Help help help !!!
Mihajlo
7:16 AM
1. problem : Hi , I am installed Windows 7 Ultimate 32bit on 512mb ram and 2.4 processor (i like playing with computers) and graphic card 64mb (i don't know full name xD ) ,
I am log on and the screen resolution was 640x480 , i have an old monitor , 1024x768 , i first go on right click , screen resolution and i can't change the resolution ...
: Imageshack - newbitmapimageak.jpg - Uploaded by Imageshack user
2. problem : I can't install the Windows 7 Themes , i think it's because i havent Theme Patcher , i don't know , im begginer with this OS ...
Windows 10 Pro x64, Arch LinuxIntel Core 2 Quad Q8200 OC'd 3.08GHz8GB DDR2 900MhzMSI GT730 2GB GDDR5 (Kepler)
Asus Rampage formula LGA775
8GB DDR2 900Mhz
Supreme FX2
Samsung LS22F350 LED
1080P
Kingston SSDNow UV400 120GB, 500GB Hitachi, 2TB Samsung, 500GB Seagate FreeAgent, 640GB Samsung, 160GB Toshiba (Arch)
AeroCool 500W Bronze
Cooler Master V6 + 3X fans
Prolink keyboard
Logitech M705
1MiB/s
Chrome Beta
Hi Mihajlo, welcome to the forums :)
Your first issue is that Windows has detected your card as Standard VGA Adapter which is why you cannot change past 640x480. Your best option at this moment is to find out the exact make & model of your card and download the relevant drivers for it.
You may find that the latest drivers will be for Vista so try installing them in http://www.sevenforums.com/tutorials/316-compatibility-mode.html for Windows 7
I have had Windows 7 installed on a rig with only a 64MB card and did indeed manage to get the Aero themes working but it did behave very sluggish.
Windows 7 Ultimate x64AMD Sempron Dual Core3GBNVIDIA GeForce 6150SE nForce 430
Compaq Desktop
3GB
1024x768
150GB Sata
Another thing to note is the version of DirectX that your card can handle natively e.g. what the hardware was written for. You'll find that if your card does not fully support DX 9 or above then you wont be able to have the Aero look.
Compaq Desktop
3GB
1024x768
150GB Sata
Welcome to SevenForums.
I congratulate you on getting Win 7 to run on your computer. If you can get some more ram, then 1 GB and preferably two GB will bring a big performance improvement.
MS Windows 7 Ultimate SP1 64-bitAMD A10-4600M6.00 GB Dual-Channel DDR3 @ 798MHz (11-11-12-28)AMD Radeon HD 7660G
AMD A10-4600M
AMD Pumori (Socket FT1)
AMD Radeon HD 7660G
High Definition Audio Device
1600x900@60Hz
Standard PS/2 Keyboard
