Help regarding connecting Laptop TO Desktop using LAN CABLE
nkam
12:27 PM
Aurangabad, India
Hello friends I am new on this forum
I just bought a laptop and I was trying to connect it to my desktop by using LAN CABLE for data transfer.
I have tried everything my way but it is not working :(
I am using Windows7 ultimate and Windows7 Premium OS.
Control Panel\Network and Internet\Network Connections -> Local Area Connection -> Properties -> Internet Protocol Version 4 (TCP/IPv4) -> Properties
I set my computer's ID to 192.168.1.2
Subnet Mask : 255.255.255.0
GateWay : 192.268.1.1
I set my Laptop's ID to 192.168.1.3
What more I need to do to connect them?
Please help me as soon as possible.
Thank you in advance.
I am sorry I am new on this site I posted this wrongly in another section :(
Now posting in correct area
Windows 7 64 Bit
2GB Nvidia GeForce GT 540M
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
GSkill Phoenix Pro 120GB SSD
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
Are you trying to connect both machines together directly? If so, you will need a crossover cable as opposed to a standard one. By far the better way would be to connect them both to your router using standard cables and configure sharing on both machines. This will also give the advantage of both machines still being able to connect to the Internet.
Of course, if you just want to transfer files from one machine to another, you could always use a USB memory stick. That would be far simpler and would eliminate any potential problems that you may come across when setting up sharing.
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
Will you please tell me the steps please ?
Thank you in advance :)
Windows 7 64 Bit
I am trying to connect both the machines having same machine name. Is it anyhow related to the problem?
Windows 7 64 Bit
Gigabyte IF233
Avast! 8.0.1497
IE 11
How to pair these devuces for the first time?
Windows 7 64 Bit
