because the driver is impossible to be fixed for years by the creative enginiers :D
anyway this hardware is not an old thing. the features of this card is still above the average but creative has the almighty xfi that they can sell if you cant use your older one which is on the win7 compatible list since the stable driver release.
Creative, never again.. - Creative Labs
Windows 7 x64
Windows 7 x64
well all my driver was up to date as usual cuz i always try to use the latest. i saw this desktop composition thing writen somewhere else but i didnt think that it may be the problem :D but it was
and here comes the question what is the connection between this windows service and the soundcard?
i cant belive its working now. god bless you mate!
are u from kazahstan? :)
Windows 7 x64
Windows 7 x64
I saw this desktop composition thing written somewhere else but i didn't think that it may be the problem :D but it was ...
and here comes the question what is the connection between this windows service and the soundcard? :)
Good to hear, mate. No I'm from The States.
Disabling Desktop Composition kills the AERO look, but that eye-candy doesn't affect much else.
Here, Windows Media Center runs - poorly, with some crackling - unless D.T.C. is turned off.
This is likely due to the elder status of my PC. The P4 with 256 video just isn't up to heavy video demands.
So, there comes a time, if you need more horsepower. ^_^
