Fan running at Full Speed, CPU Usage at 100%
Vetes
11:33 PM
In Task Manager, I see that my laptop has a total of 2038 MB of physical memory, but 0 of it is free. The only thing that I am running is Firefox with 4 tabs, Spybot, my touchpad program for my mouse and Open Office QuickStarter. My CPU usage is always above 80% and the fan runs at max nearly all of the time. Here's some more specs:
OS: Windows 7 Ultimate, 32-bit
Laptop Brand and Style: Compaq Presario C700
Processor: Intel Pentium Dual CPU T2390 1.86 GHz
RAM: 2GB
Could you open up your task manager click the processes tab make the window as large as you can and make a screenshot?
...I guess the real question in that is what is eating all the cpu?
It should show it in the process tab.
Windows 7 x64Intel i7 2600kG.skill Ripjaw 16gigs @ 1866Nvidia gtx580 (evga)
Insane hobo technologies. ;-)
Windows 7 x64
Intel i7 2600k
Asrock z68 extreme 4 gen 3
Integrated HD audio + hdmi
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
1 western digital 1tb (eSATA)
1 Seagate 1tb (eSATA)
Zalmann
Microsoft wireless 3000 (v2)
Here it is. I had to make 2 screens as a few programs ran off the bottom.
Teatimer is running amok for some reason.
It's a valid component of spybot search and destroy but I've seen it freak out like that before.
anyhow this will tell you how to disable it.
How to enable/disable Spybot Tea timer | Malware Help. Org
you are running avg active anyhow you don't even really need teatimer.
Windows 7 x64
Intel i7 2600k
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
Zalmann
Removing Teatimer has helped. Also, I had a BSOD a few times saying something about accessing memory. Also, I cannot run a Google search. Links clicked in a search go blank. I have to press Enter on the URL to open the link. I ran Spybot and AVG (Both are updated), but I cannot figure out what is going on.
Windows 7 x64
Intel i7 2600k
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
Zalmann
First off I don't think those old conextant modems ever got viable win 7 drivers.
You should probably just disable the device unless you are using dialup.
At any rate it's causing your system to load a whole slew of pre win 7 drivers and could be causing issues.
Update your intel storage drivers
http://downloadcenter.intel.com/Det...rsion=Windows 7, 64-bit*&DownloadType=Drivers
Your realtek lan driver is also out of date.
Realtek 10/100/1000 NDIS 5.1 Driver - Realtek
purendis.sys - your pure networks driver is also pre windows 7, but I can find no evidence they ever made a driver better than what you have.
I also want you to run a secure file check.
(Just to be safe some info is missing from the dumpfile could be corruption.)
you have a lot of vista drivers trying to hold up for windows 7 on your machine. I linked the ones I knew the update locations for.
KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003.  This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG.  This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG.  This will let us see why this breakpoint is
happening.
Arguments:
Arg1: c0000005, The exception code that was not handled
Arg2: 82e564a0, The address that the exception occurred at
Arg3: 8af1b864, Trap Frame
Arg4: 00000000
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
FAULTING_IP:
nt!ExpAllocateHandleTableEntry+1f
82e564a0 f00fba2800      lock bts dword ptr [eax],0
TRAP_FRAME:  8af1b864 -- (.trap 0xffffffff8af1b864)
ErrCode = 00000002
eax=0000000c ebx=00000000 ecx=0000000c edx=000f001f esi=00000000 edi=852cad48
eip=82e564a0 esp=8af1b8d8 ebp=8af1b8e8 iopl=0         nv up ei ng nz ac pe nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010296
nt!ExpAllocateHandleTableEntry+0x1f:
82e564a0 f00fba2800      lock bts dword ptr [eax],0   ds:0023:0000000c=????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
BUGCHECK_STR:  0x8E
PROCESS_NAME:  AVGIDSMonitor.
