[HELP] Connect Win 7 Ultm - XP Pro SP3 Using LAN Cable
RADITZ
4:44 AM
Greetings to all..
I'm a new member here. And also this my second day running my PC on win 7 ultimate. Not yet activated.
This last few hours i've got a lot of dizzy trying to connecting my old laptop with win xp into my PC win 7. And surprisingly win 7 use a new 'method' on sharing files with another computers.
Usually when i connect my 2 win xp pc, all i need to do is just setting up the IP addres for both pc and then plug up the LAN cable. Done, the xp connect themselves.
I did this one on my win 7. But it doesn't works perfectly. Both my pc and laptop were connected. i can see them on my windows explore network menu. But i can't browse the containing folder that shared on xp pc. And also on my win 7 pc.
Basicly, both my pc looks like already connected, BUT I CAN'T browse the shared folders that manually i set up to be share.
Plese help me how to connect win xp and win 7 ultimate properly.
Thank you.
Big regards.
Win 7 ultimate
Q6600
IX38
2GB DDR II
8800GT
RTL-888
Hi Raditz and welcome,
Did you add EVERYONE to permissions in Windows 7 shared folders?
Did you enable network sharing in the advanced Sharing Settings?
Here is an image. I'm not on my 7 Machine.
Asus
Windows 7 x64 Ultimate SP1
I5 875K Unlocked
P7P55D-E-PRO
Kingston HyperX Genesis DDR3-1600MHz 9-9-9-27 @ 1.65V XMP
EVGA GeForce GTX 570 HD 732 MHz GPU 1280 MB, 152 GB Mem
Onboard Via 1828S
Samsung T240 HD
Dual 1920X1200 1027X768
OCZ Vertex II Extended Sandforce SSD 60 Gig 2X WD Black Caviar 1 terabyte 6GBS Transer Sata 3 Marvell Chip
Corsair Gold fully Modular 80 Plus 850
Coolermaster Half X Full Tower
Noctua NH-U12P
MS
MS
Fast enough
My fridge has a water tap
Yes, I did add EVERYONE to permissions in Windows 7 shared folders.
Yes, I did enable network sharing in the advanced Sharing Settings.
Now my win 7 PC can browse (read and write) the folder of XP that I shared. But my XP can't browse the shared folder on win 7.
Does anybody can resolve this? :confused:
Win 7 ultimate
Q6600
IX38
2GB DDR II
8800GT
RTL-888
Do you have password enabled activated?
Try to disactivate.
Asus
I5 875K Unlocked
P7P55D-E-PRO
Onboard Via 1828S
Samsung T240 HD
Noctua NH-U12P
MS
MS
Fast enough
Win 7 ultimate
Q6600
IX38
2GB DDR II
8800GT
RTL-888
