Help regarding connecting Laptop TO Desktop using LAN CABLE
nkam
1:07 PM
Aurangabad, India
Hello friends I am new on this forum
I just bought a laptop and I was trying to connect it to my desktop by using LAN CABLE for data transfer.
I have tried everything my way but it is not working :(
Control Panel\Network and Internet\Network Connections -> Local Area Connection -> Properties -> Internet Protocol Version 4 (TCP/IPv4) -> Properties
I set my computer's ID to 192.168.1.2
Subnet Mask : 255.255.255.0
GateWay : 192.268.1.1
I set my Laptop's ID to 192.168.1.2
What more I need to do to connect them?
Please help me as soon as possible.
Thank you in advance.
Windows 7 64 Bit
2GB Nvidia GeForce GT 540M
If the cable isnt going through a router or switch it needs to be a "null" cable, also called a crossover. A regular cable wont work.
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
No sir I am connecting it directly to both the devices.:)
Windows 7 64 Bit
This should Help you. :)
Gigabyte Technology Co. Ltd.
Windows 10 Pro 64-Bit
Intel(R) Core(TM) i5-4460 CPU @ 3.20 GHz(4CPU's), ~3.2GHz
Gigabyte B85M-HD3-A
8192 RAM
NVIDIA GeForce 710
Integrated High Definition audio with Realtek ALC888 codec
Acer V183HV Ab 18.5" LCD Display
1366 x 768
HP
HP
100mbps
Chrome, Firefox
Please go with what zigzag has said and use a crossover cable and not a standard one and these are usually marked as such. The way to tell is look at the colours and placing of the wires into each end if they look the same it is not a crossover cable.
Also, for peer to peer connection, IP adresses need to be different for them to "see" each other.
Hope this helps.
HP Desktop Slimline
Windows 7 Home Premium 64-bit
Athlon
3GB
HP 20" LCD
500GB
Slow
Hope this helps.
Sir I have tried it with my friends laptop and it worked finely with the same cable but I am missing some settings I think so
Please guide me what more it needs to do :)
Windows 7 64 Bit
you mentioned "same cable" which means the standard cable right? you should use what zigzag3143 suggested, a crossover cable would fix your problem.
Please click HERE for step by step on how to make crossover cable
Gigabyte B85M-HD3-A
8192 RAM
NVIDIA GeForce 710
1366 x 768
HP
HP
100mbps
Chrome, Firefox
For you to be able to transfer data from one PC to another the IP addresses must be different - if you have them as stated above, it will not work.
HP Desktop Slimline
Athlon
3GB
HP 20" LCD
500GB
Slow
Oh thanks for pictorial answer but I am using Crossover Cable only :(
Windows 7 64 Bit
I am sorry I set laptop's IP to 192.168.1.3 :)
Windows 7 64 Bit
How to pair these devuces for the first time?
Windows 7 64 Bit
There is no pairing, like in Bluetooth. You have to share out folders on one or both of the computers.
Intel Core i7-2600
Gigabyte GA-P67A-UD3P-B3
Nvidia GTX 470
Dell UltraSharp 2209WA
OCZ ModStream 700W
CoolerMaster HAF 912 Advanced
CoolerMaster Hyper 212 Plus