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 82e55100 to 82e564a0
STACK_TEXT:
8af1b8e8 82e55100 8af1b908 8af1b950 b1dd4fc0 nt!ExpAllocateHandleTableEntry+0x1f
8af1b900 82e3acd9 00000000 8af1b950 b1dd4fd8 nt!ExCreateHandle+0x1a
8af1b958 82e3b0d3 00000000 b1dd4fd8 000f001f nt!ObpCreateHandle+0x2a8
8af1bafc 82e3affa 00000000 000f001f 00000000 nt!ObInsertObjectEx+0xd0
8af1bb18 82e49392 b1dd4fd8 00000000 000f001f nt!ObInsertObject+0x1e
8af1bb84 82c5b41a 8af1bc98 000f001f 00000000 nt!NtCreateSection+0x1df
8af1bb84 82c59015 8af1bc98 000f001f 00000000 nt!KiFastCallEntry+0x12a
8af1bd00 82c8603b 80002028 00000000 852cad48 nt!ZwCreateSection+0x11
8af1bd50 82e269df 00000001 ab4e8510 00000000 nt!ExpWorkerThread+0x10d
8af1bd90 82cd8219 82c85f2e 00000001 00000000 nt!PspSystemThreadStartup+0x9e
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x19
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!ExpAllocateHandleTableEntry+1f
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrpamp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4d9fd915
FAILURE_BUCKET_ID:  0x8E_nt!ExpAllocateHandleTableEntry+1f
Followup: MachineOwner
0: kd> lm t n
start    end        module name
82c18000 83028000   nt       ntkrpamp.exe Fri Apr 08 22:57:09 2011 (4D9FD915)
83028000 8305f000   hal      halmacpi.dll Mon Jul 13 18:11:03 2009 (4A5BBF07)
83200000 83234000   ks       ks.sys       Wed Mar 03 21:57:52 2010 (4B8F2FC0)
8323e000 832b6000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 20:06:41 2009 (4A5BDA21)
832b6000 832c7000   PSHED    PSHED.dll    Mon Jul 13 20:09:36 2009 (4A5BDAD0)
832c7000 832cf000   BOOTVID  BOOTVID.dll  Mon Jul 13 20:04:34 2009 (4A5BD9A2)
832cf000 83311000   CLFS     CLFS.SYS     Mon Jul 13 18:11:10 2009 (4A5BBF0E)
83311000 833bc000   CI       CI.dll       Mon Jul 13 20:09:28 2009 (4A5BDAC8)
833bc000 833d3000   rassstp  rassstp.sys  Mon Jul 13 18:54:57 2009 (4A5BC951)
83400000 83418000   raspppoe raspppoe.sys Mon Jul 13 18:54:53 2009 (4A5BC94D)
83418000 8342f000   raspptp  raspptp.sys  Mon Jul 13 18:54:47 2009 (4A5BC947)
8343b000 834ac000   Wdf01000 Wdf01000.sys Mon Jul 13 18:11:36 2009 (4A5BBF28)
834ac000 834ba000   WDFLDR   WDFLDR.SYS   Mon Jul 13 18:11:25 2009 (4A5BBF1D)
834ba000 83502000   ACPI     ACPI.sys     Mon Jul 13 18:11:11 2009 (4A5BBF0F)
83502000 8350b000   WMILIB   WMILIB.SYS   Mon Jul 13 18:11:22 2009 (4A5BBF1A)
8350b000 83513000   msisadrv msisadrv.sys Mon Jul 13 18:11:09 2009 (4A5BBF0D)
83513000 8353d000   pci      pci.sys      Mon Jul 13 18:11:16 2009 (4A5BBF14)
8353d000 83548000   vdrvroot vdrvroot.sys Mon Jul 13 18:46:19 2009 (4A5BC74B)
83548000 83559000   partmgr  partmgr.sys  Mon Jul 13 18:11:35 2009 (4A5BBF27)
83559000 83569000   volmgr   volmgr.sys   Mon Jul 13 18:11:25 2009 (4A5BBF1D)
83569000 835b4000   volmgrx  volmgrx.sys  unavailable (00000000)
835b4000 835bb000   intelide intelide.sys Mon Jul 13 18:11:19 2009 (4A5BBF17)
