Hi Guys,
Whenever i am shutting down my laptop, the BSOD will appear and the details of the error is as follows.
Im running on a Windows 7 OS
Model No. : DV6 - 6035TX
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 30/5/2011 8:25:48 PM
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Computer: WeiSheng-HP
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>2</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2011-05-30T12:25:48.670835400Z" />
<EventRecordID>16929</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>WeiSheng-HP</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">159</Data>
<Data Name="BugcheckParameter1">0x4</Data>
<Data Name="BugcheckParameter2">0x258</Data>
<Data Name="BugcheckParameter3">0xfffffa8005b06b60</Data>
<Data Name="BugcheckParameter4">0xfffff80000b9c4d0</Data>
<Data Name="SleepInProgress">true</Data>
<Data Name="PowerButtonTimestamp">129512223776260441</Data>
</EventData>
</Event>
Files that describe this problems:
C:\User\Wei Sheng\AppData\Local\Temp\WER8748.tmp.WERIntern
C:\Windows\MEMORY.DMP
As the Memory.DMP is 600 MB i cant attached it to the thread.Thus i attached the minidump file.
Hope ur able to help me guys.
Thank You in advance.
Regards.
Log Name: System
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Description:
Event Xml:
<System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Correlation />
</System>
<EventData>
</EventData>
</Event>
Regards.
- Windows 7 64 bit