835bb000 835c9000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 18:11:15 2009 (4A5BBF13)
835c9000 835d1000   compbatt compbatt.sys Mon Jul 13 18:19:18 2009 (4A5BC0F6)
835d1000 835dc000   BATTC    BATTC.SYS    Mon Jul 13 18:19:15 2009 (4A5BC0F3)
835dc000 835f2000   mountmgr mountmgr.sys Mon Jul 13 18:11:27 2009 (4A5BBF1F)
83609000 836d1000   iaStor   iaStor.sys   Sun Sep 30 00:20:12 2007 (46FF320C)
836d1000 836da000   atapi    atapi.sys    Mon Jul 13 18:11:15 2009 (4A5BBF13)
836da000 836fd000   ataport  ataport.SYS  Mon Jul 13 18:11:18 2009 (4A5BBF16)
836fd000 83706000   amdxata  amdxata.sys  Tue May 19 12:57:35 2009 (4A12F30F)
83706000 8373a000   fltmgr   fltmgr.sys   Mon Jul 13 18:11:13 2009 (4A5BBF11)
8373a000 8374b000   fileinfo fileinfo.sys Mon Jul 13 18:21:51 2009 (4A5BC18F)
8374b000 837a8000   cng      cng.sys      Mon Jul 13 18:32:55 2009 (4A5BC427)
837a8000 837eee80   avgtdix  avgtdix.sys  Mon Apr 04 16:53:24 2011 (4D9A3DD4)
86c33000 86c3b000   kdcom    kdcom.dll    Mon Jul 13 20:08:58 2009 (4A5BDAAA)
88e00000 88e22000   ndiswan  ndiswan.sys  Mon Jul 13 18:54:34 2009 (4A5BC93A)
88e22000 88e2e000   kbdhid   kbdhid.sys   Mon Jul 13 18:45:09 2009 (4A5BC705)
88e38000 88f67000   Ntfs     Ntfs.sys     Mon Jul 13 18:12:05 2009 (4A5BBF45)
88f67000 88f92000   msrpc    msrpc.sys    unavailable (00000000)
88f92000 88fa5000   ksecdd   ksecdd.sys   Mon Jul 13 18:11:56 2009 (4A5BBF3C)
88fa5000 88fb3000   pcw      pcw.sys      Mon Jul 13 18:11:10 2009 (4A5BBF0E)
88fb3000 88fbc000   Fs_Rec   Fs_Rec.sys   unavailable (00000000)
88fbc000 88ff5000   dxgmms1  dxgmms1.sys  Wed Feb 02 21:34:49 2011 (4D4A2259)
89000000 89018000   rasl2tp  rasl2tp.sys  Mon Jul 13 18:54:33 2009 (4A5BC939)
89018000 89026000   umbus    umbus.sys    Mon Jul 13 18:51:38 2009 (4A5BC88A)
8902e000 890e5000   ndis     ndis.sys     Mon Jul 13 18:12:24 2009 (4A5BBF58)
890e5000 89123000   NETIO    NETIO.SYS    Mon Jul 13 18:12:35 2009 (4A5BBF63)
89123000 89148000   ksecpkg  ksecpkg.sys  Thu Dec 10 22:04:22 2009 (4B21C4C6)
89148000 89175000   rdyboost rdyboost.sys Mon Jul 13 18:22:02 2009 (4A5BC19A)
89175000 891a7000   fvevol   fvevol.sys   Fri Sep 25 21:24:21 2009 (4ABD7B55)
891a7000 891cc000   CLASSPNP CLASSPNP.SYS Mon Jul 13 18:11:20 2009 (4A5BBF18)
891d9000 891ec000   HIDCLASS HIDCLASS.SYS Mon Jul 13 18:51:01 2009 (4A5BC865)
891ec000 891fe000   AgileVpn AgileVpn.sys Mon Jul 13 18:55:00 2009 (4A5BC954)
89200000 89206500   avgrkx86 avgrkx86.sys Wed Mar 16 09:05:26 2011 (4D80C3A6)
89207000 8920af80   AVGIDSEH AVGIDSEH.Sys Mon Feb 21 23:22:33 2011 (4D634819)
8920c000 89355000   tcpip    tcpip.sys    Sun Apr 24 21:36:36 2011 (4DB4DE34)
89355000 89386000   fwpkclnt fwpkclnt.sys Mon Jul 13 18:12:03 2009 (4A5BBF43)
89386000 8938f000   vmstorfl vmstorfl.sys unavailable (00000000)
8938f000 893ce000   volsnap  volsnap.sys  Mon Jul 13 18:11:34 2009 (4A5BBF26)
893ce000 893d6000   spldr    spldr.sys    Mon May 11 11:13:47 2009 (4A084EBB)
893d6000 893e6000   mup      mup.sys      Mon Jul 13 18:14:14 2009 (4A5BBFC6)
893e6000 893ee000   hwpolicy hwpolicy.sys Mon Jul 13 18:11:01 2009 (4A5BBF05)
893ee000 893ff000   disk     disk.sys     Mon Jul 13 18:11:28 2009 (4A5BBF20)
8f200000 8f212000   intelppm intelppm.sys Mon Jul 13 18:11:03 2009 (4A5BBF07)
8f212000 8f21b000   wmiacpi  wmiacpi.sys  Mon Jul 13 18:19:16 2009 (4A5BC0F4)
8f21b000 8f236000   luafv    luafv.sys    Mon Jul 13 18:15:44 2009 (4A5BC020)
8f236000 8f250000   WudfPf   WudfPf.sys   Mon Jul 13 18:50:13 2009 (4A5BC835)
8f250000 8f260000   lltdio   lltdio.sys   Mon Jul 13 18:53:18 2009 (4A5BC8EE)
8f260000 8f2a6000   nwifi    nwifi.sys    Mon Jul 13 18:51:59 2009 (4A5BC89F)
8f2a6000 8f2b6000   ndisuio  ndisuio.sys  Mon Jul 13 18:53:51 2009 (4A5BC90F)
8f2b6000 8f2c0000   purendis purendis.sys Mon Oct 27 23:32:00 2008 (490695C0)
8f2c0000 8f2d3000   rspndr   rspndr.sys   Mon Jul 13 18:53:20 2009 (4A5BC8F0)
8f2fa000 8f319000   cdrom    cdrom.sys    Mon Jul 13 18:11:24 2009 (4A5BBF1C)
8f319000 8f325000   avgmfx86 avgmfx86.sys Tue Mar 01 06:23:55 2011 (4D6CE55B)
8f325000 8f32c000   Null     Null.SYS     unavailable (00000000)
8f32c000 8f333000   Beep     Beep.SYS     Mon Jul 13 18:45:00 2009 (4A5BC6FC)
8f333000 8f33f000   vga      vga.sys      Mon Jul 13 18:25:50 2009 (4A5BC27E)
8f33f000 8f360000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 18:25:49 2009 (4A5BC27D)
8f360000 8f36d000   watchdog watchdog.sys Mon Jul 13 18:24:10 2009 (4A5BC21A)
8f36d000 8f375000   RDPCDD   RDPCDD.sys   Mon Jul 13 19:01:40 2009 (4A5BCAE4)
8f375000 8f37d000   rdpencdd rdpencdd.sys Mon Jul 13 19:01:39 2009 (4A5BCAE3)
8f37d000 8f385000   rdprefmp rdprefmp.sys Mon Jul 13 19:01:41 2009 (4A5BCAE5)
8f385000 8f390000   Msfs     Msfs.SYS     unavailable (00000000)
8f390000 8f39e000   Npfs     Npfs.SYS     Mon Jul 13 18:11:31 2009 (4A5BBF23)
8f39e000 8f3b5000   tdx      tdx.sys      Mon Jul 13 18:12:10 2009 (4A5BBF4A)
8f3b5000 8f3c0000   TDI      TDI.SYS      Mon Jul 13 18:12:12 2009 (4A5BBF4C)
8f3c0000 8f3f2000   netbt    netbt.sys    Mon Jul 13 18:12:18 2009 (4A5BBF52)
8f3f2000 8f3fc000   rdpbus   rdpbus.sys   Mon Jul 13 19:02:40 2009 (4A5BCB20)
8f408000 8f462000   afd      afd.sys      Sun Apr 24 21:35:37 2011 (4DB4DDF9)
8f462000 8f469000   wfplwf   wfplwf.sys   Mon Jul 13 18:53:51 2009 (4A5BC90F)
8f469000 8f488000   pacer    pacer.sys    Mon Jul 13 18:53:58 2009 (4A5BC916)
8f488000 8f499000   vwififlt vwififlt.sys Mon Jul 13 18:52:03 2009 (4A5BC8A3)
8f499000 8f4a7000   netbios  netbios.sys  Mon Jul 13 18:53:54 2009 (4A5BC912)
8f4a7000 8f4ba000   wanarp   wanarp.sys   Mon Jul 13 18:55:02 2009 (4A5BC956)
8f4ba000 8f4ca000   termdd   termdd.sys   Mon Jul 13 19:01:35 2009 (4A5BCADF)
8f4ca000 8f50b000   rdbss    rdbss.sys    Mon Jul 13 18:14:26 2009 (4A5BBFD2)
8f50b000 8f515000   nsiproxy nsiproxy.sys Mon Jul 13 18:12:08 2009 (4A5BBF48)
8f515000 8f51f000   mssmbios mssmbios.sys Mon Jul 13 18:19:25 2009 (4A5BC0FD)
8f51f000 8f52b000   discache discache.sys Mon Jul 13 18:24:04 2009 (4A5BC214)
8f52b000 8f58f000   csc      csc.sys      Mon Jul 13 18:15:08 2009 (4A5BBFFC)
8f58f000 8f5a7000   dfsc     dfsc.sys     Tue Apr 26 21:33:45 2011 (4DB78089)
8f5a7000 8f5b5000   blbdrive blbdrive.sys Mon Jul 13 18:23:04 2009 (4A5BC1D8)
8f5b5000 8f5f0100   avgldx86 avgldx86.sys Thu Jan 06 22:35:29 2011 (4D269811)
8f5f1000 8f5f4700   CmBatt   CmBatt.sys   Mon Jul 13 18:19:18 2009 (4A5BC0F6)
8f5f5000 8f5f7680   cpqbttn  cpqbttn.sys  Tue Feb 23 13:52:19 2010 (4B8431F3)
8f5f8000 8f5fe480   HIDPARSE HIDPARSE.SYS Mon Jul 13 18:50:59 2009 (4A5BC863)
8f800000 8f82c000   Apfiltr  Apfiltr.sys  Mon Jun 25 04:53:10 2007 (467F9086)
8f82c000 8f831280   GEARAspiWDM GEARAspiWDM.sys Mon May 18 07:16:53 2009 (4A1151B5)
8f832000 8f833380   swenum   swenum.sys   Mon Jul 13 18:45:08 2009 (4A5BC704)
8f837000 8f947000   athr     athr.sys     Tue Jun 09 13:04:52 2009 (4A2EA444)
8f947000 8f951000   vwifibus vwifibus.sys Mon Jul 13 18:52:02 2009 (4A5BC8A2)
8f951000 8f95c000   usbuhci  usbuhci.sys  Mon Jul 13 18:51:10 2009 (4A5BC86E)
8f95c000 8f9a7000   USBPORT  USBPORT.SYS  Mon Jul 13 18:51:13 2009 (4A5BC871)
8f9a7000 8f9b6000   usbehci  usbehci.sys  Mon Jul 13 18:51:14 2009 (4A5BC872)
8f9b6000 8f9c7000   Rtnicxp  Rtnicxp.sys  Mon Jan 22 21:01:00 2007 (45B57A6C)
8f9c7000 8f9df000   i8042prt i8042prt.sys Mon Jul 13 18:11:23 2009 (4A5BBF1B)
8f9df000 8f9e3180   HpqKbFiltr HpqKbFiltr.sys Mon Jun 18 17:12:03 2007 (46770333)
8f9e4000 8f9f1000   kbdclass kbdclass.sys Mon Jul 13 18:11:15 2009 (4A5BBF13)
8f9f1000 8f9fe000   mouclass mouclass.sys Mon Jul 13 18:11:15 2009 (4A5BBF13)
90200000 9021f000   HDAudBus HDAudBus.sys Mon Jul 13 18:50:55 2009 (4A5BC85F)
9021f000 9022c000   CompositeBus CompositeBus.sys Mon Jul 13 18:45:26 2009 (4A5BC716)
9022c000 90237000   ndistapi ndistapi.sys Mon Jul 13 18:54:24 2009 (4A5BC930)
90237000 90740000   igdkmd32 igdkmd32.sys Wed Sep 23 14:18:09 2009 (4ABA7471)
90740000 907f7000   dxgkrnl  dxgkrnl.sys  Mon Nov 01 21:37:53 2010 (4CCF7981)
90a00000 90a0a000   Dxapi    Dxapi.sys    Mon Jul 13 18:25:25 2009 (4A5BC265)
90a0a000 90a15000   monitor  monitor.sys  Mon Jul 13 18:25:58 2009 (4A5BC286)
90a15000 90a1f000   pnarp    pnarp.sys    Tue Oct 28 00:57:40 2008 (4906A9D4)
90a21000 90a65000   usbhub   usbhub.sys   Mon Jul 13 18:52:06 2009 (4A5BC8A6)
90a65000 90a76000   NDProxy  NDProxy.SYS  Mon Jul 13 18:54:27 2009 (4A5BC933)
90a76000 90aac000   CHDRT32  CHDRT32.sys  Wed Feb 27 16:26:01 2008 (47C5E379)
90aac000 90adb000   portcls  portcls.sys  Mon Jul 13 18:51:00 2009 (4A5BC864)
90adb000 90af4000   drmk     drmk.sys     Mon Jul 13 19:36:05 2009 (4A5BD2F5)
90af4000 90b32000   HSXHWAZL HSXHWAZL.sys Wed Jun 20 13:28:32 2007 (467971D0)
90b32000 90bfa000   dump_iaStor dump_iaStor.sys Sun Sep 30 00:20:12 2007 (46FF320C)
90e07000 90f0a000   HSX_DPV  HSX_DPV.sys  Wed Jun 20 13:29:51 2007 (4679721F)
90f0a000 90fbf000   HSX_CNXT HSX_CNXT.sys Wed Jun 20 13:28:20 2007 (467971C4)
90fbf000 90fcc000   modem    modem.sys    Mon Jul 13 18:55:24 2009 (4A5BC96C)
90fcc000 90fde000   RTSTOR   RTSTOR.SYS   Thu Sep 27 04:33:25 2007 (46FB78E5)
90fde000 90fdf700   USBD     USBD.SYS     Mon Jul 13 18:51:05 2009 (4A5BC869)
90fe0000 90fed000   crashdmp crashdmp.sys Mon Jul 13 18:45:50 2009 (4A5BC72E)
90fed000 90ffe000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 18:12:47 2009 (4A5BBF6F)
94000000 94009000   TSDDD    TSDDD.dll    unavailable (00000000)
94030000 9404e000   cdd      cdd.dll      unavailable (00000000)
941a0000 943eb000   win32k   win32k.sys   Wed Mar 02 21:31:07 2011 (4D6F0B7B)
99c23000 99ca8000   HTTP     HTTP.sys     Mon Jul 13 18:12:53 2009 (4A5BBF75)
99ca8000 99cc1000   bowser   bowser.sys   Tue Feb 22 23:05:24 2011 (4D649594)
99cc1000 99cd3000   mpsdrv   mpsdrv.sys   Mon Jul 13 18:52:52 2009 (4A5BC8D4)
99cd3000 99cf6000   mrxsmb   mrxsmb.sys   Tue May 03 21:43:40 2011 (4DC0BD5C)
99cf6000 99d31000   mrxsmb10 mrxsmb10.sys Tue May 03 21:43:56 2011 (4DC0BD6C)
99d31000 99d4c000   mrxsmb20 mrxsmb20.sys Tue May 03 21:43:47 2011 (4DC0BD63)
99d64000 99d67b80   AVGIDSShim AVGIDSShim.Sys Wed Feb 09 22:59:09 2011 (4D53709D)
99d68000 99d6b180   mdmxsdk  mdmxsdk.sys  Mon Jun 19 16:26:59 2006 (449716A3)
b1a08000 b1a9f000   peauth   peauth.sys   Mon Jul 13 19:35:44 2009 (4A5BD2E0)
b1a9f000 b1aa9000   secdrv   secdrv.SYS   Wed Sep 13 08:18:32 2006 (45080528)
b1aa9000 b1aca000   srvnet   srvnet.sys   Thu Apr 28 21:57:12 2011 (4DBA2908)
b1aca000 b1ad7000   tcpipreg tcpipreg.sys Mon Jul 13 18:54:14 2009 (4A5BC926)
b1ad7000 b1adf000   xaudio   xaudio.sys   Tue Jul 10 16:27:55 2007 (4693F9DB)
b1adf000 b1ae3400   AVGIDSFilter AVGIDSFilter.Sys Wed Feb 09 22:59:07 2011 (4D53709B)
b1ae4000 b1b33000   srv2     srv2.sys     Thu Apr 28 21:57:19 2011 (4DBA290F)
b1b33000 b1b52300   AVGIDSDriver AVGIDSDriver.Sys Thu Apr 14 12:10:38 2011 (4DA72A8E)
b1b53000 b1ba5000   srv      srv.sys      Thu Apr 28 21:57:31 2011 (4DBA291B)
b1ba5000 b1bc5480   WUDFRd   WUDFRd.sys   Mon Jul 13 18:50:44 2009 (4A5BC854)
b1bc6000 b1bcf000   asyncmac asyncmac.sys Mon Jul 13 18:54:46 2009 (4A5BC946)
b1bcf000 b1bcf680   giveio   giveio.sys   Wed Apr 03 21:33:25 1996 (316334F5)
b1bd0000 b1bd3a00   speedfan speedfan.sys Sat Dec 18 05:03:50 2010 (4D0C9516)
Unloaded modules:
99d6c000 99dd6000   spsys.sys
    Timestamp: unavailable (00000000)
    Checksum:  00000000
    ImageSize:  0006A000
    Checksum:  00000000
    ImageSize:  0006A000
    Checksum:  00000000
    ImageSize:  0006A000
99d4c000 99d64000   parport.sys
    Checksum:  00000000
    ImageSize:  00018000
891cc000 891d9000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000D000
8f221000 8f2e9000   dump_iaStor.
    Checksum:  00000000
    ImageSize:  000C8000
8f2e9000 8f2fa000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00011000
Windows 7 x64
Intel i7 2600k
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
Zalmann
The reason for all of the Vista drivers is that this laptop originally had Vista. I was selected to hold a Windows 7 party which came with an upgrade copy of Windows 7.
I updated the Intel drivers, disabled the modem and ran the System File Checker. It said "Windows Resource Protection did not find any integrity violations."
However, I could not identify what Realtek driver I needed from the link. There's quite a list of different drivers on that page.
Windows 7 x64
Intel i7 2600k
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
Zalmann
I did find the correct driver here just in case someone else needs it. Now, the only other question I have is about the fan. It does seem to be running very hot, so hot that it heats up the left side of the keyboard. After performing all of these functions, my free physical memory is still relatively small. Is there anyway to increase it?
you can remove extra startup items from boot using msconfig
just go to the search box type msconfig and hit enter.
Enable selective startup and go to the startup tab.
It's probably in your best interest to investigate the items there on your own so you can figure their importance. The computer will run without any of them loading but some of them are better to have around than others.
I generally disable any tray apps related to printing as the printer still works without them. since we are dealing with a laptop heat comes with the Territory you can consider a powered cooling pad for it. Or even a professional cleaning.
Given its age it's very likely got some dust clogging it up inside.
Of course it's possible to clean it yourself, but taking apart a laptop is not something I recommend for people with no experience and no one to help them.
Windows 7 x64
Intel i7 2600k
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
Zalmann
I've gotten rid all of them. I used msconfig, then restarted my PC before I posted my last post. Sorry, I should have said something.
I idle with about 1.5 gigs in use. I have more ram than that though. I wouldn't worry about it, win 7 is better with managing memory than previous versions, and while it keeps more in use in general. It's usually for a good reason. It will push unused items into the pagefile if it needs to for opening a large app or game.
Windows 7 x64
Intel i7 2600k
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
Zalmann
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
The vents don't look clogged at all. I will probably still blow air into the vents though to move any dust that I cannot see.
